Back to:
Tags:
Ricoh Aficio AP3800C Laser Printer
Ricoh AP3800C SC385 (by 3 users)
posted by totalfor on Oct 24, 2007
I am receiving the service code number 385 when I turn on the printer.  What does the code refer too?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Hawken, posted on Apr 21, 2008
1: First i got this code, then i replaced the pcu-s and the error was gone.
2: Reboot, no error code. when i tried to print an config page, the printer told me to remove paper, didnt disappear after removing all the paper and reboot...
Any connections?
Comment by Guest, posted on Nov 07, 2007
HELP i have the same fault code
Best Solution
posted on Nov 01, 2007
Helpful (85)
olegan
Rank:Apprentice Apprentice
Rating: 85%, 3 votes
SC385 ID sensor VSG adjustment
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Ricoh AP3800C SC385:
I don't want to Accept this solution
Solution #2
posted on May 14, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
buy a minolta
Thank You!
Solution #3
posted on Nov 16, 2007
Not Rated (0)
Gunslinger
Rank:Master Master
Rating: 87%, 12 votes
The code means the machine is not seeing the correct toner amount on a small test patch it uses for calibrating itself. It will probably need a service call. The one thing you can try is to replace the Black PCU and the Black Developerment unit at the same time.This may get it to recal itself. If its not this then there is not really much a non technical person can do. You can find consumables for these on ebay for about half of what you would pay a dealer. Good luck and if I see you post again I will try and help you.
Thank You!
Can you Help with these Printers problems?
Printers
installing my printer without a disk
I've downloaded the drivers for 64-bit XP, but the...
cannot adjust color the image is not correct...
hello ! My printer Ricoh Aficio AP3800C Laser have a...
I have recently replaced my fusing unit. Upon powerup with...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
