Stanton mixer one right side plays very quietly
right side plays very quietly and has loud overtone for both mixers and line in and phono for just that one side though when i plug evether table into the other line or phono i sounds fine
I have the same problem
Posted on Oct 20, 2009
How do I connect a Stanton SCS.4DJ turntable to my pc
This is a simple to use unit. Just plug the "line out" of the turntable to your "line in" on your PC or laptop. This is to just straight up record what you're mixing or playing as an audio file.
Jul 12, 2014 | Stanton SCS.4DJ Mixer Console
How to hook up to home amp
If home amp has a phono input and you have no turntable, plug the output of the MP3 player into the phono input and begin with the volume turned all the way down. If you do not have a phono input, you can plug something like a DJ mixer in to get that extra level of amplification you want for comfortable listening. If you do that, the MP3 player would plug into the turntable input and the mixer output would go to the available line level input of the home amp.
The CD player has either the coaxial connector, which is not common for home amps, and a pair of "RCA" jacks (right and left) which are.
The CD output can be connected to any avaialble line level input, such as anunused "Aux", "Tape In" "MD/VCR audio in, etc.
Dec 16, 2012 | Stanton C314 Tabletop CD and Mp3 Player
I have a T62 Stanton and I want to play it like a normal turntable. I conected it in the Behringer mixer using L/R cable. I cannot hear the bass sounds with my headphones. What is happening?
Is it connected to a "PHONO" input or something not labeled explicitly for PHONO?
"PHONO" is the only designated connection on an audio device that is literal and exclusive.Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn't have a PHONO connection you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some... http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
Apr 17, 2011 | Stanton T62 Turntable
My Technic 1200's are only playing out of one speaker at a time.
Clearly there IS a setup issue. Take serrato out of the loop for the moment and the mixer. Plug each deck (one at a time) into a hifi with a MM Phono input. Are you getting stereo? If yes, you know the decks are ok. Now reset the mixer completey. All eqs and pans including volumes to 12 o clock position and volumes to 0.
Make sure you connect deck one to a red and white of one phono input channel. Do not use 1 channel from phono and 1 from line. Use both left and right of the phono chanels.
Ok, now hook up the mixer to the amp. Keep the x-fader on channel 1 and concentrate getting a good stereo signal from this one chanel. Now do the same for the other cahnnel.
This should hae helped you to get up an running, if not narrow down the problem.
Apr 18, 2010 | Technics SL-1200 Turntable
Cdj will not play through mixer in stereo, mono only. Cables have been swapped from good deck to bad deck and problem still exists ,and deck has been swapped to the other side of mixer master channel to...
is your mixer switched to line and not phono some mixer have a switch at the back for the phono chanels, I dont mean the ones on to for to select what input you want,
its usualy a small slider switch next to the rca's sockets at the back
Jan 11, 2010 | Pioneer CDJ-1000 CD Player
I have a Stanton T.80 and Vestax VMC-185XL mixer. I recently bought Rane Serato Scratch Live which requires the turntables to be grounded through the mixer...however, the turntable doesnt have a ground...
Hi gium
Sounds like we have reached that point where progressive crossover in technologies means that the usual cautions of earth continuity for the tone arm when using a phono preamp has gone the same way as phono preamps on home theatre.
Have you tried switching to the line level and set the mixer up for that level also. That may reduce any gain induced hum. However it sounds like an earth loop problem, where both decks will need to be earthed in the mixer. Check also that all the gear is running of the same power point. Different mains phases are sometimes available near each other, having any gear (power amps also) on a different phase will cause an earth loop problem.
Is the hum all the time independent of the volume levels, or change with levels adjustments and not at all when turned right down. Let me if changing to line levels helps. We can try some more things, like connecting a temp hookup wire earth to the RCA earth to mixer chassis. Cheers
regards
robotek
Oct 04, 2008 | Audio Players & Recorders
Stanton S -650
Make sure that the "line/phono" switch on the back of the unit is set to "line", or your output signal will sound distorted.
May 22, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
STANTON SK-FIVE MIXER HOOK UP
are the gnds connected(earths) you get a buzzin noise if not earthed
May 15, 2008 | Stanton Sk2f DJ Scratch Mixer - Good...
372 people viewed this question
 Grubhead
Grubhead
