Question about Car Audio & Video
I recently bought a boat with a Clarion ''premium'' sound system. The radio turns on but only the front 2 speakers work. The back four have nothing? Any ideas? Is it the radio itself, the amp, or both? Thanks for the assistance.
  • 57 Answers
First i would check the audio settings on the radio make sure the balance and fader are all at 0 and not favoring the front only if they check out o i would make sure the wires are wired right in the back of the deck
Posted on Jun 04, 2009
I have a Clarion Marine XMD3 radio in my boat. There is a set of speakers in the back of the boat and a set in the cabin below deck. The set in the below deck cabin work fine. The set in the back of the...
Look for loose or broken wiring connections. Swap front and rear speakers wires at radio and determine if problem is the radio or the speaker system.
Aug 01, 2013 | Car Audio & Video
I have a Clarion XMD3 am/fm marine cd player that came with my 2000 Searay boat. I was somehow able to turn the inside cabin speakers off last season and only have the outside speakers on. I must have...
Might be set on mute !
Mute instructions
Use this function to turn off the sound immediately.
1. Press the [ M ] button.
The sound turns off and "MUTE" appears in the display.
2. Press the [ M ] button again to cancel the mute mode
in this other user manual it is a mute button[m] page 4
http://www.clarion.com/us/en/MungoBlobs/552/388/XMD3.pdf
or
Adjusting the fader
1. Press the [ A-M ] button and select "FAD 0".
2. Press the [ w ] button emphasizes the sound from the front
speaker, press the [ z ] button emphasizes the sound from the
rear speaker.
? The factory default setting is "FAD 0". (Adjustment range: F12 to
R12)
3. When the adjustment is complete, press the [ A-M ] button
several times until the function mode is reached
May 04, 2017 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Model-m 255 clarion installed in a pontoon boat. RADIO WAS WORKING JUST FINE, THEN I INSTALLED A (NEW) BATTERY FOR MY BOAT, HOOKED EVERTHING BACK THE SAME WAY. NOW, I HAVE POWER BUT (NO) SOUND...
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
Installed a clarion radio it powers up but no music thru speakers
sounds like a short in your wiring to your speakers the best thing to do to check this is run a speaker wire directly to the speaker from the stereo check it that way and see if it works.If that don't work it's the wires on the stereo connection.The speaker wires on most aftermarket stereos are mostly colored 2 of each green,purple,white & grey.
Nov 09, 2008 | Clarion DB538RMP CD Player
Help with install on clarion vrx935vd
I love Clarion
1st RED is + direct to battery
Yellow is + pwr to ignition so when you turn the car off the radio can still say on if you choose
black is - and ground
these are importantant first. once you have pwr you can easily work out which of the 8 other wires are pairs 2 frnt spkrs and 2 back speakers if theres 2 extra plugs for the amp or woofer(if screws run a nice thick speaker wire. But with Clarion I dont beleive you need an amp or woofer thats how good they are just have kickass speakers frnt an back
you should be able 2 find the pwr cables from the existin radio if not the yellow wire leads to the igniton and you can run a red wire staight to the battery and screw the black wire to the metal chasis(oh the blue wire is for a pwr antenna or aux and is not needed unless youve got a pwr antenna.
your speaker color code will be like eg.grey and grey with white stripe,will be one pair green another pair ,but the 4 spker pairs are skinner than th pwr cables
Spkrs have a + and - too the difference is you cant blow the spkr by trial and error its just if its wrong it will sound muffled so try both ways then youll know whats best. pwr must be correct make sure red on red and blacks on black then press on then play with your speakers then find the yellow cable that runs to the ignition then to the radio so when you turn the ign the radio comes on and when you turn the motor off you can turn the radio on cos youve also got a direct to battery connection.
Man you are gonna love your sound system
Im happy for you
Clapster
Feb 24, 2008 | Clarion VRX935VD Car DVD Player
No sound.
Disconnect speakers one by one and reset the unit each time. If the speaker is blown, or the wires are frayed, it will shut down the internal amp. Also check the fuse in the back of the radio first, it should be near the wire harness. Power cycle the unit as well, unplug it from the power source, plug it back in. Hope this helps.
Aug 16, 2007 | Clarion M475 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
