Question about Sony PS-LX250H Turntable
How do you put the belt back on my sony pslx250h.b?
  • 141 Answers
Its simple the belt goes around the platter and the motor spindle, thats it!
Posted on Jun 05, 2009
How to install belt 4-215-492-01
Take off the felt and the platter. Take some lint free cloth and rubbing alcohol and rub down the pulley. You can also use compressed air to dry it off. Also use the same method to clean and dry the underside of the platter. Put the belt around the ridge on the underside of the platter. Put the platter back on the turntable. Reach inside the access window on the platter and grab the belt. Hook the belt around the pulley. Rotate the platter to make sure it won't fall off. Put the felt back on and you are ready to go!
Jul 03, 2012 | Sony PS-LX250H Turntable
I received a SONY PS-LX250H turntable with the drive belt off. Where do I route the drive belt to get it back on?
The Operating and Install Guides are here...
http://www.retrevo.com/support/Sony-PS-LX250H-Turntables-manual/id/752ag608/t/2/
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C310321&fes=true&mdl=PSLX250H
Follow this procedure to install the belt on the turntable.
  1. Lift up on the dust cover [FIG. 1] and remove it from the turntable base [FIG. 1].
  2. Remove the rubber mat [FIG. 1] from the platter [FIG. 1].
  3. Lift the platter straight up off the spindle [FIG. 1].
  4. Slip the drive belt around the under side of the platter [FIG. 2]. IMPORTANT: Line up the ribbon that is attached to the belt with the square opening near the edge of the platter .
  5. Place the platter back on the spindle .
  6. Spin the platter so the square opening on the platter is over the motor pulley [FIG. 1].
  7. Stretch the drive belt [FIG. 3] over the motor pulley by pulling the attached ribbon [FIG. 3].
  8. Remove the ribbon from the drive belt .
  9. Reinstall the rubber mat and the dust cover .
Jan 29, 2011 | Sony PS-LX250H Turntable
My sony pslx250h turnable belt was ordered and i can't find the repair book to repair it.
Pretty simple fix. Remove the mat, remove the turntable, install new belt on bottom of turntable hub. Place turntable back onto spindle. rotate turntable so you can see motor pulley. Stretch the belt from turntable hub over motor pulley, replace mat, enjoy.
Nov 08, 2010 | Sony PS-LX250H Turntable
I have the sony record player above, and when I was moving I put it on its side and the belt came off. Now I cant figure out how to put it back on. Help ?
The Operating Instructions link on this page:
http://esupport.sony.com/US/perl/model-documents.pl?region_id=1&mdl=PS-LX250H
appears to give guidance on connecting the belt. Any use?
Oct 13, 2010 | Sony PS-LX250H Turntable
The belt fell of the gears on my turntable.
Hi dont know the model but normally like so:
Take the platter of the turntable, it should just lift of, but there could be a circlip in the middle that needs to come off first. Just lift the mat first.
Place the belt back onto the platter first, should see where it goes, then put the platter back on. There are holes in the paltter which you can then grab the belt and pull it over the motor spindle.
Hope that helps
Jul 27, 2009 | Sony PS-LX250H Turntable
Sony pslx250h
Did the problem exist on its own uncorrelated to anything you may have done?
Does it return and cycle itself off or is it just rebounding aimlessly?
Unfortunately, there are no user adjustments for tracking, antiskate, end-of-play-return, etc. The only recommendation from the manual is to make sure the turntable is level and the records are clean and unscratched.
Mar 19, 2009 | Sony PS-LX250H Turntable
Needle replacement...missing part?
To replace the stylus (N-6516 from your Sony dealer)
1.Turn off the amplifier
2. Protect the stylus with the stylus cover (it flips down 90 degrees)
3. Grasp the stylus holder (exposed when cover was flipped down) and pull it away from the cartridge body
4. Insert the stylus by pushing it in to the cartridge receptacle. Flip the stylus protector up.
Nov 24, 2008 | Sony PS-LX250H Turntable
Drive belt on Sony turntable
Usually, for most turntables, the belt goes on the bottom of the platter first. Then you put the platter back on the turntable. From here you should see an opening on the platter where you can 'grab' the belt. Pinch the belt, and then wrap it around the rotating motor's shaft. This is usually at the top left side - around the 10 o'clock position.
- OPTiC
Turntable Technician
www.1200s.com
Sep 07, 2008 | Sony PS-LX250H Turntable
Sony PS-LX250H Turntable Logo
280 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
