Question about Swift Optics
I would like to know how to dis-assemble an old Swift Vega Binoculars. It is a Nighthawk 7X50, model #788. The inside of the lens need to be cleaned and maybe the mirrors, but I am not sure how to take it apart. I am having difficulty finding out how to remove the large lens to clean the inside and to check out the rest of the inner workings for dust.
  • 26 Answers
The old swift nighthawk is a nice bino, has lasted all these years and is well worth repair ...the problem is if you do it yourself you will only make it worse as there will be more more dust inside than when you started unless you have an air hose to blow off optics after polishing,also once you disturb the optics you will certainly put it out of alignment. have repaired many of these thru the years, actually worked for swift in boston years ago. why mess it up ...larry 5088331232
Posted on Jun 22, 2009
I drop my Nikon action 7x50 in the water lake How can I clean the inside moisture?
The unit need cleaning and repair. Contact any technician. This is not a user repairable work.
Aug 27, 2013 | Nikon Action Binoculars
I need a new compass for tasco 322 BCW waterproof binoculars. Any ideas where I can find one?
Open the battery door, clean all inside with Alcohol & Q-tip. Check that the AG10 or 389 batteries are positive up. Now the compass dial pivots on a shaft. It seems to get caught. Take a strong magnet and rotate it above the compass lying horizontal and spin it until it spins freely. Take it away slowly. Does the compass settle down to accurate heading? If so place back in the top of the model 322BCW observing the glued in marks on the clear window area. Re-screw in, press brass button red LED should light.. If NOT recheck for corrosion. Regards, Don
Jul 03, 2012 | Tasco Optics
The eyepiece lenses have something on the inside. Can they be removed for cleaning?
  1. Carefully clean your binoculars by firstly removing any dirt or dust from the main body and straps using a soft microfibre cloth. Avoid the lenses at this point using any form of cloth on the lenses before removing all dirt and dust particles first could destroy them.
  1. Gently remove all traces of grit, dirt or dust particles from the lenses using a soft lens brush or canned air specifically designed for the purpose.
  1. Waterproof binoculars can be rinsed gently under a tap but be sure to use on lightly running water, avoid high pressure water as it could damage your binoculars.
  1. Gently remove any remaining marks using lens cleaning tools such as a lens pen or lens cleaning fluid and lens tissue. Do not be tempted to use kitchen towel or anything else lying around that is slightly rough and may scratch the surface of the lens, only use a lens pen, lens tissue or a lens cloth. Gently wipe the lens using a circular motion working from the centre of the lens to the outer edge. NEVER apply lens cleaning fluid directly onto the glass (always apply to the cloth) and always ensure that the lens cleaning fluid you are using is recommended for the type of lens coatings that have been applied to your binoculars (Do not use general household glass cleaning products or products designed to clean computer screens or glasses. Such products could destroy the lens coatings of your binoculars if used).
May 15, 2011 | Tasco 7x50 Waterproof w/Imp. Compass...
Theres is a water spot inside my binoculars..please tell how to clean it.. please..i need to repair it asap..i work 4 navy engineering
when you take it apart you will effect the collimation..not something to do yourself...and you will probably scratch the coatings trying to clean...gl........ capecod389@yahoo.com
Dec 13, 2010 | Zeiss Classic B/GA 525505 (7x50) Binocular
Carl Zeiss blc 7x50 binoculars
They were isued to the German army. My father bought a pair from a destitute soldier sitting on the wharf in Hamburg in 1945. I want to sell them now, but dont know what they are worth.
Jan 04, 2010 | Zeiss Optics
I have a Swift model 802, 7X35 binocular. The
at the bottom hindge there is a nut you can remove . then take a long thin screwdriver and take off the screw that holds the eyepiece focus shaft. turn center wheel till eyepiece xbars come off body,carefull not to touch lenses. gl larry@reichinstruments.com
Jun 23, 2009 | Swift Audubon 804ED BWCF Binocular
Steiner Commander Compass not working - possibly low of fluid?
Check this post for lens covers.
http://www.bluewaterweb.com/MarineHardware/Hardware.asp?
Feb 15, 2009 | Steiner Military/Marine 7x35
Fujinon-Mariner WPC-XL Lens Cap replacement
You can order a replacement set at: http://www.bakermarineusa.com/index.php?id=17&cat=38&prod=137
Dec 02, 2008 | Fujinon Mariner WPC-XL Binocular
Optics Logo
697 people viewed this question
Top Swift Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Tom Chichester
Bill Boyd
Are you a Swift Optic Expert? Answer questions, earn points and help others
