Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My riding mower blows fuses once you turn the key.
I have a Craftsmen 17,5hp briggs 42in deck model # 917.272673 riding mower after installing another engine, the fuse blows once you turn the key. battery is good engine is b/c i can put direct current to the starter and it wil turn over and fire also with starter fluid sprayed in the carb. replaced the key switch, battery, and cleaned the seat switch connections. oh also bypassed the seat switch. i would also loved to know where can i find a wiring diagram for this mower.
  • Brad Rabon Jun 04, 2009
    yes blows right away evens blows a 30amp fuse. your solution is possible i will check to finally found wiring diagram.
  • Brad Rabon Jun 11, 2009
    found problem turns out the stator under the flywheel had a broke copper wire replaced it and it fix the problem. thanks for all the help.
  • 106 Answers
Sounds like you are on the right path, maybe some wires on the ignition were replaced backward, and you are sending +12v directly to ground? Does it blow right away?
Posted on Jun 04, 2009
  • 475 Answers
As soon as you turn the key the fuse blows check the head light wires they get cought in the exhaust & that can cause it because you turn the key once the lights are on turn it again & starts engine try that
Posted on Jun 05, 2009
You don't answere anythimg
Posted on May 14, 2013
Can i replace an ariens 46in mowing deck with a 42in deck
as long as the mounting hardware is the same. and you will have to use a different belt
Oct 28, 2014 | Ariens 46in Lawn Tractor 22hp Briggs ES
Craftsman 21 hp 42in.deck model nimber 944.600110 white smoke
check the oil if it smells like gas change the needle valve and seat in the carb and change the oil
May 17, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Need a manual for poulan pro tractor 42in 17.5hp model number is 960120110
Go to www.managemylife.com and get your free manual. Poulan and Craftsman are same. Built by company too.
Mar 03, 2012 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Blades will not disengage
the brakes on the deck belt not working belt to tight or deck not fully disengaging
Jun 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
KEEPS BLOWING FUSE ON CRAFTMAN 19.5 BRIGGS, WHEN TURN KEY TO START
In my experience, and i have a good bit, when you turn the key and it always blows the fuse, the magnets under the flywheel are in direct contact with the stator (alternator). Both will need to be replaced...sorry
Apr 23, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blowing fuse
youve got a short in the wireing ,prob right at the clutch peddle switch
Mar 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,615 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
