Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Steering wheel on rider mower is straight and wheels both point
Out , can not steer it- from under it there is a wheel with belt -and up over that is a v shaped bar that looks a little chewed up- is that bar supposed to be up over the belt( sears 18.5 42" bed - got caught on a ridge and had to push it out , now it won't steer-nothing looks loose or broken off
  • 376 Answers
You need to take the bent tie rod off and straighten it out and put it back on. Look carefully at the engine pulley ("wheel"). Make sure it is not bent. By bent I mean the bottom is not pushed up. The pulley should form a 'V'
Posted on Jun 04, 2009
One of the belt keepers broke off where it bolts to the frame. the only thing I can see causing this is the drag link is hitting it when the wheel is turned. What can I do to keep this from happening?
The steering wheel gear is out of adjustment. To repair this you must drop the plate under the tractor. Remove the two bolts holding the steering assembly,there you will a gear at the bottom of the steering wheel shaft. This gear matches up with a spline that controls the steering wheel travel. You must make sure,that the wheels are facing straight ahead. Place the steering gear at the center of the opposing gear teeth,this will give the steering wheel perfect travel in both directions. You will encounter a problem trying to replace the bolts back in,when reinstalling the steering wheel shaft assembly. You must keep the wheels straight,at all times,any movement from center will again throw the wheels out of adjustment. I almost forgot the most important step the mower must be removed Sound hard,doing this repair,when explaining,but can see what has to be done,is much easier.Please,be careful you most certainly,will have to jack up the tractor to get get to the steering assembly. Hope this helps. Sincerely,Brad Locke
Jul 21, 2015 | Craftsman Garden
Have a cub cadet and steering wheel keeps turning but not turning the wheels at all now
howdie sounds like the Gear Box is broken it might need replacing or ther is a shear Pin that is Broke in ther To stop it from moving so might need to be replaced as well
Apr 25, 2015 | Cub Cadet Garden
I have a John Derre L130 and the left steering arm has lots of play any suggestions?
it has a steering wheel not steer arms... your issue is either something is bent/broken, the steering shaft is stripped or the steering wheel is just off
Aug 29, 2014 | John Deere Garden
Two front wheels misaligned, one is straight and the other points outward
To give you a professional soultion I really need a complete model number.
Here is what happens when steering becomes a problem on ANY brand of riding mower.
1. Tie rods get bent
2. Wheel spindle pivots get bent on one side.
3. Pivot bearings or bushings get worn
4. Linkages from the steering wheel to the tie rod pivot connection get bent.
On the basic bottom of the line Craftsman riding mowers the tie rods are fixed and not adjustable. However if you look for a mirror image left to right of the tie rods often you will note that one of them is bent in or out... or is shorter than the other one. There are after market tie rods that are adjustable. This is over 40 years of experience talking here.
THe best way to do an inspection of steering is to place the mower on tripods so that the fram is being supported and not the steering components and then set the steering wheel to the straight position and inpsect ALL of the steering and suspension components for the front end.
Without your model number this is quite generic. With a model number I can show you a parts diagram by item number of what to check.
Thanks for choosing FixYa,
Kelly
Aug 09, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman DLT 3000 Lawn Tractor, Model 917.273821. Two problems for which I'd appreciate any help: Problem 1. The front wheels are not aligned. The left front wheel cants out to the left so much so...
Problem 2 is probably a belt slipping or a pulley loose somewhere.Problem 1 .........is the tie rod adjustable?If the tie rods are adjustable, put steering wheel where it's supposed to be when straight, then adjust tie rods so that each wheel is pointed straight ahead. There should be a lock nut that needs to be loosened, then turn the tie rod end in or out and tighten lock nut. Back to problem 2....if it isn't the belt or pulley, it may not be an easy fix.Sometimes over time, belts stretch and get loose, or a set screw in a pulley can work loose, and cause the pulley to slip on the shaft. If it is hydraulic, it might be low on fluid.. I don't know for sure as I am not a big fan of Craftsman lawn tractors. Good luck
Apr 16, 2011 | Garden
The steering on my Husquavana 150 mower is slack and uneven, it turns sharp to left but not to right. Gear wheel at end of steering shaft is worn. How do I repair it with more sustainable solution. Thank...
replace steering gear and lower nyliner bushings on steering shaft. Also check sector gear for wear and replace if needed. When replacing gear place front wheels straight forward and center steering wheel-the unit should steer the same both ways then.
Nov 22, 2009 | Husqvarna Garden
Rider steering difficulty
First inspect all the steering parts. Inspect them closely and see if anything is worn to the point it is binding. Lubricate all moving parts. See if anything is bent or rubbing against another part. It is obvious it is only hard to steer when weight is on the front. That is a clue to what is going on. It is just a matter of looking very closely at what moves and what can cause something to no move as it should.
Oct 06, 2009 | Garden
Steering wheel straight but the wheels are in v shape nothnbroken
Barring anything broken or bent on the front steering linkage, the tires can be adjusted by removing the tie rod end from the control arm of each wheel. The tie rod end should be threaded into the tie rod. Turn the end in or out, depending on which way you need the tire to adjust. Do this procedure on both front wheels with the steering wheel in the straight forward position.
Hope this helps...
Jul 31, 2009 | Craftsman Garden
Husky rider wont turn left
CHECK THE STEERING SHAFT GEARS AT THE BASE OF THE STEERING WHEEL. I HAVE SEEN THE TEETH ON ONE SIDE BREAK OFF
Jul 29, 2009 | Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
340 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
