Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Off/on switch does not work
I vacuumed one room and turned off vacuum.  Went to another room turned it on and nothing happened.  I waited 2 days and still when I turn on vacuum, nothing happens.  Any ideas would be helpful.  I checked belt and it is O.K.
  • 0113 Nov 05, 2007
    I removed the two screws in the back and re assembled. I can turn it on but not off.
  • Yosefyitz May 09, 2008
    I took apart the vacuum until the actual on/off switch, which was difficult to switch. I think it may be a broken spring inside.
It really worked,
Thanks for this uggestion!!
Posted on Nov 05, 2007
The on/off switch in Hoover Windtunnel upright vacuum cleaners is operated by a lever in the handle assembly.  remove the two screws on the back ovf the vacuum and see if the lever has bypassed the switch assembly.  if so, re-assembly should fix the problem.  It is also possible that the switch activating lever has broken.  If so, replace the activating lever.
Posted on Oct 24, 2007
Nothing happens
it could be the wiring coming from the vacuum itself you might have to change it.can be brought at any electrical wire store have you checked the plug wiring is it all intact or has some came out from the terminals?
Apr 06, 2014 | Electrolux Z4735AZ Gazelle 1900W Upright...
My Dyson DC07 Animal will not turn on
it could be one or two things broken switch/ cable broke/ or fused, this video below will help if you need new switch
Jan 01, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
My vacuum worked just fine... i went in another room to use it and now it won't turn on no matter what outlet i use!
If it works in the other room's outlets, I would think that it might be tripping the circuit breaker for the room it isn't working in. Check your circuit breakers.
Dec 07, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
Will not start at all
most likely if it dont turn on at all period.1 of 2 things on/off switch went out or 2 motor burned up but most time u can tell if it is bad motor cause if it smelt like burnt plastic ever bad news its dead but hopefully u can just change switch
Dec 15, 2007 | Kenmore 31913 Progressive Direct Drive...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
558 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
