Question about RCA R52WM24 52" HDTV Projection Television
I have a RCA HD 52in and I'm have a problem with the Convergence Ic's
    Scholar:
  • 150 Answers
Hi, rca`s don`t have convergence IC`s, they use an entirely different system to perform convergence, you have a blown chemical fuse and 3-6 bad solder joints on your flyback transformer. replace fl231 chemical fuse rated at 400ma. right beside flyback (theres 3 of them your bad one is the middle one)and while your soldering re-solder all of the flyback transformer pins and your tv will be back to normal :) video-tek
Posted on Jun 05, 2009
I have an rca 60 inch big screen..it just happen to show double vision looks 3d with out the glasses..lol ....sound is all good just the picture..model number..mm61110 chassis number..mmc102g..i love...
Yes it can be fix, first try to adjust the convergence setting in the setting menu then go to convergence section, adjust the red and blue convergence. You should be able to move the red and the blue convergence up, down and left, right but if you cannot move this far enough the convergence IC is defective and should be replaced. This convergence IC is attached to a large aluminum plate, this is the heat sink and the convergence IC has a marking of STK-#### followed by a number, in order to replace this IC you should have a soldering iron, desoldering pump, soldering lead be careful when pulling out the IC you may accidentally tampered or damage the PCB and caused much damage to the unit. Note before opening the back cover of your tv be sure to unplug it first. But if you are not familiar with electronic parts you can contact a service technician to do it for you and save you from stress good day and best regards.
Aug 30, 2011 | RCA D52W23 52" HDTV CRT TV
My screen to my RCA 56" HD TV is messed up. The picture seems to be bowed inward and the colors are all mixed up. I tried to do the convergence but it is not on the menu and I remember it being there...
t is the problem of convergence setting or convergence IC.
Comment by ready2helpu, posted on Oct 21, 2008 IF THE PROBLEM OF CONVERGENCE SETTINGS then check out this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
if the problem of convergence IC THEN check out this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
you can do it manually.
thanks.
Oct 21, 2008 | RCA R52WM24 52" HDTV Projection Television
I have a RCA 52in TV & the picture is arched. Model # is D52W15.
Problem description indicates a convergence alignment issue. Convergence circuirty needs to me replaced.
Jan 19, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Service convergence alignment procedure
Most non-LCD and plasma TVs have to be manually adjusted with special tools that are used to adjust the internal comparator circuits that align your image. It could be a cheap repair job at a shop.
Jun 04, 2010 | RCA F36645 TV
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
RCA D52W23 52in HDTV red and green ghost and bowing lines
Ur convergence it dead,need convergence kit,use what in that kit,U know to solder? Tries websites Tv Repair World.com,Ebay.com
Oct 06, 2009 | RCA D52W23 52" HDTV CRT TV
What is the part # for a rca hd tv convergence ic. model # d52w23 & where is it available .picture concaving ay top & bottom,colour out of whack.
The part number for the convergence ic's are on the ic, they all start out with stk392-??? if it is a 110 thorugh a 150 you can use a stk392-180 to replace the orignal one, if it is a 560 you must use the same stk392-560 ic.
Sep 01, 2009 | RCA D52W23 52" HDTV CRT TV
Rca 52in rear projection hdtv red, blue, and green lines n double
tHIS is a convergence problem.. first question if you go into the customer setup menu. is the convergence option listed? If you have not got that option i suggest you read "the fl231 problem in the tips and trick section of this website. this can be a simple inexpensive repair..if you do have the convergence option then it can be one of three diffrent boards convergence power, convergence amp or small signal board. and will need further trouble shooting
Apr 04, 2009 | RCA Televison & Video
Rear projection tv broke
try resoldering the vertical output IC. This is a common problem the tubes blank out but sound and on screen displays still work 90% of the time its the solder connections on the vertical IC that causes it.
Mar 24, 2008 | RCA P52960 52" Rear Projection Television
Rca 52 hd
convergence ic is out...just repaired it. the 2 ic were 14 dollars on ebay. check resistors too..
Feb 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R52WM24 52" HDTV Projection Television Logo
351 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
