Question about Dryers
Kenmore 970 C81062 10 Electric Dyer WILL NOT
Kenmore 970 C81062 10 Electric Dyer WILL NOT START.
You can hear a buzzing noise, but the dryer will not start.
My DLG7188RM runs and dries fine. But every 20 minutes or so while it's simply resting (not in use) there is a loud buzzing noise coming from the back of the machine. It lasts about 5 seconds or so and then shuts off.
Can you help me diagnose this problem?
Posted on Feb 17, 2010
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 120 Answers
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Posted on Jun 04, 2009
Buzzing noise from my dyer
You may be experiencing some feedback through a buzzer from the timer. Below is a link that may be of some help.
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
Oct 23, 2017 | KitchenAid KEHS01P Electric Dryer
I have a Kenmore Electric Dryer Model# 110.96551220. When i push the strat button, the dryer does not start but I hear a surging type noise. Any idea what is wrong?
you will need to remove the front panel, unplug dryer, open dyer door remove screws from inside the door frame, with a flat tip screw driver gently pry up as it is clipped and it will pop up, you will need to disconnect the door switch and sit the front panel aside. The top of the dry will lift up, on the motor look for two switches.buttons one is a reset the other is a trip. you will hear a click when you reset it. hopefully this is the problem, if not then see if you can turn the drum, it should be hard to turn but turn all the same. Hope this helps tim
Sep 11, 2010 | Kenmore Dryers
When I press the start button on my Kenmore dyer it make a noise but won't start
if it's a humming or like a buzzing noise it's coming from the motor.try spinning the drum by hand,if it moves freely it could be the motor,if the drum is hard to move you could have something like a sock stuck in the blower wheel or something is jamming up the machine and the motor can't move.also just yesterday i found the belt broke and was rapped around the motor so you'll have to get in there and take a look.good luck,let me know what you find
Jun 27, 2010 | Kenmore 63942 Dryer
Kenmore model 66812694 - quits running, buzzing noise at restart
bad motor,when you hear that noise open the door,hold in the door switch with one hand and with the other spin the drum and have someone else start it while you do this,all your doing is helping the motor start to spin but it sounds like a bad motor,this could be from not cleaning out the dryer,if it's gas it should be done once a year,electric can go another 6 months because there isn't an open flame in there,if you clean out the dryer and vent line the clothes will dry on time,the parts will last longer and you won't have a dryer fire.
Nov 19, 2017 | Kenmore Dryers
Buzzing noise when i turn the timer switch
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 06, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Dyer was grinding, then won't run
Sounds to me like you motor has froze up. Is there any smell coming from the dryer? The fuse would not cause this. A fuse would make the dryer do nothing when you hit the start button.
Nov 21, 2008 | Roper REX4634KQ Electric Dryer
Kenmore dyer
I have a kenmore gas dyer, it will start to dry then go out and just run. you can shunt it dwn resit the timer the time it needs start it and it will lite for a cycle then go out, short burn, then out. is it a senor???? JW
Jun 09, 2008 | Kenmore 62802 Electric Dryer
Kenmore Dyer 65662
check the thermal fuse on the blower housing, remove the back panel and you will see a white fuse with blue wires connected to it it is to the left of the vent tube of the dryer if it shows no contunity then the fuse is bad and needs to be replaced
May 07, 2008 | Kenmore 67082 Electric Dryer
Dryers Logo
1,088 people viewed this question
Top Dryers Experts
