Question about IBM ThinkPad R51 Notebook
Dim LCD with a IBM R51
I tried replacing the LCD, LCD cable and the LCD inverter. All of which did not fix the problem. I as well can see the image on the screen with a bright light on it. I believe that the only other possible replacement can be replacing the planar (motherboard) Other that that does anyone have any idea what the problem can be?
Thanks
  • 197 Answers
Try updating your video driver. Also, try connecting your machine to external monitor and see if there's a display if not i then confirmed that you planar is faulty.
Note: If machine is under warranty no need to pay for the repairs.
Posted on Jun 04, 2009
Laptop ibm t60 screen white, but works fine with external lcd screen connected by VGA cable
Check your laptop's LCD connections. One of the below items may need replacement or you may need to just reinsert them, might be loose.
- LCD cable
- LCD inverter
- LCD itself
NOTE: Most often, the LCD inverter is the culprit.
Hope this helps.
Jun 25, 2011 | IBM 92P6569 DVD/CD-RW for ThinkPad R50,...
I have an R51 1836-Q6U. When I turn on the laptop I get a series of screens that show scrambled patterns (these are not the test patterns one would normally see during a bios check of an lcd) they are more...
You should try connecting an external monitor. If it shows nothing at all or a scrambled image or it does load to Windows but won't let you change the resolution or the color space, your graphics chip most probably got overheated and de-soldered itself. There is no easy fix. This would involve taking the laptop apart and either heating the GPU (which would end up being a temporary fix) or sending of the motherboard to professionals who specialize in GPU re-soldering.
Jul 02, 2017 | IBM ThinkPad R51 Notebook
My monitor doesnot run
Try an external monitor to verify if the laptop is working just fine.
If you get a clear picture on the external monitor, see if the laptop LCD is dim, or has no image at all.
If dim, you will need to replace the backlight or inverter.
If there is no image at all on the LCD, see if there's a small microswitch at the base of the LCD, this microswitch turns of the LCD assembly when the lid is closed. Usually these microswitches can easily get stuck due to dust and dew. You'll have to wigle it out with a toothpick or similar pointy object.
If there is no microswitch, perhaps it may be that the LCD cable is loose and is out of its socket, and you'll need to open up the laptop and re-seat a long (about an inch) rectangular-shaped connector leading from the motherboard into the LCD assembly.
Jan 02, 2011 | IBM LCD Panel, 14.1-in. XGA TP R50/p, R51,...
Lcd is very dim. after changing res a glow in the lower right corner starts then back to darkness. It works fine with my vga monitor.
Hi, display DIM cause by LCD or inverter Board (brightness controller). Might costly. Up to you either want to change it or not.
And using external monitor is best solution, I think so. =)
May 08, 2010 | IBM ThinkPad R51 Notebook
My screen has gone dim on my ibm thinkpad r50e, when trying to boot just kept goin in circles wouldnt load windows, so have restored factory defaults! but screen still dim? can you help please
if the screen is dim and the images still display it means that the it's probably the CCFL tube or the inverter (located in lcd panel) it will need to be replaced.
Mar 06, 2010 | IBM ThinkPad R50e Notebook
My IBM R51 LCD is dim 2" from the right side
The fault is most likely a faulty CCFL lamp.
For service, parts and DIY info check out LCD Parts WEB site - click on this link :-
www.lcdparts.net
Dec 28, 2009 | IBM ThinkPad R51 Notebook
Dim screen
Your LCD has a small problem its cold soldering. Its a factory depict try to fix its on electronic shop...
Aug 08, 2009 | Dell Computers & Internet
Ibm laptop 2647 series23 the power is on no monitor screen lite
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 04, 2009 | IBM ThinkPad T20 2647 Notebook
Screen goes fuzzy after 45 minutes
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Mar 27, 2009 | IBM ThinkPad R51 Notebook
IBM T40 Laptop screen goes black, will not come back
First of all, you have to check whether you can see video signal with surrounding light tilting the screen.
If you can see dim image, all you have to do is replace back-light inverter or fix it. Usually, the fuse is open and you can connect it by simple soldering.
If you can't see dim image, it is another problems.
Give it a try.
Dec 09, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad R51 Notebook Logo
179 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
