Question about AEG Dishwashers
AEG Dishwasher FAVORIT 3A Error Message C3
Some cardboard left in washer accidently and C3 fault code displayed.
Unblocked filter but pump kept going.Only way to stop was by switching
off at mains.
Manual states that ' leak prevention system has been triggered'
Suggested remedy close the tap and contact your local AEG Service Force Centre.I have done this
Can I repair this without specialist help?
  • david-olsen Jan 03, 2008
    I've poured in water from a cup to start machine, but still miss solution on C3 error.
  • Bart Kanters
    Bart Kanters Aug 27, 2018
    Just empty the machine, hold it on its side and let the water run out that worked with mine
If you open a sidepanel and look at the bottom of the machine you see a brown device with a piece of white foam,this is the leak prevention system.
Push foam down and the error code should be cleared.
Make sure you there's no water left on the bottom of machine
Posted on Mar 05, 2009
AEG dishwasher Favorit 86450I displays error code AL7.What does it mean?
i was looking up some info about your dishwasher and this problem might be part of the control board or the pump not turning on in the dishwasher however if one is tech savy you can actually get a ardino board to run the dishwasher (seen on youtube)
Feb 23, 2017 | AEG Dishwashers
I have a oko favorit 4071 doesnt start and display H8 error.
I think this is not the error code. I belive this is hardness of water (could be set from 0 or 1 to 10, depending of model. Read your user manual how to exit the program for adjust the water hardness).
Error code for your appliance depending on model and look like:
i10, i20,i30............ or
C1, C2,C3.............
Dado
Jul 06, 2015 | AEG Dishwashers
AEG Favorit 60870 Dishwasher not starting
Matthew, in most cases when a circuit board repeats the same action over and over, there was a short and loss of communication with associated controllers. Obviously you have power to the control unit, so that means the instructions from the controller to the solenoids is lacking. You are correct in assuming the board needs replacement, however you must determine is the cost for replacement is worth the time and effort. An old machine means one repair after the other. If its relatively new; then it may be worth it.
Mar 10, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Error c3
http://www.aeg.co.uk/Support/Troubleshooter/?Command=Detail&CatId=98&SymptomId=1412&DetailId=1412shows AEG's meaning for a C3 error code
Feb 06, 2013 | AEG Washing Machines
Aeg sensorlogic 50700 first showed c2 message; we drained & cleaned filters 3 times; worked half cycle and now showing error message c3?
Error message C3 is most likely indicating the flood switch is triggered. This means water is leaking from under the sump. The C2 error is linked to drain problems which you cleared.
Dec 29, 2010 | AEG Dishwashers
Aeg 60800 dishwasher showing c2 on panel,water still in bottom of dishwasher. will not start.
from other forum
Not pumping or pumping too slow. Check for blockages in pipework, filter and pump. If all clear, replace pump.
Curing the fault on these machines doesn't always get rid of the error code though. Some faults are locked in.
If you find this, post back and I'll try to help.
Mar 11, 2010 | AEG 24 in. Favorit 60800 Free-standing...
Favorit 43070 vi leak
I assume that this leak is from the flat tank on the side of the machiene. Any water leak to the bottom of the machiene puts the washer in ANTI FLOOD mode with the pump out motor activated. You can remove the flat tank by disconnecting the hoses to it and pulling it upwards. If you find a small leak just run it over with a hot soldering iron to melt closed the small leak. Also note that this tank has a small outlet pipe that deliberatly discharges water to the anti flood device (polystireen float / micro switch at the base of washer) in case of a fault (blocked pipe / leak etc).
Jun 07, 2009 | AEG 23 in. Favorit 44070Vi Built-in...
AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
Feb 02, 2009 | AEG 24 in. Favorit 3A Free-standing...
AEG OKO-FAVORIT 50800
C3 error means that there is water at the bottom of the dishwasher. Unplug the dishwasher, slide it forwards and push it back. So it stands on the 2 back knobs. Do this atleast at a anle of 45 degrees. You will see water flowing at the floor.
If this happens often you have a leak somewhere. Time to cal the technician then.
Mar 03, 2008 | AEG Dishwashers
Dishwasher fail on C3 (leak prevention system)
http://www.kunnig-elektro.de/reparatur/spuelen/aeg/zulauf2.html
in German ... anyway a couple of pictures :)
Dec 15, 2007 | AEG 24 in. Favorit 50730W Free-standing...
Dishwashers Logo
4,667 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
