Question about Acer ScanPrisa 640P Flatbed Scanner
OS compatibility 1st there was stiaspi.dll file required.then i downloaded it.pasted it in the program.when it disappeared the remaining prob is.."check if the device is properly connected to your computer blah blah"the scanner is plugged, has power and connected to the port, all other ports are empty.so whats the prob?
  • 1,006 Answers
Try in bios and ENABLE ALL PORTS AND install again
Posted on Oct 24, 2007
Getting an error on outlook mapi cant find the msncon.dll file
what version operating system did you install on . most likely it is not compatible with your OS
Jun 28, 2015 | Microsoft Office Outlook 2003 for PC
I cannot install in window7
Unfortunately this is an older scanner and the company has no interest in maintaining the drivers. The support for this scanner is now provided by Benq and they have no drivers past XP. The available drivers are at: http://www.benq.co.uk/support/downloads/downloads.cfm/dtype/D/page/downloads/product/163 .
If you have Win7 32-bit, you can try the compatibility mode. To try this, download the driver and right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties. This may not work. (Since the 64-bit OS requires signed drivers, I don't think it will work for that OS.)
An option that will work is to use a second computer with a supported OS (older version) installed. This can be a physical second computer, a dual boot machine or a virtual computer in your Win7 box. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP driver from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
I hope this helps.
May 19, 2011 | AcerScan 320U Flatbed Scanner
I am trying to install master of orion II on a windows 7 64 bit operating system and it won't open, because DPLAY.dll cannot be found. I have downloaded the driver, put it in the sys32 folder, the...
First install MOO2 on a computer were it runs and copy the entire micropose directory to the program files (x86) directory.
Then copy the dplayx.dll file from the windows\sysWOW64 directory and renamed it dplay.dll and put it back in the sysWOW64 directory (be sure the dplayx.dll file is still there) or if you have the 32 bit version it should be found in the system32 directory (I am guessing, but you will need a dplay.dll)
Found this great post about getting MOO2 to run in Windows 7, and even with the compatibility enabled it still has a graphics palette problem. The reason is because of Windows explorer, and to fix the problem you need to disable explorer.
I know this can be a little too much for some, there is an easier way.
Simply create a notepad file on your desktop, and paste the following.
(If you have 32-bit version of Windows 7.)
TASKKILL /F /IM "explorer.exe"
cd C:\"Program Files"\Microprose\Orion2
start /w C:\"Program Files"\Microprose\Orion2\Orion95.exe
start C:\Windows\explorer.exe
(Copy and paste below if you have 64-bit)
cd C:\"Program Files (x86)"\Microprose\Orion2
start /w C:\"Program Files (x86)"\Microprose\Orion2\Orion95.exe
Make sure you rename the text file to Moo2.bat, then it will launch Moo2 and disable explorer. Moo2 plays perfectly fine this way, even without any of the compatibility enabled.
The Batch file will also restore your explorer when you exit the game.
Alternatively, you could use DosBox to play the game.
Click Here for instructions
Hope this helps,
G33k
May 11, 2011 | Spectrum Holobyte Masters Of Orion 2 -...
I cannot get my i phone 4 to sync with i tunes. It tells me the required disc cannot be found.
This symptom may be caused by an issue with the digital signing of Windows XP drivers. Following the steps below to reregister the several .dll files mentioned below may resolve this issue. Before attempting the steps below, try to restore the iPod using the latest version of iTunes. If you are unable to restore the iPod or if the symptom reappears, follow these steps:
  1. Disconnect the iPod from the computer and close iTunes.
  2. Highlight all of the following 10 lines of text that begin with regsvr32 and then choose Copy from the Edit menu of your web browser: regsvr32 /s softpub.dll
    regsvr32 /s wintrust.dll
    regsvr32 /s dssenh.dll
    regsvr32 /s rsaenh.dll
    regsvr32 /s gpkcsp.dll
    regsvr32 /s sccbase.dll
    regsvr32 /s slbcsp.dll
    regsvr32 /s mssip32.dll
    regsvr32 /s cryptdlg.dll
    regsvr32 /s initpki.dll
  3. Open the Notepad program by navigating to:
    Start > All Programs > Accessories > Notepad
  4. In Notepad, choose Paste from the Edit menu. Note: Make sure that the text that appears in Notepad is the same as what is shown above.
  5. From the File menu, choose Save As.
  6. For File name, type appleipod.bat and save the file to the Desktop.
  7. Close Notepad and locate the appleipod.bat file. It should appear on the Desktop with the icon shown below: ts1539_1.jpg
  8. Double-click the file and you will see a black window appear on the screen for about a minute. Wait until the window automatically disappears and proceed to the next step.
  9. The appleipod.bat file can be deleted at this time.
  10. Open iTunes and connect the iPod.
  11. When the iPod appears in iTunes, restore the iPod and resync your content.
Note: Because some malware may unregister the .dll files, make sure you have the most recent updates to your anti-virus software and then do a full scan of your files.
Solution 2This symptom may also be caused by software applications which change the appearance of Windows XP. Try deleting or removing any third-party Windows OS skins, Windows themes, or desktop mods that are installed to resolve the iTunes Error -50 issue when syncing your iPod to Windows XP.
Mar 05, 2011 | Apple iPhone 3G
At startup iget a error message saying The procedure entry point_ismbcspace could not be located in the dynamic link library MSVCR71.dll
Can you tell me what program your trying to start that gives this error message? Also do you have XP, VISTA or Other?
Try re-installing the problem software.
Try registering the file with start -> run -> type "regsvr32 msvcr71.dll" without quotes, and press OK or enter.
If the problem still remains try downloading this file, the readme file inside has the instructions on what to do with it, then you may want to repeat the start -> run command.
http://www.dll-files.com/dllindex/pop.php?msvcr71
If the problem still remains let me know and answer the questions I've posted for you.
Thanks,
Ekse
Aug 14, 2009 | Office Equipment & Supplies
Driver stiaspi.dll not found
http://www.fix-all-dll-errors.com/stiaspi.dll/
This will fix the issue without any botheration. :)
May 26, 2009 | AcerScan 620P Flatbed Scanner
Files disappeared from maxtor one touch iii mini
Alrighty, I finally found the handy file undelete utility which I have successfully used in the past to undelete files on flash cards. The file is Restoration.exe, and it doesn't use an installer. Thus it is a completely stand-alone program. The author of this program says that it is compatible with all Windows OS through XP. It probably will work with Vista too. The program also is compatible with NTFS as well as FAT32 file systems. Here is a link to CNET.com where you can download it and then use it to try to recover the deleted files on your flash card:
Restoration
Once you have recovered the files on your flash card, copy and paste them to your hard disk. I never do cut and pastes from flash cards for fear of accidentally losing files. Copy and paste, and once you have verified that the files were successfully copied to your hard disk, then delete the files on your flash card if that is your preferred method. Yet I prefer to put the flash card back in my camera and then do a quick format of the card in order to delete all files on the flash card.
Anyway, hopefully this restoration utility will allow you to get those deleted images back. :-)
Apr 13, 2009 | Maxtor 160GB OneTouch III Mini USB 2.0...
Ipod nano chromatic reads error? will not turn on? Nano; 4th Gen;16Gig; When you attach the nano, to the USB port it shows up as a Mass storage unit; transfer music to I tunes and hit the sync button and...
Hi All,
try this out
  4. In Notepad, choose Paste from the Edit menu. Note: make sure that the text that appears in Notepad is the same as what is shown above.
  6. In the File name: field type appleipod.bat and save the file to the Desktop.
Jan 03, 2009 | Apple iPod nano 4th Generation
Acer ScanPrisa 640P Flatbed Scanner Logo
Top Acer Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Marvin
Marvin
syaiful ridlo
syaiful ridlo
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
