Question about Acer AT3220B 32 in. LCD TV
Acer 32 lcd seems to be frozen
It started acting up with not being able to use remote. then gradually got worse and had to reset by unplugging the unit to be able to make it work with satelite and remote. now when we open the unit we have to keep swithing on and off several times until empowering appears but freezes on black screen channel 1.
thanks for any info.
    Problem Solver:
  • 10 Answers
Hi
You will need to visit acer website to see if their is an upgrade for the software some manufacturers do this some dont, it would be a matter of downloading and installing on flash memory card to insert in USB on tv,if not it will have to go into an approved acer service centre
Posted on Jun 04, 2009
AOC envision series 32 inch LCD model Number L32W861
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Oct 31, 2016 | AOC L32W861 32 in. LCD TV
When I move the lid of my laptop the screen messes up
it seems the wire that used to connect between display circuit and motherboard connector has got problem. So please check each wire and also reconnect the connector which connect to the motherboard of your laptop.
Apr 01, 2013 | Compaq Presario Cq-62 15.6 Laptop Lcd Led...
LCD 32lg3000 frozen
Make a hard reset to this set, and try again. To make it a hard reset, unplug the power cord from wall socket, and re-plug it into after 10 minutes or so. This must make it a hard reset. In most cases, this must help.
Jul 18, 2012 | LG Televison & Video
I cannot adjust the brightness on my Acer 5420-5687 laptop. The laptop had frozen so I unplugged it and took out the battery which reset the brightness. I tried using Fn key and holding the either sun...
I'm sorry my friend but seems your LCD monitor having problem. There are three options with your LCD monitor. Option 1: repair your LCD monitor *commonly problems are the LCD inverter*. Option 2: Replace LCD monitor with a new LCD monitor. Option 3: Instead using your dim LCD monitor plug CRT or LCD monitor external serve as your monitor. Have a nice day.
Jan 26, 2011 | Acer Extensa 5420-5687 Notebook
I have a 32 in insignia and a universal remote was used to try and turn channel..it turned the channel once and now its frozen on that channel even the tv remote wont work and the manual buttons on the tv...
Turn your TV off and unplug it for several minutes. Remove the batteries from any remote controls that you use for the TV, press all of their buttons, and install fresh batteries. Reset the TV to factory defaults. The universal remote control should not have caused any damage to the TV. If the problem persists, we recommend that you seek service by calling 1-888-237-8289 in the U.S or 1-866-237-8289 in Canada.
Mar 24, 2010 | Insignia NS-LTDVD19-09 LCD TV
My Samsung Le32r73bd TV has frozen so that I can only watch one channel. I have tried turning it off at the mains. Changing "source" and resetting the remote control but it has not fixed it. Any...
Unplug,replug ur cables,satalites,or telicoms boxes for about an hour or so.Replug these boxes back in let the software upgrade,the tv signal should be back to normal.Tries that,99% will solved this problems u have.
Mar 09, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Screen is frozen and displaying," this is an encrypted channel." I unplugged it for a few hours, turned off and on....what do I do next
hook up your sat/cable box and reset the tuner; place the set into "setup" then: "add channels" the tuner will look for and install active channels
Apr 25, 2009 | iLO 3200 32 in. LCD Television
Picture is frozen
There is a button on the lower part of the remote that is a "freeze" button, it will freeze the picture, or capture a still shot. Try pressing this button to "unfreeze" your picture.
Jan 13, 2009 | Akai LCT3285TA 32 in. LCD Television
Sporadic Discoloration & Distortion
Most of these monitors have a 3 year warrantly. Give them a ring and see if they will exchange it. No harm in trying!
Mar 22, 2008 | Acer AL1912B 19" LCD Monitor
Acer AT3220B 32 in. LCD TV Logo
308 people viewed this question
Top Acer Televison & Video Experts
Rommel Balcita
Martin Murray
Jaime Hernandez
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
