Question about Texas Instruments TI-83 Plus Calculator
When I enter Sin(30)the answer is -.9880316241. This not correct. What should i do?
  • 192 Answers
You have the calculator set up to do radians instead of degrees. I'm not that familiar with the TI-83 but I believe you should look for a key labeled DRG. This stands for Degrees, Radians, and, Grads. Push this key and then use the arrow keys to move from RAD to DEG and hit enter. Now enter Sin(30) and you should get 0.5.
Posted on Jun 04, 2009
  • gdcroft Jun 04, 2009
    I looked it up. The TI-83 doesn't have a DRG button. Instead you need to use the Mode button and then the arrow keys to change from radians to degrees.
Do you enter sin 30 to get answer or 30 sin
Set the angle unit to degrees.
Try sin (30)=, and 30 sin
The correct answer is 0.5
Usually if pressing the sin key display sin( then you should use sin(angle) =.
Jul 15, 2014 | Canon F604 Scientific Calculator
Sin(30)=
The sine of 30 radians is about -0.988 while the sine of 30 degrees is 0.5 .
To change the angular setting, press MODE, down-arrow to the "Radian Degree" line, highlight Degree, press ENTER, then 2nd QUIT to exit the mode screen.
Jul 26, 2012 | Texas Instruments TI-84 Plus Calculator
Any sin, cos, or tan function problem always gives the incorrect answer. I can use my TI 55 that is 30 years old and get the correct answer, but my son's TI84 plus silver edition is incapable of giving the...
Make sure you have the proper angular mode set. The TI-84 can work with degrees or radians.
Press MODE to bring up the mode screen. Use the arrow keys to highlight either "Radian" or "Degree" on the third line and press ENTER. Press 2ND [QUIT] to exit the mode screen.
If this doesn't do it, please reply to this post giving an example of a calculation and the answer you're getting from the calculator.
Feb 03, 2011 | Texas Instruments TI-84 Plus Calculator
I have a CA656 model calculator. First, how cann I get it to show teh full answer to my math problems in decimal form. It is rounding to a whole number. Next, how can I calculate sin 30? What steps...
  1. Press MODE 9 to shift into Normal display mode, or MODE 7 and enter the number of digits you want to see.
  2. sin 30 EXE. Be aware that the result depends on the angular mode. Most math problems are specified in radians, while your example sounds like it's in degrees. To select degrees, press MODE 4. To select radians, press MODE 5.
  3. 30 * sin 30 EXE. Everything in #2 above applies.
Aug 14, 2010 | Sentry Office Equipment & Supplies
How do you use the sin-1
You would press on the SIN key, "sin(" should come on the display, then enter the value, for example 3.5 or -1 so that the display shows
sin(3,5) or sin(-1) for example.
remember to close the sin with the ) on the end.
sin(-1) = -0.841470985
Feb 16, 2010 | Texas Instruments TI-30XA Calculator
Ti84 "Sin/Cosin/Tan" Problem...
The problem is that you have the mode in radians. You want them in degrees. This is a simple fix. Press mode and then go down to radians and select degrees
Jun 24, 2008 | Texas Instruments TI-84 Plus Calculator
TI-83Plus
Make sure you are set to degrees, radians, or grads, whichever angular measurement you are using.
The DRG key toggles through the three modes of input, and the display shows which you are in.
30 SIN will give the correct 0.5 answer if you are set to use DEG.
Set to RAD and since 30 degrees = (30)(pi)/180= 0.52234 rad, set to RAD and 0.52234 SIN also gives you the correct 0.5 result
May 06, 2008 | Texas Instruments TI-30XA Calculator
SIN COS TAN
The answer that you have received in actuality is correct. However, it is in exact form when the answer that you were looking for was an approximation (decimal form) answer. To achieve this all you have to do is hit the alpha button (the yellow button with a diamond in the center) and then enter which will give you your desired answer :-)
Jan 14, 2008 | Texas Instruments TI-89 Calculator
Need help withe the sin, cos, tan problem with ti - 83 plus
here are the steps in changing it from radian to degrees
1. turn on your TI-83 plus
2. press the MODE button near the top of your calculator
3.go down to options and move the highlight from radian to degree, press enter and clear
you're good to go
Feb 17, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
309 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
