Question about Jenn-Air JGC8536 Gas Cooktop
Cooktop igniter sparks but gas will not light
  • 10,865 Answers
Hello there. i can help you.
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, either repeat the procedure or call a qualified appliance repair technician
Posted on Jun 04, 2009
SOURCE: Viking Gas Cooktop - Ignition sparks continuously when in 'on' position
This is likely caused by either a dirty ignition electrode, a cracked ignition electrode, or a bad spark re-ignition module.
Clean and inspect the six electrodes for cracks, If that doesn't solve it order a new
Ignition module from an internet appliance dealer that carries Viking parts like Appliance Zone.
If you replace the Ignition module yourself, make sure to turn off the circuit breaker to the range/cooktop before you work on it. Also, make a drawing of where the different color leads are plugged into the ignition module before you unplug the wires and plug them into the new re-ignitor. If the unit is under one year, this should be covered under the warranty.
Viking had a recall a few years back on their ignitor modules.
Posted on Oct 27, 2008
  • 110 Answers
SOURCE: Dacor cooktop ignition problem
TAKE THE BURNER CAPS OFF AND CLEAN THEM REALLY WELL AND MAKE SURE THAT THEY R PUT BACK ON PROPERLY THRER ARE GENERALLY A NOTCH THAT HAS TO BE LINED UP JUST RIGHT FOR THE CAPS TO FULLY SEED TO PROMOTE PROPER LITING
Posted on May 30, 2008
Eddie Rentas
  • 59 Answers
SOURCE: MAYTAG GAS COOKTOP IGNITER PROBLEM only 2 igniters spark
Hello
Check and make sure that the electric sending units to the side that it's not sparking ( Left side or Right side) are good, you can check that by replacing the one that works with the one that does not. they are located under the knobs on the switch rod, it's very simple, they just sit there with 2 wires, just lift and unplug the wires and replace with the good ones, and if they start clicking when you turn the knobs, then just replace the bad ones with new ones.
Hope this help
Eddie Rentas
Tupper Lake NY
Posted on Aug 02, 2008
  • 7 Answers
SOURCE: replace dcs gas cooktop re-ignition module
donho1,
most likely the problem is the switch places onto the shaft of the valve. to replace the switch, you would need to remove the burner cap and port rings. you will see a large brass nut that needs to be removed on all 4 or 5 burners. next you would need to remove the nut in the center of the simmer port ring which is also the venturi for the main burner. you must be careful when removing this nut as they have a tendancy to lock onto the jet holder and could be hard to remove (don't strip or break the venturi or holder).....after you remove those nuts, the burners and top can be removed (watch the igniter wires). you can remove the switch by removing the retainer clip that holds the switch onto the valvestem.
Posted on May 28, 2009
heatman101
  • 43501 Answers
SOURCE: GASS COOKTOP-electric ignition sparks continuously w/gas is of
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Apr 23, 2010
One of my igniter in my smeg gas cook top does not spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 30, 2011 | Smeg 23 in. SE64 Gas Cooktop
Cooktop model JPG933BEC2BB right front igniter quit working
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
heatman101
May 12, 2011 | GE 30 in. Profile JGP933 Gas Cooktop
ELECTRONIG IGNITION DOES NOT WORK TO IGNITE THE COOKTOP I HAVE TO USE MATCHES TO IGNITE THE GAS
heatman101
Apr 04, 2011 | Bosch 30 in. NGP74 Gas Cooktop
The igniter doesn't work at all. If I turn any knob to the ignite setting, you can hear the gas coming out but there is no ticking sound, and therefore no ignition. Can I fix this myself?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Sep 03, 2010 | GE 36 in. JGP628 Gas Cooktop
Thermador cooktop won't light it has the ignite
try to clean a little bit the head of the sparkler and push the button for gas a little bit longer
Mar 11, 2010 | Thermador 31 in. SGS304Z Gas Cooktop
New cooktop-1 burner does not light automatic
find the spark module. Follow the spark wires to the module . unplug the one that doesn't work and plug in a working wire. If it sparks it the wire if it doesn't spark change module
May 16, 2009 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Jenn-Air JGC8536 Gas Cooktop Logo
2,987 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
