Question about Olympus ? 1030SW Digital Camera
When i turn the camera on it chimes 3 times then shuts off
Whenever I turn on my 1030sw camera it chimes 3 times then shuts itself off.
After a year or so, and not having always rinsed the camera after using in sea water (my bad) the camera got water in it.
The screen is black, it Shimes 4 times and then nothing
The screen should be ok because it came up once (in play mode)
I tried to open the camera to remove any residues i might have found and discovered that one of the frontal screws didn't have a rubber seal on it.
The quality of the screws is very bad and you can very easily damage them, making it impossible to remove them
There was indeed plenty os residue and rust in the inner parts of the camera ...
I think the leak came through the battery / card cover
Once you have some salt deposit in there it just seems to close well but doesn't close well enough to avoid water leaking in
The frontal cover color / varnish started peeling off just 2-3 months after usage in water. Then the cover above the lens came off ...
For a rugged camera it has just too many parts that can come off and compromise waterproof-ness ...
Too expensive for that kind of quality ...
Next time I will buy a regular (good) camera and a casing ...
or are there better quality builds ?
Posted on Jul 14, 2012
  • 4 Answers
Mine is now doing that, have you figured out what was wrong with yours? Mine has never been dropped, so the solution above doens't work for me.
Posted on Jul 30, 2009
Mine was doing the exact same thing. i just fixed it by taking the little silver frame that wraps around the lens off. This may effect the cameras use underwater but atleast it will work above the sea! just peeled it right off and it works perfectly now.... free :]
Posted on Sep 16, 2009
  • 464 Answers
You should have dropped the camrer down at least once. you have to replace the lens array.it costs around 60$.
Posted on Jun 04, 2009
How do I make my clock chime the correct number of times?
whenever the battery is weak the chime changes....whenever you change battery the clock chimes to the last time it chimed so...try setting your clock to next hour of chime n then move the hands of clock to next hour n your clock will chime accordingly.....
in this way waiting for chime to finish ...set to clock to present time ....waiting for it to chime every time the minute hand passes 12
Dec 09, 2015 | Home
Clock Manuals
leave it running when it gets to 12 oclock it wiil reset itself
May 02, 2013 | Watches
Chimes whenever the drivers door is open, even if the key is out. It is also really loud, want to turn the chime down also
My van chimes also with the key out. I think it is a reminder to lock the car as you leave. I don't see any way to reduce the volume.
Sep 07, 2012 | 2002 Buick Rendezvous
Hello, I have a digital camera olympus 1030sw. If I set the camera to flash, there are times that it will flash but most of the time it won't. What would I do to solve the problem?
it would be very hard to say what could be the reason behind this. But however you can check if the battery is charged correctly or you can change the battery cells to see the difference.
Oct 14, 2011 | Olympus ? 1030SW Digital Camera
Olympus 1030sw say card full when it is definitly empty
1. Is there a slide switch on the side of the card? Is it unlocked? 2. Go into your camera's menu and find "reset"...follow the on-screen instructions. 3. Format the card in the camera.
Dec 08, 2009 | Olympus ? 1030SW Digital Camera
My olympus will chime and only come up in the "play mode"
Submerse it in a bowl of water, ensuring everything is closed properly. Then run it under running tap water, not full blast and while doing this under the tap turn it off and on.
I just did this tonight after having the same problem and it worked!
Aug 06, 2009 | Olympus ? 1030SW Digital Camera
I have an olympus mju 1030sw and when i try to take a photo a tone sounds 3 times and it turns itself off. any ideas?
power issue with the battery or the card may be malfuntioning... try taking pics with card out
Sep 18, 2008 | Olympus Cameras
Camera telling me to clean card reader
Hey mursty,
What you most likely need to do is format the memory card as described on page 35 of your camera manual. I have included a link to a PDF download of your camera manual in case you need it. I hope this helps!
http://www.olympusamerica.com/files/Stylus_1030_SW_Instruction_Manual_EN.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Jul 29, 2008 | Cameras
GE simon security system
Depends. Do you mean the chime? If all that is missing is the chime whenever a zone is tripped then simply press the CHIME button on the front panel. If it is lighted solid red then your chime is on and it will talk to you. If chime is off then it wont talk to you at all when a zone is tripped. Good luck.
Mar 09, 2008 | GE Security Simon 3 Wireless Home Security...
Olympus ? 1030SW Digital Camera Logo
498 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
