The top freezer is working but lower part refrigerator compartment doesn't cool at all even adjusting temperature to Max cooling???
It is like fan doesn;t blow cold air from the freezer
Hello Eddie111,
If you were to remove the rear panel on the inside rear of the freezer you would then be able to gain access to the evaporator coil, If when you gained access to the evaporator coil you then noticed any ice build up on the coil itself this would be called a defrost issue that your unit was having. This is usually due to one of three parts either the defrost thermostat, the defrost heater, or the defrost timer or in some units the adaptive control board would be showing a fault. Would need you to message me back further if you do have a defrost issue with your unit. There is also a small damper door that lets the evaporator fan motor blow cold air into the refrigerator side of the unit this damper door is controled by a thermostat that is found in the ceiling of the unit. Usually attached to the control knob that is located inside the freezer. So first thing to check for is that the fan is working on the inside of the freezer next thing would be if you have the defrost issue on the evaporator coil itself, and lastly you would check the damper door and the thermostat inside the refrigerator side of the unit. If you have any further questions message me back with your reply to the defrost question that I asked previously. Thanks again I await your reply
Rick
