Question about Dell PowerEdge 500SC Server
Video not working, red flashing light on bottom of pci raid card
  • chuckie85 Jun 04, 2009
    HI,
    Thanks for the the suggestion, I'll give it a shot when I get home from work this evening.
    Originally when I tried to fire up this machine, I had apparently installed memory in the incorrect configuration and I did get the memory message beeps.
    I removed all the memory and reinstalled only 1 128mb module in the correct configuration and no longer recieved beeps, but, now the video doesn't work and I started to get the flashing red light from the under side of the raid controller.
    I didn't clean the memory contacts however.
    Thanks again
    Brigadier General:
  • 3,614 Answers
try to resit the momory module on the unit. wipe and clean the contact on the module & resit it again. if this not solve the issue, try to remove/ uninstall the videocard and put it back again. if still theres a problem this could be a problem with your vcard.
btw. did you hear any beeping sound coming from the unit.?
Let me know for further clarifications.
Posted on Jun 04, 2009
    President:
  • 2,923 Answers
The red light indicator blinks once a card is not properly installed. Now, since it happens after accidentally inserting the memory card, you need to do some test to see if the PCI cards are still working. Here are the things that you need to do:
1. Remove the video card from the PCI slot and clean the contacts.
2. Re-insert the video card and fire up the computer.
3. If you get the same problem, insert the video card into any available PCI slot in your computer.
4. Last, try different video card and observe that red light behavior.
NOTE: If you will get the same problem after using different video card, you need to contact the computer manufacturer for second opinion. There could be a possibility that the PCI slots are defective.
Good luck and have a great day!!
Posted on Jun 05, 2009
Use of PCI-e x16 slot for non-video card
...........................................!O_O!...........................................................
WHY would you want to do that?
There is a PCI-Express x1 slot on the motherboard.
Black in color, and in-between the black PCI-Express x16 slot, and a white PCI slot.
Use the PCI-E x1 RAID adapter card in the PCI-E x1 slot, and a PCI-Express graphics card in the PCI-E x16 slot. Sheesh!
A PCI-Express slot is not an evolved PCI slot.
Completely different technologies.
PCI uses a shared Parallel bus architecture, while PCI-Express is based on Serial point-to-point.
So your idea of how to 'fix' your problem, is to use a PCI-E x1 card in a PCI-Express x16 slot, and a PCI graphics card in a PCI slot?
Completely backwards.
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
PCI-Express x16 slot uses the same lanes from the Northbridge, as the OnBoard video?
UTTER NONSENSE!
The Northbridge chip handles the Faster capabilities of a computer.
Handles the Processor, Ram Memory, and HIGH-SPEED Graphics.
HIGH-SPEED graphics is the Accelerated Graphics Port (AGP) technology, and the PCI-Express technology.
The Southbridge chip handles the Slower capabilities of a computer.
The PCI bus is one of those slower capabilities handled by the Southbridge chip.
The PCI bus is also a shared bus. This slows data down.
The AGP bus, and PCI-Express bus are Not shared. They also have a direct link to the Northbridge chip.
The PCI Bus has to go through the Southbridge chip, which has to go through the Internal Bus, THEN to the Northbridge chip.
OnBoard video, or Integrated Graphics, uses the PCI bus.
When you inserted the PCI-E x1 RAID card in the PCI-Express x16 slot, and a PCI graphics card in the PCI slot, BIOS just assigned another IRQ for the PCI-Express x16 slot.
(Interrupt Request)
No fancy technology going on there.
Backwards technology going on with a PCI-Express x1 card in a PCI-Express x16 slot, though.
I do not concur, and do not think that is a good solution, Kevin.
Regards,
joecoolvette
Aug 24, 2012 | Gateway Foxconn C51GU01 Motherboard
I have a Dell Optiplex 170L mnitower. It has one IDE and one SATA port. I have connected a 1 TB drive to the sata and disconnected the ide drive that came with the system. No I am thinking, what if I add...
Hi there! You don't actually need a IDE to SATA converter. If you purchase a RAID 1 card, it gets hooked up to your computer via PCI or PCI-E. The RAID card will have at least two SATA ports on it - those are what you use to create your RAID. The sata port and ide port on the computer will not be used in the raid1 configuration. If you're going to go ahead with this, I'd recommend trying to find the exact same brand and model of drive as the first one you have. Also, keep in mind that creating a RAID 1 array requires formatting BOTH drives. Your Optiplex 170 only has PCI ports, so this may be a viable RAID card. It is fairly inexpensive, but will do the job. http://www.newegg.com/Product/Product.aspx?Item=N82E16816132001&cm_re=PCI_RAID-_-16-132-001-_-Product If you need any more help/advice let me know! Alex
May 30, 2011 | Computers & Internet
If we use the server without PCI-PCIe Raiser card, it can boot into the OS. However, it cannot boot into the OS when we install the PCI-PCIE Raiser Card into the sever, and it alerts message error as...
The problem seems to be 2 things..
1.) firstly send the boot priority in the bios to HDD 0 or the harddrive connected directly to the board with the os.
2.) second thing, the Raiser Card, if it has raid Harddrrives connected via the ext. one of the raid harddrives connected to it is malfunctioning , remove and disable one at a time until u find the correct one. Or it could be the Card itself is malfunctioning.
I'm guessing here that you have a IDE card connected to the Raiser card with raid harddrives on it, One of them is malfunctioning.
Apr 01, 2011 | Dell PCI-X Riser Card for PowerEdge R200/...
I have 2 320gb sata drives connected to this pci card, but can only see one of the drives. Do i have to configure the card so that it can recognize both drives. They are not setup in RAID and don't need a...
Problem solved. There are 2 sets of jumpers on this PCI card. By deault they are set at 1-2 on both jumpers. So I changed them both to 2-3, reinstalled the card, restarted my PC and WoW!!!
There it was... working and recognizing both the HDD.
Thanks anyway and I hope that my answer gets posted as public so others can learn from my adventures... jejejeje.
Thanks FixYa!!
Jan 17, 2010 | Sabrent Serial ATA (SATA) 1 External + 2...
No screen
HI I'm mhel , try to replace your memory card (RAM) with a new one this should do the trick.
e-mail me if this help
mhel
mijamhel@yahoo.com
mhel_services@yahoo.com
May 31, 2009 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
Help with server boot problems flashing orange lights etc
Seems the RAID is broken. You may see which drive (hot swappable?) it showing an error code with its lights in front. If not, I would suggest re-seated all drives.
If you see one that is not right, remove it all the way, while it is on, then push it back in, it should try to rebuild the raid on the drive, if it still fails, you will need to replace the drive.
Not sure what RAID you are using or how many drives, so feel free to explain more.
G'luck
Oct 24, 2008 | Dell PowerEdge 4600 Server
Is there help for this dragon doesnt go on ive tryed video mem ?
This might be problem with your RAM. Remove the RAM and connect it to another memory slot or try changing RAM with new one.
Remove your PCI card and try now...
Sep 28, 2008 | Soyo i845 P4I Fire Dragon Pentium 4...
It doesn't boot up/work/register
The x1800 is a high-end video card, and requires you to plug a power connector into the back of the card. If this is not installed, the video card will not work.
The card should have come with an adapter to change the standard hard-drive style 4 pin molex power connector into the 6 or 8 pin adapter for the video card.
Feb 14, 2008 | ASUS EAX1800XT/2DHTV RADEON X1800 XT, (512...
Pci ide raid card problem
Could be a PSU problem. What wattage PSU do you have?
Jan 31, 2008 | Sabrent SBT-RDIT PCI IDE Silicon Image...
Dell PowerEdge 500SC Server Logo
mukhtar21 shaikh
mukhtar21 shaikh
