Question about Goodman GMS90703BXA Heater
Leaking water gm100-4 is leaking water from it's side
    Problem Solver:
  • 5 Answers
Furnace not on right pitch or the 2nd heat exchanger is bad or stooped up it may be on open well head gas if so the orfices are wrong
Posted on Sep 26, 2009
  • 1,420 Answers
Sounds like a leak at either the fan motor, condensate hose or tubing going to either the drain or condrnste pump. Open up the unit and with toilet paper, trace where the water is coming.
Posted on Sep 12, 2009
  • 332 Answers
How long have you had the unit,, depending on where you live you might be using your ac in your house and if the installer didn't install the condensate catcher on the flu pipe then you wil have water runing out of the unit, if it is happening all the time then you would need to have a service tech come out that would meen something like the tank or a water line is broken,, but since you said it's coming from the side I would have to say it is condensation
Posted on Jun 29, 2009
  • gary miller
    gary miller Jul 13, 2009
    check the condensate line,, these units have alot of condensation and there is a plug {rubbercap} over the plug,, you may have to install a 3/8 tubing to it and run it over to a drain,,
  • gary miller
    gary miller Aug 01, 2009
    that is for condensation, it should have had a 1/4 inch tube installed to the vent, there is a place for it it has a plastic cap on it,, run the tube to a bucket or a drain, but once you have done this it will stop leaking, if you wouldn't mind after you see this is the solution could you come back and rate this,, thank you
Maytag Wide by Side leaks from the refrigerator side
Hold the door switch in and you should be able to watch it leak.
Sep 10, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Water leaking from outside bottom
the waterline going in the freezer door may have a hole take the kickplate off while looking underneath use the water in door to see if any water is leaking from that tube
Apr 27, 2009 | GE Profile TPX24PBDCC Side by Side...
Leaking water
turn the water off its behind the unit on the wall .
you might have a busted pip in the door but only tech' can fix that ....
Aug 30, 2008 | Kenmore 53082 / 53084 Side by Side...
Water leaks when filter is connected
Does it leak from the back or the front of the appliance ??
Aug 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking
I think this will help..
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Aug 21, 2008 | GALAXY Microsystems 25.4 cu. ft....
Water leaking
I guess it was water from drain lines, or leak from water lines.
Aug 01, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
Feb 11, 2008 | Jenn-Air JCD2389G Side by Side...
Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Apr 04, 2007 | GE GSS20IEP Side by Side Refrigerator
Goodman GMS90703BXA Heater Logo
194 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
