Question about Bosch WFK 2401
Beeping Our Bosch WFK 2401 will beep during the cycle of washing.  The machine will wash and then stop w/ Multiple beeps.  You have to push the start button to get it to wash again. This happens about 10 times a cycle.  You have to run to the machine and push start or it will beep again after a brief pause. I was told the timer might need to be reset.
  • 5 more comments
  • Jim Davis
    Jim Davis Nov 07, 2007
    I have not fixed my problem yet, but I found a great web site with a complete breakdown of parts for the WFK 2401.
    It is http://www.appliancepartspros.com/
    They also have live tech support free. It was really quite nice.
    Based upon my personal testing of my machine I think my problem may be
    1: the circuit board.
    2: a inlet valve for the hot or cold water.
    Error code 01 keeps flashing. The owners manual says this is a water inlet blockage or a valve problem.
  • Jim Davis
    Jim Davis Nov 19, 2007
    I actually fixed the machine about 1 week ago. the date of this posting.
    After much trial and error I figured out it was the Could water valve.
    It snapped out w/o the use of a screws. The hoses came off easily enough
    And I purchased a new part from a local dealer in Haltom, TX.
    The name was "Appliance Part's Depot." They were the cheepest
    for this part at $72.50. I followed the advise of another member and took
    Lots of pictures.
    Had I called a Tech to come to my home and fix it, it would have been big $.
    Now All I have to do is wait for the water valve to die.
  • choofly Nov 22, 2007
    Thanks for the post! I have the exact same problem with this washer. Was there a good way to test whether your problem was with the cold inlet valve or the hot inlet valve?
    Thanks,
    Mai
  • Jim Davis
    Jim Davis Nov 24, 2007
    Yes,
    There is a good way to test whether it is the cold water valve.
    Run the machine with out any clothes in it.  1st run it on a cold wash and then a hot wash.  Watch the amount of water moving through the machine.
    Right before you get the error you should be able to hear but not see a water going into the tub.  Pop out the detergent drawer and watch the water flow into the machine.
    I would not do this until you are sure that there is restricted water flow as you may end up with a really wet floor.
  • Anonymous Mar 22, 2014
    Turn on the desired cycle(regular dry).the time shows 1:01 and i'm ready to push on start/pause button"........nothing ....
  • Anonymous Mar 24, 2014
    Push button nothing happens
  • Anonymous Mar 31, 2014
    I have the same machine as above. The problem with it is it stops half way through the cycle. I push the start button again then it will go to the end of the cycle with out it washing. What could the problem be please help?
Thanks! I found this online, which shows how to run tests on the washer to see what might be wrong, which helped, too. Now if i can just find a few muscly people to help me move the dryer from atop the washer.
http://forum.appliancepartspros.com/attachments/washer-repair/42d1194897506-error-code-01-wfk2401test.pdf
from this page:
http://forum.appliancepartspros.com/washer-repair/2385-error-code-01-a.html
Posted on Nov 26, 2007
    Problem Solver:
  • 4 Answers
Thanks for posting this solution! I'll try it with mine.
Posted on Nov 20, 2007
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
Hi, the spin cycle on our bosch wfk 2401 suddenly stopped working. The wash and rinse cycle works but when it's time for the spin cycle to begin, the machine hums as though the motor is straining...
If there is motor humming while the spin cycle is ON , please confirm if the motor also heats up-- take caution not to touch live points. Also if you manually push the motor with care so see if the spin starts up then the capacitor (this assists with the starting) can be weak or faulty.
Remove and check with a mains tests and see if the charge retains, if not change. Other wise check if there is friction on the motor or drive.
Jun 14, 2011 | Bosch WFK 2401
Bosch wfk2401. machine stops and lights start blinking " error code 03"
washing machine does not spin on any cycle , however the belt is fine. Any recomdenations
Jun 13, 2011 | Bosch WFK 2401
What is the life expectancy of Bosch front loader (under counter)? Making loud noises during wash - not spin - cycles. Worth repairing?
not long. have a Bosch Axiss WFL 2060. It started making buzzing noises starting about a year ago and I ignored them. It failed and I am replacing either the motor or/and more things. If ur a DIY its definitely less expensive than a new machine. dwkendall sends
Dec 27, 2010 | Bosch WFK 2401
Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Apr 20, 2010 | Bosch WFK 2401
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Bosch WFK 2401 problem, please help
this could be a block in the pump or motor brushes would go for the pump
Jun 22, 2008 | Bosch Classixx WFL 2462 Front Load Washer
WFK 2401 DOOR does not open anymore
where is this machine i might be able to help over the phone
262-893-4840
Apr 23, 2008 | Bosch WFK 2401
Washing Machines Logo
1,095 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
