Question about HP Compaq Presario S5100NX (DM172A#ABA) PC Desktop
My computer(Compaq 5301RSH 5000 SERIES) won't start because "Windows could not start because the following file is missing or corrupt: system32hal.dll. Please re-install a copy of the above file." What can I do to fix it.
  • 297 Answers
Alright..Not a big problem..Generally happens due to some files corrupting. Put your Windows CD in the drive, boot form the Disc and choose to repair the operating system. The problem will be solved.
Thank you!
Sabharish
Posted on Jun 04, 2009
    Problem Solver:
  • 8 Answers
Let me guess, Compaq did not provide you with an original Windows installation disc? Of course not. You can call Compaq and request they send you your restore CD's if you did not get them either. Or, you can shut down your system press the power button an as it is booting press shift F10 and follow the prompts for a system restore. It may require cds, this depends on the level of corruption/destruction state the system is in. There is a reason this file is corrupt or the file system became corrupt. Hope it helps, post for additional help.
Compaq presario c300
Switch the computer off - remove the battery if necessary and wait a couple of minutes. Replace and try restarting.
Jul 28, 2014 | Compaq Computers & Internet
I have an evo n610c and it started up with a message that says, "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair thi
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Feb 15, 2013 | HP Compaq Evo n610c Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
A FILE WINDOWS SYSTEM ROOT 32 IS MISSING OR CORRUPT
Try starting in 'SAFE MODE'.
Click START
Click RUN
Type CMD and press ENTER.
Type 'CHKDSK C: /F' and press ENTER.
If you are prompted to shutdown & restart to run the "check disk", do so.
During the restart, "check disk" will find/repair any file-system problems, and then restart in "normal" mode.
Sep 18, 2009 | Compaq Presario 5000 PC Desktop
Vgaoem.fon
Hello there:
your problem is due to a missing or corrupt file this file is a key file that windows needs to operate.
please try this
Root of the issue
You might come across this error message and this behavior of Windows operating system due to missing or damaged Vgaoem.fon file. This is a key file for Windows operating system, which is required for Windows to boot up.
How to recover inaccessible or lost partitions
Follow the underwritten steps to sort out the issue:
  • Configure your PC to start from CD/DVD
  • Insert XP bootable CD and restart the system
  • Boot the system from CD and press R to start system in Recovery Console
  • At command prompt, type map and press enter
  • Type underwritten line and hit enter: expand CD-ROM drive:\i386\vgaoem.fo_ drive: \windows\system here CD-ROM drive is the drive latter of your CD Drive.
  • Type exit and restart the system.
If your system works properly, then the problem is resolved. In the else case use Partition Recovery Software to recover lost hard drive partitions and data. These tools are particularly designed to effectively scan the affected hard drive and retrieve all of the lost, missing and inaccessible hard drive partitions. These applications are quite easy and safe to use. i hope that this helps
best regards mike
Jul 22, 2009 | Compaq Presario 5000 PC Desktop
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
if you have a windows cd you can do a system restore from it or at the boot screen some computers have a system recovery so you can use system restore without a disk, if you can use system restore, restore your computer to a earlier time and that should solve your problem
How do I restore my Compaq Presario computer to factory settings without the disc as I can't find it!
You first find a Windows installation disk valid for the licence sticker on computer, then download drivers from HP website.
Here driver page for Presario 5000 series :
Compaq Presario 5000 Desktop PC series - Download drivers
Apr 17, 2009 | Compaq Presario 5000 PC Desktop
Windows xp missing file and won't start up
Here's what I would do, because after reading around on that error message, it seems like you can't repair the problem.
I would find myself one of these: http://www.casecooler.com/3drto2dr.html
Take out your laptop's HD, hook it up to that convertor, slave it to a desktop, pull all your data that you don't want to lose to the desktop, put the laptop's HD back into the laptop, reformat/reinstall windows back onto the laptop, pull the HD back out of the laptop, hook it back up to that convertor, slave it back to the desktop, put your data back onto the laptop's HD, then put it back in the laptop.
That will leave you with a clean install that works on the laptop and you won't lose any data.
Nov 12, 2007 | Compaq Presario V4000 Notebook
Having problems with my compaq Persario 2500
this problem occurs when you try to update drivers in the computer..sometimes windows XP cannot update the driver and that corrupts system.ini file as it has a lot of bad entries..Due to this you will get this error mesage..No its not due to virus.its due to an attempt to change system.ini file
That means the System Registry Hive has become corrupted.
There are two ways to get back up and running. The easy way which doesn't always work, and then there is the hard way.
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Oct 11, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
HP Compaq Presario S5100NX (DM172A#ABA) PC Desktop Logo
146 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
