Question about Sony PlayStation Portable (PSP) Console
Ahimasid asid
Test
Posted on Apr 16, 2008
  • 709 Answers
Hi Off2,
OMG ROFLMO, WTF?
Posted on Oct 27, 2007
4 two tone beeps on startup
Sounds like your memory or video card is the issue. I would try the memory.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 29, 2012 | Intel D865PERL Motherboard
Meening of motherboard beep
The beeps or blinking lights tells the technician what is wrong with the computer. Most times it's a memory or video card issue. If you are getting beeps, try checking your memory.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 24, 2012 | Compaq (261671-001) Motherboard
Continuous beeping noise on boot up
Sounds like you have a bad memory chip or one of the memory slots is bad.
Remove the Power Cord, Remove the battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 02, 2012 | Computers & Internet
Screen not on and alrm sound
Is it a constant alarm? If so you might have a memory problem.
Remove the Power Cord, Remove the screw and the cover that houses the memory and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.If it is like a 3 alarm or beeps interval, then you might have a video card problem.
Apr 15, 2012 | Dell Studio 1555 laptop
Samsung beep codes
I bet you've got a bad memory chip.
Mar 30, 2012 | Samsung R580 PC Notebook
I need to reconnect my radiator in my 2000 ls v8
For 2000 Lincoln LS 3.9L SFI DOHC 8cyl...
Radiator - Removal & Installation
  1. Drain the engine cooling system.
  2. Remove the upper radiator sight shield.
  3. Remove the air cleaner outlet tube.
  4. Remove the six bolts and the two radiator upper support brackets.
  5. Remove the upper radiator hose.
  6. Remove the bolt and position the receiver drier aside.
  7. Disconnect the dual flow coolant valve electrical connector and the A/C line from the fan shroud.
  8. 3.0L engines only:
    Disconnect the Throttle Position (TP) sensor and the Idle Air Control (IAC) valve electrical connectors.
  9. Remove the bolts.
  10. Remove the bracket.
  11. 3.9L engines only:
    Remove the bolt and position the electric water pump aside.
  12. Disconnect the high pressure cooling fan bracket and line.
  13. Inspect the seal and install a new seal if necessary.
  14. Disconnect the return hose from the cooling fan and shroud.
  15. Separate the return hose from the fan shroud and position aside.
  16. Remove the two bolts and the fan shroud assembly.
  17. Remove the A/C condenser.
  18. Remove the two bolts and position the multi-cooler assembly aside.
  19. Remove the bolts and the condenser support brackets.
  20. Remove the radiator.
To install:
  1. Install the following:
    Radiator Condenser support brackets Multi-cooler assembly A/C condenser Fan shroud assembly
  2. Connect the return hose to the fan shroud
  3. Connect the high pressure cooling fan bracket and line.
  4. 3.9L engines only:
    Replace the bolt and position the electric water pump aside.
  5. 3.0L engines only:
    Connect the Throttle Position (TP) sensor and the Idle Air Control (IAC) valve electrical connectors.
  6. Replace the following
    The upper radiator sight shield. The air cleaner outlet tube. The six bolts and the two radiator upper support brackets. The upper radiator hose. The bolt and position the receiver drier aside.
Hope help with this (remember rated and comment this).
Mar 17, 2010 | 2000 Lincoln LS
How do I install a brake booster on a 2003 Ford Expedition Eddie Bauer with no ESC package? Do I need to bleed anything before removing the part?
disconnect the neg batt cable,loosen clamp and disconnect air cleaner outlet tube and resonator from the air cleaner. 2.disconnect maf sensor connector. 3.lift air cleaner assy from tray and position aside. 4. remove screws from power steering resevoir, and position aside. 5.disconnect brake fluid level sensor, and if equiped brake pressure switch. 6.remove the two mounting nuts holding master cylinder, position master cylinder aside (DO NOT LOOSEN LINES ON MASTER CYL). 7.remove mounting bolts for degas bottle and postion aside. 8.if equiped diconnect wiring at the pedal position sensor. 9.relaease clamp and disconnect hose. 10.remove the pin, washer, bushing and switch, disconnect pushrod. 11.remove the nuts and brake booster, to access nuts fold back sound insulation. reverse procedure to install.
Sep 16, 2009 | 2003 Ford Expedition
AOC lm929 monitor
AOC LM929 or Envision EN-7100 removal instructions:
DANGER!!! UNPLUG and allow the monitor to discharge before servicing.
with a small flat head screwdriver, insert into the edge and pop open the small plastic
pieces that surround where the stand connects to the monitor. put plastic pieces aside.
lay monitor on soft flat surface front side DOWN. with a phillips head screwdriver,
remove 4 screws in the center that hold on the stand. put stand and screws aside.
lay monitor on soft flat surface front side UP. insert flat head screwdriver into the
side edge of the grey plastic and turn screw driver so the plastic surrounding the
screen edge pops up exposing an area surrounding the screen. put plastic rectangle
piece aside.
slide out plastic buttons piece from the side and put aside.
with a phillips head screwdriver, remove 8 screws (4 on top and 4 on bottom) that hold
the screen assembly to the back housing. now lift screen assembly out of the plastic
housing. put back plastic housing and screws aside AND lay the monitor screen with the
FRONT side down on a flat soft surface.
with a phillips head screwdriver, remove 2 screws that hold on the metal electronics
cover. slide the cover down and remove. put the cover and screws aside.
USE CAUTION!!! Some components may still contain a charge.
check fuse... whatever...
Aug 29, 2008 | Computers & Internet
Removal of AVG7 antivirus
hmmm... an alternate solution for removing a software asides from going to add/remove prog...
i would definitely use Your Uninstaller Program.
download it here.. link
i recommend using this asides it being very easy to use...it also removes all registry entries after uninstalling any software.
Apr 08, 2008 | Computers & Internet
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
