Question about Garmin nuvi 750 GPS Receiver
Can't start the route once it's entered in
Garmin 750when the route is entered in how do I start the route? I can't find the go button
    Scholar:
  • 62 Answers
Hello, You will find all informations regarding your garmin nuvi 750 in the following link to the manual. http://www8.garmin.com/manuals/nuvi750-GPS-Atl_OwnersManual.pdf Please rate the solution. Good luck, Jegan
Posted on Jun 04, 2009
My garmin rino hcx won't upload satelites
Try performing a factory reset.
Be sure to save your favorites, routes, and waypoints before doing the reset as these will be deleted.
The factory reset is done with unit OFF.
Press and hold PAGE button and ENTER button and while holding the buttons turn ON the unit.
Reset is complete.
Dec 21, 2011 | Garmin Rino 530HCx 2.1 in. Handheld GPS...
When i turn the power on it just keeps flashing Garmin.
You can try three things to try and get the Nuvi to start normally:
1) soft reset: Press the power-on button for at least 20 seconds - starting from power off. It should restart.
2) master reset: This will revert to factory defaults erasing all POI's, Favourites, Tracks, Routes etc. From power-off hold the lower right corner for at least 20 seconds while pressing the power-on button once. A question should appear to erase all user data. Press yes and it will revert to factory defaults.
3) Connect a USB cable in power off. Connect it to a PC / Mac which is also powered down. Start the PC/MAC - the Garmin Nuvi should start in communication mode. Connect to the internet and load MyGarmin.com and try to update the software version to the latest one (if available). If necessary install the Garmin communication plug-in in the webbrowser.
Jul 10, 2011 | Garmin nuvi 1300 Car GPS Receiver
My Garmin 1450 locks up and will not compute a route, or show maps. It is about 3 weeks old and this it the first trip for it.
I experienced the same issue with a Garmin Dezl 560 - which is based on the Nuvi. After experimentation with various very long routes the Garmin started with sudden restarts, lockups and other weird behavior. It became unusable - which seemed like a programming error to me.
After a Master Reset - clearing all user data (POIs / Routes / Tracks) the Garmin acted normal again.
A master reset is triggered by holding the right bottom corner of the screen for at least 20 seconds while pressing the power button once. A question appears after some time to clear all user data.
Recently I've upgraded to a latest software version through MyGarmin.com - haven't seen this sudden lock-up / restart issue since.
Jul 09, 2011 | Garmin nuvi 1450 GPS Receiver
Problem with our Garmin you can turn it on and it will not do anything but display Garmin name and will not turn off. Have changed batteries, any ideas???
It sounds like your Garmin has a corrupt file or file system. This is common when using bird's eye imagery with unsuspected shut-downs.
Try doing a soft reset of the Garmin:Warning: This procedure will delete information (waypoints, routes, tracks, etc) from your GPS and settings may be set back to factory defaults.
1. Power the unit OFF
2. Hold down the two Soft Keys for 2 seconds
3. While continuing to hold the 2 Soft Keys down, press and hold down the Power button for an additional 5 seconds
4. Release all buttons, and select YES to the prompt asking "if you want to clear all user data?"
This form of reset does not seem to reset all of the settings to factory defaults, just a few of the basics like Time Zone and Language, the remainder of the settings are still taken from your existing profile files.
Once you have completed a reset remember to place the Colorado outside in a stationary position for 20 minutes in plain view of the sky so that it can rebuild the almanac before using it again.
Note: Holding down both soft keys and the select button in a similar fashion seems to do a similar reset to the Colorado. This may be a master reset.
If the problem still persists, try this as a last ditch effort.
Warning: This procedure may delete information (waypoints, routes, tracks, etc) from your GPS and settings may be set back to factory defaults.
If you can't get your CO to start properly and it will not go into USB storage mode when connected to your computer you can try this as a last ditch recovery. It worked on a 400t that would freeze when loading maps and soft/hard resets didn't not work, I've also used it to recover a Colorado which refused to boot because of a bad gpx file.
First you'll also need to download file below. Once you've downloaded this file unzip it into a directory such as C:Garmin on your PC.
On your PC click the Start menu, select "Run..." and type "cmd" where it says open. A black window with a DOS command prompt should appear. At the command prompt enter the following command:
.text { font-family: monospace; }.text .imp { font-weight: bold; color: red; }.text span.xtra { display: block; } > cd c:Garmin
At the next command prompt type the following command without hitting enter:
.text { font-family: monospace; }.text .imp { font-weight: bold; color: red; }.text span.xtra { display: block; } > Updater.exe 066101000230.rgn
Now back to your GPS.
Press and hold the "up button" on the Rock'n Roller while you plug the CO into the USB cable. Wait 10-20 seconds while still holding the "up button". You should see a Garmin banner and nothing else. At this point you can hit enter on your PC to execute the updater command. Once the updater runs you will need to select you Colorado under USB and hit enter. This should perform the update (you may get a warning about loading an older version of software). You should receive a message that the update was successful and the Colorado will reboot.
Once the reboot is complete the "Loader" banner should appear near the top of the CO screen after about 30 seconds. Release the "up button" and on your PC you should be able to see the Colorado as a USB drive.
You can now attempt to fix the files on your Colorado which are preventing it from starting. If you've recently added or changed files these are good places to start. Deleting gpx files and/or replacing map img files with your backup copies may resolve the issue as well.
zip.png Colorado_Mass_Storage.zip
Feb 07, 2011 | Garmin Colorado 400t
Describe your change state/province setting garmin 960 Problem I live close to a state border, so I want to search all states without having to enter state/province
Once you click Where To at the bottom of screen click Near
choose Where I am now ..... A different City....Current route or Destination
Nov 22, 2009 | Garmin Nuvi 660 GPS Receiver
Wont calculat route
sat nav needs a valid gps signal to start calculating route, even if it found entered address. Address is searched on built-in map, not live gps position. That means, sat nav may have problem with gps signal. Try to reset device to its factory settings first. hope this helps
Nov 01, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Started out on route. Garmin nuvi 255 kept repeating same thing
This has happened to me also,therefore I never start the location I am going to untill I am in the car ready to go,I turned the unit off,then on and went to my favourites and touched my location again,worked for me,good luck.I keep all the locations I am going to now or in the future in favourites,saves time.
Sep 21, 2009 | Garmin nuvi 255W GPS Receiver
Transfering Routes to GPS device
Once you have transferred it using mapsource it won't automatically be in the custom routes. You still have to "import it from a file". Unplug your garmin from the computer then go to "Tools" then "My Data". That's where you should find the "import route from a file" button. It won't import if you already have 10 custom routes saved so you'll have to delete one.
May 03, 2009 | Garmin Nuvi 550 GPS Receiver
Route calculation Error on Garmin GPSmap 60CSx
Try re-setting your gps by simultaneously pressing the Enter and Page buttons while turning it on if that doesn't work check your firmware i found the latest one v 3.90 would shut off my gps when recalculating v 3.70 is stable Garmin know that the new firmware can cause problems
Mar 09, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Hi I have a Street Pilot C510 and will taking it with me overseas. I have the correct maps. How do I use my GPS so that it will navigate me along a specific route(coastal)which is my preference.
You should be able to "insert" points into an exising route. So, first enter your destination. Once the Garmin selects the route, you can then pick several points along the coast, and insert them into your route. This will force the GPS to re-route you along your prefered coastal route.
Jul 08, 2008 | Garmin GPS
Garmin nuvi 750 GPS Receiver Logo
75 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
