Question about aBABY.com Baby Gear
How to set up time &date,cannot do thru the manual,
Sorry, no I don"t, I clicked strollers instead of G.E. Phones- cannot set up time & date thru manual,Thanks, Grace
Posted on Jun 04, 2009
I cannot reset time and date on my samsung z2
Want to set the date and time for your mobile phone? Follow these easy instructions.
From a Home screen, tap the Arrow icon to display all apps.
  1. Navigate: Settings > Date & time.
  2. To use network-provided values, turn on the following:
    • Automatic date & time
    • Automatic time zone
  3. When manually setting data & time, perform the following:
    Automatic date & time and Automatic time zone settings must be turned off to manually adjust date and time.
    1. Tap Set date.
    2. Adjust the date then tap OK.
    3. Tap Set time.
    4. Adjust the time then tap OK.
    5. Tap Select time zone then select a time zone.
  4. If desired, tap Use 24-hour format to turn on or off .
May 23, 2018 | Samsung Cameras
How do reset the time
  1. From a home screen, select Apps (located in the lower-right).
  2. Select Settings.
  3. If applicable, select System (appears in Starter mode only).
  4. From the SYSTEM section, select Date & time.
  5. To use network-provided values, select the following:
    Enabled when a check mark is present.
  6. If not using network-provided values, perform the following to adjust date & time manually:
    1. Select Set date.
    2. Adjust the date then select Set.
    3. Select Set time.
    4. Adjust the time then select Set.
    5. Select Select time zone.
    6. Select the time zone.
  7. Select Use 24-hour format to enable of disable.
  8. To change the date format:
    1. Select Choose date format.
    2. Select one of the following:
      • Regional (6/7/2013)
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
Date and Time Settings Pantech Marauder
Nov 01, 2015 | Pantech Cell Phones
How do i set the time on a pantech p5000?
Date and Time Settings - Pantech Marauderâ„¢ [Device-Specific Instructions]
  2. Select Settings.
    1. Select Set date.
    3. Select Set time.
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
How to set time & date on sony handycam HDR-CX240
From manual: To set the date and time, select MENU -> Setup -> Clock Settings -> Date & Time Settings.
Jul 16, 2014 | Sony HDR-CX240 Full HD Handycam Camcorder...
Set screen date/time in kodak easy share
Hello There!,
I think I can help you :-)
Here is the link for the user manual
http://gdlp01.c-wss.com/gds/7/0300001857/01/PSA480_CUG_EN.pdf
On page 16 it explains two ways to set date & Time.
1st is when you turn on the power it will ask you to set the time & date, and you can enter it.
2nd way to set time & date, or change it is to press the MENU key, and select "Set Date & Time".
I hope this helps you.
Please also giving me a good rating for offering you help, :-)
Thanks,
Sep 17, 2011 | Canon PowerShot A480 Digital Camera
How do change time by one hour say 2.30 to 3.30 7020 phone
Select Menu > Settings > Date and time. To set the date and time, select Date & time settings. To set the formats for date and time, select Date & time format. To set the phone to update the time and date automatically according to the current timezone.
You can get more help from downloading the manual from Nokia at http://nds1.nokia.com/phones/files/guides/Nokia_7020_UG_en.pdf
Mar 13, 2011 | Nokia Cell Phones
How do I set the time date stamp
• Setting Date & Time Use the Date & Time function to set the date and time of your camera. This function is useful attaching date stamps on captured images. Your camera uses a 12-hour time format. 1. Press the navigation controls to adjust date and time value. By holding down the up arrow or down arrow keys, the numeric values change continuously. 2. Press OK to apply changes.
or you can get help from manual here
https://images-na.ssl-images-amazon.com/images/G/01/00/00/10/67/62/13/1067621330.pdf
at page 73
Good Luck
Jan 09, 2011 | Polaroid i1437 Digital Camera
I need to change the date on my watch and don't have the instruction manual. Thanks!
mcdevito75 here, Sounds like you have the time set, but the date is a fifferent matter, Here"s what to do, the stem (winder) of your watch has 2 positions, slip a fingernail just under the stem, and gently lift the stem to it;'s first position, this position allows you to change the date without so many cycles of the entire watch, it"s a little tricky but you"ll get used to it. Once you get this first position set the date to 1 day before the date you want, now pull the stem out to set the time of day, go thru 1, 24 hour cycle to set the date you want and time of day. The date is now set and will change on time, approx. Mid nite. Hope this helps.
Aug 03, 2010 | Watches
Current time and date samsung tocco lite
On the main menu select Settings, then Time & Date.
Set Time zone updating to Manual.
Then SCROLL down i.e. drag the menu upwards (this is the bit that many don't realise.)
Then you will be able to set the time & date.
Sep 20, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Using my memory card, i check my photos display with out date & time.
You will find a setting that will date/time stamp the actual image when it's taken. Please take a look in your manual. Most cameras have this feature.
May 09, 2009 | Sony Cybershot S650 Digital Camera
Baby Gear Logo
32 people viewed this question
Top aBABY.com Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you an aBABY.com Baby Gear Expert? Answer questions, earn points and help others
