Question about Goodman CLQ36AR49 Air Conditioner
A/C not working - just blowing uncooled air
I have a 2.5 ton Goodman Heat pump, 1.5 years old. When I try to turn on the A/C, all I get is the fan blowing regular air, not cold air. Any ideas what the problem might be?
Also, in the winter, when I turn on the heat, the fan blows unheated air for like 15 minutes before it starts to heat up.
Oh, and I have no idea what, or where, a reverse valve is :-)
Thanks a million!
  • 116 Answers
This is a 3 ton unit it still has parts warranty on it if you look inside the fan area of out door unit the reversing valve has 3 copper lines on one side and 1 on the other fyi when giving call for cooling out door fan running? if no check for fuses in disconnect at unit or breaker off in panel remove panel where power comes to unit pull disconnect look at capacitor silver thing with wires on top if swollen on top bad hope this helps some
Posted on Jun 04, 2009
5 ton goodman package unit
I guess this is a heat pump unit, check the change over valve in the gas circuit, sounds like the solenoid on the valve is burnt out
Mar 24, 2014 | Heating & Cooling
Will not come on but emergence heat works
Check contactor that operates compressor and condenser fan. Does it try to come on when you first turn it on, or just sits there? If it tries to come on, it could be the capacitor.
Jan 25, 2014 | Goodman Manufacturing Goodman GPH1348H41...
My 5 ton Goodman Heat Pump won't go into heat or ac mode. Fan won't turn on. No noise from compressor. System is 1 1/2 yeras old.
Easy: Turn the "fan" switch to on at the thermostat and see if the blower starts. If no start, check breaker at breaker box. Check service disconnect at or near the air handler. With the breaker and/or service disconnect OFF check the 3 or 5 amp fuse inside the top cover in the air handler.
Not so easy: (You must know what you are doing for this part or let an HVAC Tech do it for you) Open thermostat and firmly jump the Y and R terminals to see if you get the compressor to start for no more than 30 seconds. (don't do it more than once.) Jump the G and R terminals to see if you get the blower to start. If so, u have a bad thermostat. If not, check the transformer inside the same cover in air handler for proper voltage. (24V. Make sure you also get 220 on the opposite side of the transformer)
If the blower comes on, but the heat pump doesnt start, open the side cover of the heat pump, with the thermostat on cool, and the temp. setting as low as possible for at least 10 minutes see if the contactor is pulled in. If so, check the capacitor and see if it's blown out. Be super careful these systems operate with 220v and the amperes are enough to kill you if you make a simple mistake.
May 20, 2010 | Goodman CLQ36AR49 Air Conditioner
Its 28 degrees out side and my goodman 3.5 ton heat pump package unit is blowing cold air out of all my regesters
Sounds like the heat pump is not running. Check outside to see if the fan is spinning.
Try moving the thermostat to emergency heat and see if that gives you any heat. If it does, then you have heat until you can get a service technician to locate the problem with the heat pump. It could be a wide range if issues from bad thermostat to bad wiring to bad capacitor.
Jan 07, 2010 | Goodman Heating & Cooling
Goodman 3 ton outside unit fan not blowing
Motor, wiring and/or capacitor. If the sticker on the side of the motor isn't burned off you can get the motor info off that. Model numbers from the motor do little for locating the motor but my help. Best thing to do is get the AC motor specs and look up online (cheapest) or go to a motor shop. The specs you need would be as follows.
Horsepower-Such as 1/4 or 1/3
Voltage-Most likely 240/1 (240vac single phase)
Rotation-CW/CCW looking at the shaft end of the motor
Amps
Frame size
Jul 10, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman heat pump 5 ton power problem
Sound like the outside unit is going to ground or the unit is over amping. Take and shut off the power to the unit and check all of the electrical connection for tightness. Don't forget to check the disconnect wires too since you shut it off at the breaker box. If you have a meter check to see if it''s live before you work on it. If it's all tight then call back the person that did the previous repair and tell them that he obviously missed something and the you feel that it should be a warranty call.
Dec 20, 2008 | Goodman CLQ36AR49 Air Conditioner
1997 Amana 2 or 2.5 ton heat pump, 13 seer - air handler only blows 4-5 min
do you have a totaline t-stat. they and some other brands have a fan recirculation setting in the installers menu.
this is assuming that this happens in addition to the heating or cooling normally
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Goodman CLQ36AR49 Air Conditioner Logo
316 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
