Question about Dometic Rooftop RV Air Conditioner
Rv electrical question
Our rv has been tripping breakers when plugged in to garage. My husband turned everything off at the main breaker box in the camper and plugged it in and it still tripped the breaker. We tried 3 different adapters one which was brand new and it still did not work. He brought in the extenstion cord in and put the wires that go to the main black power cord into the extension cord and it worked without tripping the breaker. Please let me know if anyone might have an idea what is going on?
  • 106 Answers
By the main breaker in the camper, do you mean the main 24 or 12 volt breaker, or the incoming 120vac breaker? Is it tripping the breaker in the camper, or the house? If it is tripping the breaker inside, i would look for maybe water damage, rusty components, maybe have an electrician come look at it, not worth going out away from home, and that problem ruining your vacation! Does this unit have a generator set? Try disconnecting the generator too. Hope that helps!
Posted on Jun 04, 2009
We have no power coming to the caravan from the main line at a caravan park,trip switchs trip
You don't give enough info, but I presume you mean the breaker on the parks supply post trips?
If so it means you have a dead short somewhere in your RV, the only way to find out what and where is to turn all the breakers on the RV board, turn on the master first, it should stay ON, (See note) proceed to turn the other breakers "ONE BY ONE", one of them should jump your or the park's main, keep that one OFF until you identify and repair the shorting equipment in your RV.
(Note if the parks breaker jumps when you turn on the RV's main only, get professional help.)
Jan 15, 2018 | RVs
Outlets not working all fuses are good
120-
VOLT
AC
SYSTEM
The following electrical components (if so equipped) will only operate when your
RV is connected to shore power: 120 to
12-volt power converter, air conditioner,
120-volt refrigerator, microwave oven, television(s), fireplace and appliances
plugged into convenience receptacles.
SECTION 6 - ELECTRICAL SYSTEM JAYCO TOWABLE
6-2
120-
VOLT
CIRCUIT
BREAKERS
The 120-volt AC circuit breakers located in
side the main load center protect all
120-volt wiring and components in the RV fr
om circuit overloads and short circuits.
Should a circuit overload or short circui
t occur the circuit breaker protecting the
affected circuit will "trip" preventing the flow of electricity through that circuit.
If a circuit breaker trips, shut "off"
the appliance on that circuit (i.e., power
converter etc.) and allow the circuit breaker to cool down for a brief period of time.
After the cooling down period, reset the circuit breaker by moving its lever "off" and
then back to the "on" position. If the circuit breaker re-trips or frequently trips,
contact your dealer to have the electrical problem diagnosed and repaired.
A circuit breaker identification label is permanently attached to the inside surface
of the 120-volt load center.
Maintenance and Replacement
At the beginning of camping season, inspect the circuit breakers and replace as
needed. Test by turning each circuit breaker "off" and back "on". Circuit breakers
are wearable parts and must be replaced
as needed, as part of your RV
maintenance. If you have any questions, consult your dealer.
Please contact your dealer for repair assistance when replacing circuit breakers.
CONVERTER
The power converter converts 120-volt AC power to useable 12-volt DC power
when the shore power cord is connected to an external power source.
The converter has a built-in protective thermal breaker that will shut it down should
overheating occur. Overheating can be
caused by operating the converter above
its maximum power output for an extended period of time, or by an obstruction to
its ventilation air flow. To reduce converter heat build keep unnecessary 12-volt
lights and motors turned "off"
Keep the converter cooling fins and fan clear of
obstructions.
Inspection and maintenance
If the 12-volt power converter is not working (auxiliary battery not being charged)
check the reverse polarity fuse(s) in the converter fuse panel.
There are no
customer serviceable parts inside the converter case and the
manufacturer's warranty will be void if
the case has been removed
. If you
have further concerns contact your dealer.
Nov 16, 2014 | Jayco 2013 Jay Flight Swift 264BH
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
Main breakers keeps blowing what is the reason i had the electrical company check there stuff up to the house said everything was ok no smaller breakers are blowing just the 200 main is it possible i did...
Add up all the amps from active breakers. Do they add up over 200? If not, then I suspect a bad main breaker. If they do, then you need a larger service box and or main breaker.
Sep 24, 2017 | Siemens 200 Amp Main Breaker 30 Spaces 40...
Electrolux EOB 6632 oven trips main house circuit breaker if used above 180c. Installation electrician has done whole house test, says everything normal, must just be a particularly sensitive ciecuit...
Hi, welcome to FixYa! my name is Shaun. I hope i can help you out with your question. Your main house breaker is tripping over 180C because of the amount of current your oven is drawing. Keep in mind that an oven is capable of pulling up to 1/4 the amount of amperage of your total house current capacity, up to 50 Amps. This is assuming you have a typical 200 Amp main breaker. Add this in with your heating/air-conditioning, up to 30A, if electric, your water heater, 25 A if electric, and whatever lights and appliances you have plugged in and turned on, you can imagine how quickly those amps add up when your oven is on. Your oven breaker won't trip because you're not exceeding 50A on that circuit, however if your total household load is exceeding 200A, your main will trip. Also, breakers lose efficiency over time. Sometimes they can drop current capacity by as much as 25%. So your best bet is to replace your house main and see if that fixes your problem. Hope this helps out. Have a good day!
May 05, 2011 | Electrolux EOB6632 Electric Single Oven
I have a 15 amp single pole circuit breaker that
It could be either or at this point. First thing to do, is unplug all electric devices from the plugs on that circuit, and then attempt to reset the breaker. If it does not trip, one of the devices plugged into a receptacle on that circuit could have a short. If it doesn't trip, plug each device in one at a time to see it it trips the breaker to pin point what is causing the short. If the above has no effect, I recommend replacing the breaker. It is easy and inexpensive to do. Just make sure you main is shut off before doing any work on the panel. I hope this helps and good luck!
Nov 06, 2009 | Connecticut Electric & SWITCH UBIP130...
No electrical power
You must find the reason the main breaker is popping ...
I'd start by unplugging everything and remove all breakers. Turn the main on ... does it pop? If it pops here look between the breaker panel and the end of your cord. Turn the power off - reinstall the first breaker - turn power back on. What happens ... keep doing this until the main or individual breaker pops - investigate that circuit to find your short.
If you get all breakers back in with out popping anything ... start plugging stuff back in. Something is shorting somewhere.
Let me know what you find please.
thanks
a
Oct 06, 2009 | Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED
Siemens Main Breaker 125 Amp gets warm and trips
sounds like a loose connection ,or possibly a weak main breaker.
Jul 14, 2009 | Siemens /ITE 100Amp 2-pole molded circuit...
Roof Top A/C Throwing Main Breaker
do you have an amp meter. when the main is tripped what is running? maybe the main breaker is going bad. I dont think you are pulling more than 20 amps when everything is running. not unless the fan on the A/C shorts to ground when it gets hot????
let me know
Jun 22, 2009 | Dometic Rooftop RV Air Conditioner
Installing a Dayton G73
How many amps is your service? And what gauge wire did you use for the heater?
If your service is only 40amps that is your problem. You don't have enough amps for the heater and the rest of your house, you will have to upgrade your service.
Nov 02, 2008 | Dayton G73 Utility Heater
Dometic Rooftop RV Air Conditioner Logo
394 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
