Question about Sony KV-35S45 35" TV
Sony kv 35v36, Picture blinks out to black every few seconds. I removed the back in the hopes of finding a adjustment nob. Where is it, what tool do I need to turn it, and is this a fix?
SOURCE: Sony wega model KV-32FS12
Probably a defective horizontal output transformer , also check the horizontal output transistor. Both parts available from tritronicsinc.com
Posted on Jan 28, 2008
SOURCE: Sony KV-32FS120 blinks 4 times
good day.
Have you tried first resoldering the terminals in the circuitry?
Also, try to check for the ABL supply near the flyback. Watch out for the small voltage zener diodes.
response is highly appreciated.
chris
Posted on Mar 28, 2008
SOURCE: Sony Trinitron KV-32fs120 Does Not Turn On
i have a unvirasal remote how do iget the codes for it
Posted on Sep 29, 2008
  • 4234 Answers
SOURCE: Red blinking light, SONY KV-32FS13
The 4 blinks usually mean a vertical deflection problem. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Posted on Oct 02, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: my 32'' sony wega blinks 5 times
The 5 blinks means a problem in the set's AKB (auto kine-bias) circuit. Sony TV's monitor the operation of the picture tube. When some kind of trouble has been detected, the TV blanks the screen and flashes the 5 blink error code. This may be due to problems in the video circuit, a bad picture tube, or adjustments that have changed due to aging of parts. There isn't anything I can suggest you try on your own to fix it. Because several things may cause the problem, and the proper tools and service information needed to troubleshoot, you should refer this repair to a professional.
Posted on Feb 17, 2009
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron XBR 36 in (TV control on Top Middle of set) (set-up / tv/video / vol / channel / power) when set is powered on the standby/stereo light Continuous blinks red once a second, no pausing -...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is exactly as you have described .....after few seconds picture comes slowly & immediately (after few seconds). it gets off only red light blinks............ .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore ..since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally .....GUARANTEE....... vishnuswamy_4.jpg
Jul 24, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
We have a Sony KV-35V36 TV. Will watching TV and the power just went off. We get no power all all anymore. How do you ge the the fuse on this TV.
The fuse is inside the chassis and likely soldered. Unplug the TV, press and hold the power button for 30 seconds, repeat. Plug it back in and see if that has reset it.
Is the outlet good, or did the power outage trip the breaker?
Apr 22, 2011 | Sony KV-35V36 35" TV
On my 36in sony the picture goes in and out..from picture to black back and forth constiantly..im just clue less
a picture that blinks in & out every few seconds then it could be a bad tube.
I know the older models the picture would flash in and out with snow etc. that was a tuner problem.
haven't worked on very many sony wega's, maybe another tech here has a better ans.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony KV-27FS210 won't turn on: 5 blinks
If you have little experience of TV repair then take off back cover of Sony Kv-27FS210 and find Screen Control Knob on flyback transformer, turn that knob slightly CW or CCW and turn on TV to get picture. I think you need to turn ON TV few times to get proper adjustement of screen volts.
Above said procedure is for non-tech person.
(Tech person will adjust screen volts (G2) as per procedure mentioned in service manual with proper tools.)
Jul 28, 2009 | Sony FD Trinitron WEGA KV-27FS210 27" TV
T V blinks to black every few seconds otherwise works fine
Sony put i pic killer circut in there tvs. if the tube was not
giving the proper feed voltage on the guns in
the pic tube it blinks off ,sound good no pic.
if you turn up the brightness
on the flyback transfromer you can
get a little more life out of it ,
Jun 28, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My 32'' sony wega blinks 5 times
Feb 17, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
My tv blinks from regular picture to a black screen continuously.
your tv is on the blink.
remove the back panel of set
on the crt pcb board you will find a wite or black pot.
turn it up or down while set is on this is the G@ voltage ajustment.
you might get 3 monts to a year of extra life from your pictor tube by doing this.
regards,
daniel.
Dec 23, 2008 | Sony KV-32S42 32" TV
SONY WEGA KV27FS120 WON'T TURN ON, LED BLINKS A FEW TIMES
I have a SONY WEGA 3 years old KV-32XL90E and have the same problem the Stand By/Timer light blinks 16 TIMES, pauses and then does it again.The sound is but no picture.
Nov 13, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv 32s42 32 tv
turn up your master screen control on flyback transformer. if when sceen gos black ,the timer light will be blinking. this means your picture tube is week. by turning up the screen control you may give it more time.
Aug 05, 2007 | Sony KV-32S42 32" TV
Sony KV-35S45 35" TV Logo
63 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
