Question about Sony Cameras
LCD cracked, no impact how can this happen
Did your replacement LCD work? Was it pretty easy? I am very skilled at PC repair...
  • 579 Answers
I can replace your 7/7Hi LCD $50 US plus shipping. 68pishta@gmail.com
Posted on Nov 24, 2011
    Sergeant:
  • 246 Answers
Posted on Jun 04, 2009
How to fix a damage screen for a vizio vf550m
Vizio Flat Screen Repair - All - Instructables
www.instructables.com/id/Vizio-Flat-Screen-Repair/
InstructablesWhere can I get a replacement screen for a Vizio 70" that cracked. Model .... Is there a repair to resolve this problem and where do I find information? IMadeIt
Vizio TV cracked how to fix this? - YouTube
? 0:22
https://www.youtube.com/watch?v=d3wSCSfatjQ
Jan 27, 2014 - Uploaded by mario gutierrez
Find out how to repair this? I have the ... Cracked TV Screen - LCD & LED TV Panel Repair Options & Replacement ... VizioFlat Screen Repair.
Dec 10, 2015 | Vizio VF550M 55 in. LCD HDTV
99 jeep cherokee drive line sheered at rear end
well first of all take it easy on the burnouts! ha ha. if you sheared the yoke thats a simple fix, youll just have to replace the pinion seal and the nut might be jammed on there pretty good so your going to need an impact wrench and of course a new yoke. and i would have the driveline checked before re-installing, just because it didnt break doesnt mean its not torqued. once you replace the yoke and pinon seal install the drivline and youre good to go. however if you torqued the pinion gear any its game over bro, and repairing the rear end is going to be beyond your skills. (in order to re set, shim and square the rear end you need to be a skilled mechanic, no guess work, no doing it out of a repair manual) hope this helps, good luck
Mar 08, 2012 | 1999 Jeep Grand Cherokee
Cat knocked evo unto ceramic tile floor. Screen is cracked but also looks like large growing ink splotches on the inside. Is this just screen and LCD
It sounds like not only was the glass screen cracked, but the LCD has been damaged as well. My suggestion is to find a local cell phone repair shop and get it replaced. It should be pretty easy to fix and shouldn't cost too much. Unless of course you have insurance on the phone..if so then just order a new one.
Mar 12, 2011 | Cell Phones
Our daughters HP photosmart M637 camera's display looks like broken glass. She says she did not drop the camera but was scroling through her photos and all of a sudden the display window went blank and...
As you suspect, this simply does not happen unless the LCD panel has had a physical impact. The LCD units are stress tested when manufactured and the odd ones which crack "all of a sudden" would do so within a few months of manufacture and then get replaced under manufacturer's warranty. The broken glass which you see is the cracked LCD unit and it's behind an outer plastic protective cover.
The only way to fix it is to replace the LCD panel, but it's not a DIY job and repairs will cost more than the camera is worth. The M637 will only be about two years old but it was a budget model to start with so it would be cheaper to buy a fully functional used equivalent camera. There are even brand new models of similar or better specification which will be cheaper than a repair.
If the camera works "as is" then it may be better to put up with the fault until the camera no longer works.
Dec 07, 2009 | HP Photosmart M637 digital camera (L2455A)
Large LCD cracked screen from impact, worth repair?
Cost alot to replace LCD screen not worth the money.If u can find it on Ebay bad PCB,and a
good LCD screen is might worth to repair.
Aug 23, 2009 | Televison & Video
I have a cracked lcd screen on my lenovo Y430. i want to open it up and replace with new lcd i just bough. wanted to know if there's any pictorial or video of how to disassemble and put in new lcd screen
Hi, good day sir, well there are pictorials on how to replace the LCD of a laptop on the internet, you may do search using search engines. happy searching.
Jul 16, 2009 | Lenovo IdeaPad Y430-3231U Notebook
Cracked screen
on a 3g iphone the glass/digitizer replacement is pretty easy, definitely much less than replacements of ATT or Apple if you can do it yourself, there are iphone repair guides websites that guide you through the repair step by step, but you should have done something like this before.
Mar 19, 2009 | Apple iPhone (16 GB) Smartphone
Jvc lcd tv
Without seeing the lines in question, it is difficult to say 100%. But, if the panel was cracked, the only remedy is to replace the panel. Given its age (3 months), unless there is specific evidence of impact, I would suggest that the crack may have come from the frame moving with time. Don't waste your time with the local shop. Call JVC directly and indicate that you had no impact on the TV and that the "shop" is trying to not repair it. Verify that the TV has the same problem as when you brought it to the shop.
Dan
Sep 25, 2008 | JVC LT-32X887 32 in. HDTV LCD Television
LCD screen has gone on nokia 2610.. needs replacing. Everything else works fine
Here is a quick guide that will show how to replace the LCD screen. They are only 20 dollers or so on ebay. It is a pretty easy process.
http://www.howtofixmyphone.com/how-to-replace-a-cracked-or-broken-nokia-2610-lcd-screen/179/
Good luck.
Sep 22, 2008 | Cell Phones
Cracked Camera
No easy fix. Pressure or impact is the usual cause of a cracked LCD. Try not to get the black stuff on anything....it's pretty toxic! The screen needs to be replaced (assuming there's no other, internal damage). They are usually in the range of $75 US.
Feb 19, 2008 | Nikon COOLPIX S200 Digital Camera
Cameras Logo
2,831 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
