Question about NorStar T7316E Corded Phone
Unable to access "Programming Mode" - NorStar T7316E Corded Phone
  • 1 more comment
  • zonaken Jun 24, 2009
    Yep, that sounds like the deal here.
    I am just a user and apparently outsiders did the phone set up.
    Right now everyone thinks I'm nuts thinking that turning on caller ID can be done, but I know otherwise, just don't have the access. I'll just keep using Fctn-811. Thanks anyway. -ZK
  • Carl Navarro
    Carl Navarro May 11, 2010
    Programming requires an Installer/System Coordinator/Admin login and password. Did you get any of those? What sytsem is the 7316 connected to?
  • 192 Answers
Sounds like you have a BCM telephone system, and the person that programmed the Phone System shut off the set programming feature.
Meaning that the only way to program anything is thru a computer plugged in to the system.
Posted on Jun 20, 2009
  • ynotphone
    ynotphone Jun 26, 2009
    Well actually Caller ID can be enabled on a per-set basis...
    It is a option that needs to be enabled, but their telephone set needs to ring for Caller ID to become active.
Can I program the car to recognixe the key fob.
1996 Roadmaster
  1. Locate the programming connector located in the LH trunk. Trim may have to be pulled back to access programming connector. ( Connector has black/white wires leading up to it and it is not connected to anything.)
  2. Jump programming connector terminals. Leave terminals jumped unitl step 6.
  3. System should now lock and unlock doors to indicate programming mode has been entered.
  4. Press any button on keyless remote once. System should now lock and unlock doors, indicating successful programming of keyless remote.
  5. Repeat step 4 for additional remote or other existing keyless remote. NOTE: A maximum of only two Keyless Remotes can be programmed.
  6. Remove programming connector jumper wire to exit programming mode.
  7. Test remote(s).
Oct 19, 2015 | 1996 Buick Roadmaster
Unable to acces network
Perform a hard reset on your device by pressing and holding your lock screen/power button until your device powers off. If this doesn't solve your problem please set your phone to airplane mode for ten seconds, and then turn it he airplane mode back off. Airplane mode can be accessed through your cell phones settings.
Thanks,
Dish Guy
Apr 07, 2014 | Nokia E Cell Phones
How to program a new remote control for jeep grand cherokee 2002
Programing Sentry keys: 1. Dealer-Programming additional Sentry Keys (requires ONE original key)
In situations where only one key is available, keys must be programmed by the dealer via the Secured Access Method. The Secured Access method applies to all vehicles. This method requires the use of a DRBIIIt scan tool and will also require that you have access to the unique four-digit PIN code that was assigned to the original SKIM. The PIN code must be used to enter the Secured Access Mode in the SKIM. This PIN number may be obtained from the vehicle owner, from the original vehicle invoice, or from the DaimlerChrysler Customer Center. Refer to the appropriate diagnostic information for the proper Secured Access method programming procedures.
2. Self-Programming additional Sentry Keys (requires TWO original keys)
Detailed steps: (1) The first step of course is to acquire a blank transponder key. These can be purchased from your Jeep dealer or bought online. Online prices are usually around $20.00. You can then take the blank key along with one of your original keys to any key maker or locksmith and have it cut to match, just like with any other key.
(2) Insert one of the two valid Sentry Keys into the ignition switch and turn the ignition switch to the On position.
(3) After the ignition switch has been in the On position for longer than three seconds, but no more than fifteen seconds, cycle the ignition switch back to the Off position. Replace the first valid Sentry Key in the ignition switch lock cylinder with the second valid Sentry Key and turn the ignition switch back to the On position. The second valid Sentry Key must be inserted in the lock cylinder within fifteen seconds of removing the first valid key.
(4) About ten seconds after the completion of Step 3, the SKIS indicator in the instrument cluster will start to flash and a single audible chime tone will sound to indicate that the system has entered the Customer Learn programming mode.
(5) Within sixty seconds of entering the Customer Learn programming mode, turn the ignition switch to the Off position, replace the valid Sentry Key with a blank Sentry Key transponder, and turn the ignition switch back to the On position.
(6) About ten seconds after the completion of Step 5, a single audible chime tone will sound and the SKIS indicator will stop flashing, stay on solid for three seconds, then turn off to indicate that the blank Sentry Key has been successfully programmed. The SKIS will immediately exit the Customer Learn programming mode and the vehicle may now be started using the newly programmed valid Sentry Key.
Each of these steps must be repeated and completed in their entirety for each additional Sentry Key that is to be programmed. If the above steps are not completed in the given sequence, or within the allotted time, the SKIS will exit the Customer Learn programming mode and the programming will be unsuccessful. The SKIS will also automatically exit the Customer Learn programming mode if it sees a non-blank Sentry Key transponder when it should see a blank, if it has already programmed eight (8) valid Sentry Keys, or if the ignition switch is turned to the Off position for more than about fifty seconds.
NOTE: If an attempt is made to start the vehicle while in the Customer Learn mode (SKIS indicator flashing), the SKIS will respond as though the vehicle were being started with an invalid key. In other words, the engine will stall after about two seconds of operation
NOTE: Once a Sentry Key has been programmed as a valid key to a vehicle, it cannot be programmed as a valid key for use on any other vehicle.
From WJ's Forum: http://www.wjjeeps.com/sentry.htm
Hope helped (remember rated this help) Good luck.
Nov 02, 2009 | 2002 Jeep Grand Cherokee
1999 Chrysler Town and Country
Have you you tried just re-programming all of your remotes? I just added a "new" (from Ebay) remote and when re-programming, had to do them all. Here's how... 1. Using a functional key fob transmitter, unlock the vehicle and disarm the Vehicle Theft Security System. 2. Insert ignition key into the ignition switch. 3. Turn the ignition switch to RUN position without starting engine. 4. Using a functional key fob transmitter, press and hold the UNLOCK button for a minimum four seconds (maximum ten seconds) 5. While holding UNLOCK button, and before ten seconds passes, press and release the PANIC button. A single chime will sound to verify that the RKE module is set to receive the new Vehicle Access Code(s) 6. Within 30 seconds of the chime, press and release the "LOCK" and "UNLOCK" buttons on the transmitter at the same time. Then press any one of the buttons. The BCM will sound an abbreviated chime to acknowledge that the programming of the transmitter has been completed and was successful. 7. Repeat step 6 for all transmitters that will be used with this vehicle (up to 4 total) 8. Programming mode will last for 30 seconds. To get out of programming mode sooner, turn the ignition OFF. A single chime will sound to verify that the RKE module will no longer accept additional Vehicle Access Code(s) 9. When Vehicle Access Code(s) programming is complete, turn the ignition switch to the OFF position and verify RKE system operation using each key fob
Aug 03, 2009 | 1999 Chrysler Town & Country
Unable to connect
Probably not configured for web access and multimedia messaging... refer to the network provider for programming update if you want these services.
Apr 20, 2009 | LG ALLTEL AX275 Cellular Phone
Cannot access System Programming Mode
You need to get the ''installer code'' in order to get deeper into programming.
Thanks,
lucus123
Feb 15, 2009 | GE Security Simon 3 Wireless Home Security...
Help Request
Do you have any programming experience on your system ? Is seems like the line has to be asigned to the phone it is ringing on but you will have to do that in system programming.
Jul 28, 2008 | Lands Phones
Unable to get hold of unlock codes for Game Programming Starter Kit
What package? Cannot give advice without info. Comment back if not solved yet. Tango
Feb 07, 2008 | Pearson Software Game Programming Starter...
X-keys and Window XP SP2 x64 (64-bit)
Hi guys,
Unfortunately programming in Memory Resident Mode on Vista will not be supported, however if you program your unit on an XP or 2000 machine first you will be able to “run” your unit on Vista.
Because we are unable to program in Memory Resident Mode in a Vista environment we are currently moving to new firmware called MWII which supports a mode called Boot Mode. Boot Mode is very similar to Memory Resident Mode in that when operating in Boot Mode all of your X-keys device's macros are stored in the X-keys device's internal memory. Our MacroWorks II software is required to write programming to an X-keys device operating in Boot Mode or to read programming from that device.
I apologize for the inconvenience this will cause. If you have any questions for me please email me at: Roccol@piengineering.com
Sep 28, 2007 | P.I. Engineering X-keys Destkop Keyboard
Night Mode
This is all done in system programming for the system. You most likely have an installation company that handles changes and additions to the system and programming. Otherwise you would need to gain access to a programming manual (not a user guide) for the phone system itself (not your phone) Programming these is not simple especially for someone who has never done it.
Oct 18, 2006 | Panasonic VB-43223 Corded Phone
NorStar T7316E Corded Phone Logo
183 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
