Hitachi 42EDT41 42 in. HDTV-Ready Plasma Television
Problem for Hitachi 42EDT41 42 in. HDTV-Ready Plasma Television
I have green specks in my black areas when movement occurs. Does anyone know of a resolution of the pro...
By iameagle on Oct 24, 2007
I have green specks in my black areas when movement occurs. Does anyone know of a resolution of the problem?
Same Problem
Oct 22, 2008
-   green dots, in parallel lines, all across my Acer 22" monitor -   Guest
Feb 17, 2008
-   yes I have had the same problem but, in my case the specks were throughout the t.v. screen at start up then completly disapear after a while, now my screen is full of rainbow color vertical lines and finally no color-   schrag74
Nov 26, 2007
-   What does it mean if there are green speckles when you start the tv visible only in dark scenes and after the tv warms the go away? I that the same voltage problem on the board that can be adjusted?-   jas44
Nov 19, 2007
-   I have the green dots in the dark background that flash. Is this an expensive repair and can it be done in the home?-   makai
Best Solution
posted on Oct 24, 2007
Very Helpful)
tvtechnician
Rank: Guru
Rating: 88%, 120 votes
you will need a technician service the y sustain board. the tech will connect an oscilliscope to the board and readjust the voltages on this board. when these voltages are off, like yours, you will see speckles in dark or light backgrounds....
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jul 20, 2008
Not Rated)
horst s
Rank: Apprentice
Rating: 78%, 4 votes
i have orange chains of pixels usually L shaped in black areas, but not always, it happens with some videos and pictures, but the weird thing is that it usually only happens in the center maybe 5inch by 7inch area. could it be nvidia drivers? i have a 8600gts xxx by xfx and acer 22 inch p223w screen running xp media center. any ideas how to fix it would be great
Was this helpful?
Yes
No
Popular Solutions for Hitachi 42EDT41 42 in.
Questions and Unsolved Problems for Hitachi 42EDT41 42 in.
Do you recommend Hitachi 42EDT41 42 in. HDTV-Ready Plasma Television?
Answer
Answer
last night i lost my audio on the tv. when i turned tv and cable box off and rebooted my system,... (More)
Answer
i have a thin green line that runs from top to bottom on th left side of my tv about 2 inches from... (More)
Answer
when powered on i have a good picture but there is a black line that splits my screen about an inch... (More)
Answer
what happens when your plasma goes pop but there is sound and no picture
Answer
black vertical line 1 inch wide down the center of the screen modelpw1a 42edt41
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hitachi 42EDT41 42 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
