Question about Acer Aspire One PC Notebook
Aspire one ZG5 CCHANGES THE ZOOM LEVEL ON ITS OWN
My aspire one zg5 changes its zoom level from 100 to 10 or more. I would like to lock it but I am not able o do so. Please help me.
Go to Control Panel > Mouse > Device Settings > Settings > Advanced Gestures > Pinch
(or alternatively right-click the Synaptics Pointing Device icon in your taskbar and select Pointing Device Properties)
Untick the box that says 'Enable Pinch'. This will disable the zooming.
Additionally, you might be suffering the same problem as I was which was I had no idea how to use the zoom and that's why I wanted to lock it. Once I learned, I've decided the zoom is useful and I'm keeping the feature enabled.
Here is what Synaptics have to say about the 'pinch' gesture:
The Pinch gesture delivers zooming functionality in many applications. The Pinch gesture can be used to perform the same function as a scroll wheel on standard Windows applications that support CTRL-SCROLL WHEEL zoom functionality.
To perform a pinch gesture, place two fingers on the TouchPad surface. Move them closer together or further apart. To zoom in, place your fingers on the TouchPad surface near to each other and then slide them apart. To zoom out, begin by placing your fingers apart and then moving them closer together.
The best zooming experience results when the finger tips of the two fingers are used for the gesture.
That will hopefully be of assistance if you want to learn how to use the zoom rather than disable it.
Posted on Aug 08, 2009
If the screen is compressed on one side of acer aspire one zg5
reset resolution to a lower setting try 1024x768 if that doesn't work try reinstalling windows as long as the same issue is not present in the dos start up screen then its windows based
Feb 27, 2013 | Acer Aspire One PC Notebook
Acer aspire zg5 battery not charging
If your laptop computer runs normally on your acer aspire one zg5 ac adapter, but the battery won't charge, please try the following troubleshooting steps:
1) Remove the battery from the system.
2) Look at the connectors in the bay and on the battery for signs of physical damage.
3) Check the battery charge by pressing the status button or image on the battery near the LED's. Note: The lights indicate the current amount of charge on the battery. If all the LED's come on when you press on the butto, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flashm or blinkm there could be a problem with the battery.
4) Reinsert the battery; puch until it locks into place and the latch snaps back to the locked position.
Jan 09, 2013 | Computers & Internet
Support and drivers of my acer aspire one zg5, i can't find.please help
this where to get your drivers from...
http://www.notebook-driver.com/acer/acer-aspire-one-netbook-windows-xp-drivers/
remember to rate me
Dec 31, 2010 | Acer Aspire One Netbook
Turns on (fans spinning, HD clicking), blank screen, no sounds
hi this issue is with ribbon cable it is connect between the mother board and your LCD screen. the cable required change. if you can change it OK other wise take it to nearest service center.
Jun 15, 2010 | Acer Aspire One Netbook 8.9" Notebook
Zoom level keeps changing
I had this same problem after I downloaded IE9. The zoom level kept reverting. I tried every solution I could find that was offered on this site. Nothing worked. I disabled Google toolbar and the problem is gone.
jon
Apr 27, 2010 | Acer Aspire 5500 5570-2609 Laptop
My aspire one zg5 screen has moved to the left
i assume that when you start the machine you are getting the correct screen (Acer preboot screen) if that is working, then you should check the resolution, simple way is to start the computer in VGAmode, press F8 while starting the computer and select the VGA mode, this will start the computer in 800*600 resolution. then change the screen resolution to the 1024*600. this should fix the issue.
Mar 31, 2010 | Acer Aspire One PC Notebook
Can't find the equivalent model numbers for Aspire One ZG5
From ACER FAQs:
The Aspire One systems labeled with the model ZG5 are actually an Aspire One AOA110 or an Aspire One AOA150. Any information will be listed under AOA110 and AOA150, rather than ZG5.
The supportmodel number is located on the bottom of the netbook on a white label above the serial number. Alternatively, the support model number will be located in the BIOS which can be entered by pressing the F2 key when turning the netbook on. Once in the BIOS it will be under the Information tab to the right of Product Name
Aug 22, 2009 | Acer Aspire One PC Notebook
Wireless driver for acer aspire one series zg5
Hi there and welcome to FixYa,
I find that there is drivers for Linux, Vista and XP, go to:
this page
and choose you OS and all the drivers you need including your wireless driver :-)
Regards
/Teis
Don’t forget to vote if this was what you needed.
Thank you
Dec 17, 2008 | Computers & Internet
Help me find driver for my acer atom zg5...its xp Os
Hi and welcome to FixYa,
The driver for your Aspire Acer Atom zg5 (WinXp) can be downloaded here:
http://www.drivers-software-download.org/tag/acer-aspier-one-zg5-sound
regards
/Teis
--> dont forget to vote "FixYa" if this Fixed Your problem :-)
Dec 07, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire One  PC Notebook Logo
1,211 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
