Question about Sony Cyber-shot DSC-N1 Digital Camera
Sand i got some sand in my camera as well... the lens goes out and then in about 5 times then it shuts down...... it only does this sometimes.. it will go months and work fine.. then it acts up....
  • 643 Answers
Use a vacume to **** up most of the grit. DO NOT USE COMPRESED AIR. if the lens is making crunchy noises. basically all the internal gears are done. sony wont touch cams that have been droped in water or sand. try the vacume thouh it has worked before.
Posted on Jun 04, 2009
My zoom will not come out, just clicks trying to come out.
Stuck zoom is the most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
This part can be easily replaced in most cameras.
The following video shows how to open a Nikon Coolpix P80:
http://www.desmontalo.com/?p=277
Apr 29, 2012 | Nikon Coolpix P80 10.1MP Digital Camera...
Lens error.....restart camera. Tried over and over again. Nothing works. HELP!
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god....
thanks.
Apr 11, 2011 | Canon PowerShot SX10 IS Digital Camera
Camera doesnt turn on, it lights up then beeps three times and then shuts down
The camera shuts itself down to protect itself for further damage since it detected a problem. Make sure your battery is fully charged. If yes, then do this little trick. Hold the camera with your right hand with the lens facing the ground. Next, tap the camera's base as you turn ON the camera. This aims to remove any grit of sand or dust stuck in between the camera's base and the side of lense barrel. You may have to do this several times and see it it works.
Please let me know how this goes. Thank you for using FixYa.
Jan 22, 2011 | Samsung L100 Digital Camera
Kodak camera shuts down as soon as it powers up. Lens goes back inside - has sand stuck
Good day,
This is a common problem and sometimes can be fixed.
Please see details on my tip on how to fix this error here:
http://www.fixya.com/support/r7041378-digital_camera_lens_problems
Let me know if my tip was useful for your problem!
Regards
Dec 08, 2010 | Kodak EasyShare M1033 Digital Camera
Camera shuts down when 'zoom lens' is used.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Jun 10, 2010 | Kodak EasyShare C913 Digital Camera
When Turning on the Canon Power Shot A530 the
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Dec 21, 2009 | Canon PowerShot A530 Digital Camera
Samsun sl201 lens will not extend, then camera shuts down
If the camera's lens will not retract out, then eventually shuts down, here is what you try to do.
Hold the camera from your right hand with the lens facing down. Then tap the base of the camera to your left palm while turning the camara on; do this several times until the camera's lens retracts out.
This problem often occur when the camera was taken outdoor or in the beach. Sand or a tiny granule of dirt might got stuck in the base of the lens.
Sep 25, 2009 | Samsung SL201 Digital Camera
Lense error, restart your camera
If i told you to smack it around a bit would ytou believe me?
But that is the fix Canon use to get rid of these errors 98% of the time.
Charge or change the battery, insert it tuen camer on when it goes off smack it hard into your palm a few times and turn it back on.
Just incase there is some dirt/dust stopping the lens from extending blow a can of compressed air around it and give it another few slaps . Sometimes after about 20-30 ngoes of this the camera will jump back into service Believe me it does work nearly all the time Canon charged me $90 to do this trick
Jul 29, 2009 | Canon PowerShot SD850 IS Digital Camera
Nikon Coolpix L4 Lens error
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Dec 08, 2008 | Nikon COOLPIX L18 Digital Camera
After 2 years, erratic behavior.
Lens unit problem. Either imact or sand etc in the lens zooming gearbox area. Maybe uneconomical to repair on this model if new lens unit has to be installed. ( it is shutting off because the lens does not come on line properly and so the shutter and CCD do not come on line... when this happens camera switches off. )
Aug 04, 2007 | Fuji FinePix S3100 Digital Camera
Sony Cyber-shot DSC-N1 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
