Question about SVA-USA VR-30W 30 in. LCD Television
My power supply went dead. the tv is still good.
Need a new transformer. amazon says out of stock. any ideas?
Ebay
Posted on Nov 19, 2009
My panasonic viera Plasma tv just went dead?
in no stand by power indicator, the first place to be checked will be the power supply board . check for blown fuse but before you replace new fuse you must need to check first bad component like shorted diode, transistor and transformer. then if the power supply board now working good then still the tv won't open check bad component at the SU or SD BOARD.
Sep 08, 2012 | Panasonic Televison & Video
While watching the TV the screen went blank and there wasn't any sound. I've checked all the cables. I tried turning it off and back on but when I did this the power light flashes 27 times before...
The tv power supply board it is shorted and dead.That the board where the tv power a/c cord plug into it.Tries websites like Shojimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 28, 2011 | LG 32LC2R 32 in. HD-Ready LCD Television
Problem with the JVC AV-36D503 36" TV.........TV will not turn on. Bought TV New in June of 2003...Dec 2003 the TV went Dead...They replaced the Safety Fuse. If same problem would you have any idea...
Tv might have more dead parts than just the safety fuse.If tv have only a power supply board fuse only they can do it for u wright there take the tv aparts and replace the tv power supply safety fuse like 15 mins job and will cost u like $40 dollars take it to any tvs repair shops.
Aug 25, 2011 | JVC AV-36D503 36" TV
The power went out tonight and now the TV wont turn on. When the power went out the TV was off. I have tried reseting the TV several time to no avail. The green timer light just keeps flashing. Any ideas...
Either the capacitors are shot or the high-voltage transformer aka power supply is shot. You can test power from transformer to main board with a voltmeter. you can test the resistance/continuity of any capacitor with a mulit-meter in the ohm position.
Feb 02, 2010 | Televison & Video
Sony KT-T25SF8 Dead, no video or audio, low level clicking noise
Most likly the Horizontal output transistor has shorted out because of cold solder connections on the flyback transformer, and or a bad capacitor in the sweep power supply and or, a bad flyback transformer. If the set Did not blow the fuse, then mopst likly you will have a problem in the main power supply where several parts in a kit form has and should be replaced all together.
Jan 17, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Totally dead. Vizio GV42L
If the circuit breaker was tripped, more likely the fuse inside the TV power supply might also be blown. If that is the case there might be a short circuit in the power supply components, more likely on a diode or transistor/mosfet.
Contact these website to see if they have the parts for your plasma.
Good Luck.
Dec 03, 2008 | Vizio GV42L 42 in. LCD Television
SONY TRINITRON 1996 35 INCH
Power supply failure caused by bad solder connects in horiz
drive circuit = four parts blown in quick succession = repair
shop cost = under 200.00...................................T.
Nov 25, 2007 | Sony KV-32S26 32" TV
Tv went dead while viewing, will not power back up
You have a short somewhere in the load for the power supply. Probably the horizontal output transistor and the flyback transformer. You need to have it checked out by a tech. You may want to get an estimate. Stargazer
Mar 11, 2007 | RCA F36715 36" TV
Sanyo DS31520 went dead
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Squealing noise is from the power supply teling you that there is an overload condiction. The overload is shifting the operational frequency of the power supply into upper audio hearing range. Check the diodes and caps in the supply circuit and the active components in the deflection circuit. also resolder the LOPT, h-output, h-driver, and h-driver transformer. Good luck
Jun 19, 2006 | Sanyo DS31520 31" TV
SVA-USA VR-30W 30 in. LCD Television Logo
214 people viewed this question
Top SVA-USA Televison & Video Experts
Michael Galve
Michael Galve
Adorjani Laszlo
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
