Question about Texas Instruments TI-83 Plus Calculator
I can not find the "Inv" button...
My assignment is using SIN, COS, and TAN; and it says to type the information in the calculator and hit the "Inv" button and the hit the "Tan" button... I am so confused...
  • 56 Answers
There is an inverse button below the math button, but if you hit second and the tan it should give you the inverse of tan. Hope this is what you wanted
Posted on Jan 09, 2008
How do you calculate sec174?
SEC, CSC & COT are the INVERSE of COS, SIN & TAN and are usually require hitting the "2nd F" or "Func" key of the calc to make:
SIN button work as COSEC,
COS button work as SEC
TAN button work as COT
Formulas are below:
sec x = 1
cos x
cosec x = 1
sin x
cot x = 1 = cos x
tan x sin x
Feb 05, 2013 | Sharp EL531 Scientific Calculator
How do i get inv on my TI-84 Plus caculator
To get the inverse trigonometric functions press the 2nd key then the trig function key. If you'll look at the key legends above the SIN, COS, and TAN keys you'll see the standard math notations for their inverse function.
Apr 05, 2012 | Texas Instruments TI-84 Plus Calculator
I can not find the arc key or the INV key
The INV key that you may find on some scientific calculators has, on the TI 83/84/ Plus calculators, an equivalent key marked [2nd].
On the TI83/84 Plus, each trigonometric function has a second marking [SIN^-1], [COS^-1] or [TAN^-1]. To calculate the inverses of trigonometric functions ( arc sine, arc cosine, arc tangent) you press [2nd] followed by the relevant trigonometric function key For example, [2nd] [SIN] displays sin^-1( on the command line.
Unfortunately the hyperbolic functions and their inverses are only accessed through the CATALOG. You press [2nd][0] to open the CATALOG. Then you scroll down the CATALOG list to reach cosh(, cosh^-(, sinh(, sinh^-1(, tanh(, or tanh^-1(.
To speed the search in the catalog, you use the ALPHA keyboard: To reach cosh(, press[PRGM] and you scroll down from there.
Feb 27, 2012 | Texas Instruments TI-84 Plus Calculator
Cot(x) = -0.6
Let's start with a little background.
The cot(x) is also known as the cotangent(x) and it equals 1/tan(x) which equals cos(x)/sin(x). I'm showing these formulas because your calculator may not have a cot button but it will probably have buttons for tan, cos, and sin.
Your calculator may also have buttons for tan-1, cos-1 and sin-1. These are the inverse functions for tan, cos, and sin. If you enter a number and then push the tan-1 button, the result is the angle whose tangent is the entered number. For example, it you enter 1 and push the tan-1 button the answer will be 45 deg because tan (45 deg) = 1.
Now let's look at the problem, cot(x) = -0.6.
The first thing we need to know is do you want the answer in degrees or radians? Your calculator will have both modes. The default mode when you first turn it on is probably degrees. If this problem is in radians you will need to change the mode of your calculator over to radians before we start.
If cot(x) = -0.6, then tan(x) = 1/-0.6 from the formula I showed in the background section.
This means tan(x) = -1.6666666...
Now we just enter -1.66666667 and hit the tan-1 button to get the answer.
If we're operating in radians the answer is -1.0307 radians.
If we're operating in degrees the answer is -59.036 deg.
I hope this helps you out.
Dec 06, 2011 | SoftMath Algebrator - Algebra Homework...
How do you use TAN, SIN, and COS on this calculator?
I'm going to use sin(90°) as an example. You would hit the sin button, type in 90, then hit ). You must type in the close parenthesis or the calculator won't read it correctly. The answer should be 1.
Jun 08, 2011 | Texas Instruments TI-30XA Calculator
Cant find the arc or inverse button
The trigonometric function [SIN],[COS] and [TAN] have inverse functions arc-sine, arc-cosine, and arc-tangent which are also implemented on scientific calculators. To access the inverse trigonometric functions you use the sequences [SHIFT][SIN], [SHIFT][COS] and [SHIFT][TAN]. The functions are marked on the body of the calculator as [SIN^-1], [COS^-1] and [TAN^-1].
When you use these functions, make sure that the angle unit is correctly set (as required by the problem you are solving) because the angle values returned are in the same unit as the one set.
Jan 15, 2011 | Casio FX-115ES Scientific Calculator
How to use calculator on how to evaluate trigonometric functions
The FX-115ES is somewhat different to other calculators you might know. The sequence of keys is more like writing up a calculation in a textbook, whereas for "normal" calculators operations are reversed in some places.
For example, with most calculators you would type 30 [sin] to calculate the sine function of 30 degrees, with the 115ES its [sin] 30 [=].
The 115ES has all the standard trigonometric functions:
  • Standard functions (sin, cos, tan), type the [sin], [cos] or [tan] key followed by the argument.
  • Inverse trigonometric (sin?¹, cos?¹, tan?¹), type [SHIFT][sin], [SHIFT][cos] or [SHIFT][tan] followed by the argument.
  • Hyperbolic functions (sinh, cosh, tanh), type [HYP][sin], [HYP][cos], or [HYP][tan] followed by the argument.
  • and finally inverse hyperbolic (sinh?¹, cosh?¹, tanh?¹), its [SHIFT][HYP][sin], [SHIFT][HYP][cos], or [SHIFT][HYP][tan] followed by the argument.
Arguments can be given as numbers with mantissa (2.718), as fractions (use the fraction key below [CALC]) or as degree, minute, second (30°12'45") using the [°'"] key for input. To switch between degrees (1 circle = 360°), radians (1 circle = 2?), or grad (1 circle = 400 gon), use [SHIFT][DRG>].
Jan 06, 2011 | Casio FX-115ES Scientific Calculator
How to solve for the trigonometric functions in the casio scientific calculator?
Press the relevant function key [SIN],[COS],[TAN] followed by the angle value.
For inverse trigonometric functions [SIN^-1], COS^-1], or [TAN^-1], Press [SHIFT][SIN], [SHIFT][COS], or [SHIFT][TAN].
For other functions
When calculating trigonometric functions one must make sure that the angle unit the calculator is using is the correct one.
Aug 26, 2010 | Casio FX-115ES Scientific Calculator
The answer that you have received in actuality is correct. However, it is in exact form when the answer that you were looking for was an approximation (decimal form) answer. To achieve this all you have to do is hit the alpha button (the yellow button with a diamond in the center) and then enter which will give you your desired answer :-)
Jan 14, 2008 | Texas Instruments TI-89 Calculator
Cosh Squared or Cubed
if you want to square sin(3), press:
Sep 24, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-83 Plus Calculator Logo
2,653 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
