Question about Coleman Powermate 27 Gallon Air Compressor
Coleman powermate 27gal 5hp air supply line and regulater gets very hot and blowes off hose
    Problem Solver:
  • 9 Answers
Is a shroud of any sort been took of ? is there oil in pump assembly ? Is there a fan on this model? At what pressure does the compressor stop pumping (should be less than 135psi aroud120psi) are you using it over it's duty capacity ei:sandblasting....?
Posted on Jun 05, 2009
How to drain gas from a coleman powermate 6250 generator.
easy way would be to pull the fuel line off at the carb and put the hose into a can and open the petcock
Jul 24, 2017 | Coleman Electrical Supplies
Fuel line is clogged
? If it is blocked the only thing to do is completely remove it and blow out with compressed air. Don't do that with it still connected to the carb, or you will damage the carb needle and float assy.
Aug 25, 2012 | Coleman Powermate Powermate 5000W...
My Coleman Powermate 5,000 (6250 surge) CAN drive my big old Sears 5hp 220 compressor, (that's it's job), since there's no 220 in the garage. BUT, there's been a number of time'
What you are describing sounds like a load of bad fuel, the white smoke may be due to that. I suggest you drain and check the fuel, let it settle out and see if any water appears at the bottom of the sample.
May 18, 2012 | Coleman Powermate Portable Generator...
I just seperated the tapered crankshaft from the rotor of my coleman generator ( coleman powermate 2250 with a 5hp briggs and stratton engine). I applied PB blaster, and hit the end bell with a dead blow...
No there is not a key of any sort between the rotor and crankshaft, to verify you will not find a keyway to put one into on the shaft. Just the end bolt with washer holds it on.
Jan 19, 2011 | Coleman Powermate Premium Plus 6250W...
Starts but will not keep running
sounds like you are getting enough gas tostart but not run. check the carberator bowl to see if it has gas in it. make sure your valve to supply gas from the tank is wide open. blow your fuel line back with low air pressure. it is possible you float is stuck up not letting gas flow into the bowl. remember, spark, fuel in, exhaust out. good luck
Sep 02, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5000 with 10 HP Tecumseh engine. It had a float problem and leaked gas out the air filter. I replaced the float and stopped the leak, but now it won't start. It will start if engine...
I have a Coleman Powermate 5000 with 10 HP Tecumseh engine. It is very hard to get started. once started runs great . But when you shut it off and try to restart it it will not start.
I have plenty of fire. I also replace the carb.
I still have problems getting it started. I tried to start it with out the filter also. What can i try next?
Thanks for any help
Jun 18, 2010 | Coleman Powermate Powermate 5000W...
Change from 220v to 110v on air compressor
I can't blame you for askig, but here's my response. 5 HP is 3750 running watts. or about 35 amps at 110 volts and it would take somewhere around 50 amps to start it provided the motor could even be wired for 110 which I don't believe it can and for that exact reason. I'm sorry, but it's just not practical.
May 16, 2009 | Coleman Air Tools & Compressors
I would like to find info on the capacitors for my 27gal powermate air compressor
? should be printed on them careful as they bite when discharging if you need replacement try mastertoolrepair.com they have them
not sure on best way to discharge them hope this helps
Jan 18, 2009 | Coleman Powermate 27 Gallon Air Compressor
Coleman Powermate 27 Gallon Air Compressor Logo
648 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
