Question about Whirlpool Calypso GVW9959K Top Load Washer
Fills with water and starts then stops and shows ob signal
  • 530 Answers
You either have something stuck in your sump balls which without a special tool will be very difficult to repair on your own or you have a bad pump. tilt unit back enough to look underneith it might be difficult with all that water in it. So here is what I do to remove it. Do you have a wet dry vacuum? I take the drain hose and attach my vacuum to the end and **** out all the water this is a very easy way. Now get under the washer by tilting it back but not all the way just enough to gain acces to the pump. take the bottom panel off by removeing 3 5/16 bolts. make sure the unit is unplugged from the wall for safty of course. if you where to look up and to the right of it. you will see the pump take it off by removing the 2 clamps and 2 clips. look inside the impeller sometimes you will see a lot of lint or coins. But usually it needs to be replaced if there is anything in there. let me know how it goes I hope for you that it isn't in the sump area. you would have to remove the lid, tub ring, ujoint, wash plate, balance ring, basket, the part you need the special tool; for is the hub nut. with out removeing this you will not be ablke to access the sump. try the pump first though
Posted on Jun 04, 2009
How to fix amana w10240534c washer wont fill?
check your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. no fill If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
May 31, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Calypso Washer stopped working
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*@#$&
Jul 18, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What does error code ob mean on a Whirlpool Calypso washer? The washer stops in mid cycle with the error code ob. I restart it and after a few minutes it shows the same error code again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*@^%
May 29, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore calypso washer will not spin the clothes ld or ob signal continue to show even after i have evenly distributed the clothes
May 15, 2010 | Kenmore 24032\24036 Top Load Washer
The washer stops mid cycle and says Ob. I
Apr 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*(@$&
Mar 28, 2010 | Kenmore 24032\24036 Top Load Washer
My Kenmore calypso washer (older model is giving me the Ob and SL flashing signal. The washer stops right before the last drain and spin. Any ideas?
Jan 16, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite (Calypso) Top loader Will start and fill up w/ water, and wash for a while. During the washing process it makes a humming noise and then the display gives a "ob" reading. I have replaced the...
Jul 18, 2009 | Kenmore 23822 Top Load Washer
Whirlpool Calypso stops at 26 minutes and throws ob code
May 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
first you need to clean your washer
run the washer with no clothes; add 1 cup vinegar, that will cut the soap residue from the hoses do this on hot wash hot rinse
then when you wash your next load of clothes; fill the tub about 1/4 full, add the soap, turn the agitator to disolve the soap, then add the clothes
this problem happens also if you are using too much soap or a heavy duty soap such as Tide.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
172 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
