Question about Jensen VM9510 Car DVD Player
I bought a UV8 DVD player for the car, please help me
I bought a DVD player for the car and I connected the pink cable to the ground to test it, but it doesn't work. The screen is still blue. What can I do?
  • Anonymous Nov 29, 2007
    i have a uv8 but it doesnt work . the screen stays blue , the dvd doesnt work
Go to radio mode het setup press 543210 hold 0 until the secret menu comes up then you can bypass the problem
Posted on Jan 02, 2008
Ground it for two seconds, disconnect, then reground it. Worked for me.
Posted on Nov 03, 2007
Just bought jensen uv8 touch screen and installed speaker wires will produce no sound except for sub input on rca please help?
it could be a case while you or someone installing the unit could or might have blown out the speaker output of the unit
try taking the unit out connect the red(acc wire) yellow(constant wire) together connect the black(ground wire)
get a test speaker and see if u get sounds
Jan 26, 2010 | Jensen VM9510 Car DVD Player
How do i get my phaser linear uv8 to come on.
Check to make sure you are connecting Power (+) to positive (red) and ground (-) negative (black).
Jun 30, 2009 | Jensen VM9510 Car DVD Player
Parking Break Override
Simple if you don't know where to ground the wire to, just ground it with the ground wire of the radio. Twist the pink and black wires together, then put them with the black ground comming from the car. Hope this helps.
Jan 12, 2009 | Audiovox Televison & Video
Jensens UV9 By pass the brake
hook up the ground with the pink and when you are in am/fm mode hit the dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure it beeps after every no. has been pressed. then it should bring up the hidden menu select the hammer option and turn on the brake bypass option. your done.
i took this from the uv8 brake bypass. it works on the uv9.
Nov 12, 2008 | Car Audio & Video
Uv8 problem!!!! please help
Ipod controls usually go to the cd changer input or auxiliary input. They might have just updated the the looks but usually the inside is the same, especially if they have the same model number. By the way you can get that ipod cable really cheap on ebay.
May 21, 2008 | Jensen VM9510 Car DVD Player
Uv8
For anyone wanting to play dvd's while driving...Wire the brake directly to the ground wire. Simply as that!!!
Mar 15, 2008 | Jensen VM9510 Car DVD Player
Phase linear uv8 parking brake problem
for the uv8 to bypass the parking brake to watch dvds you have to take the pink wire and put one end to one of the screws on a two screw toggle switch connect the other end of the pink wire to the other screw and connect that to the black ground wire
Mar 12, 2008 | Phase Linear UDV9010 Car DVD Player
Phase Linear UV8
go to setup hit 543210 but hold 0 then turn the bake override on and then hit the X
Dec 11, 2007 | Jensen VM9510 Car DVD Player
How can I watch video in my UV8
no wire it to a switch and you have to flip the switch twice and leave on
Dec 10, 2007 | Jensen VM9510 Car DVD Player
Jensen uv8 help
The green with white is for the back up camera option, if you dont have a camera dont hook it up. If you use th remote when in the dvd mode press setup on the remote, then enter 5 4 3 2 1 0 (with the numbered keys) then holding 0 for 4 seconds, this will take you into a screen where you can shut off the parking brake overide. Now you dont have to hook up the pink wire.
Nov 25, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
