Question about Microsoft Visual FoxPro 5.0 for PC
Transfer foxfro dos-dased attendance application to other PC
We are using a foxpro dos-based attendance application.How can I transfer the whole application because we are going to upgrade the PC? I dont have the installer of that application?
thank you.
  • John Moore May 11, 2010
    How far are you going to upgrade? DOS programs get harder to run on newer versions of Windows. I would suggest you consider upgrading your DOS database program to a Windows database program such as Access in MS Office. Then you should be able to use FoxPro to save your data in a "Comma Separated Value" (CSV) format. Access will import the CSV file and your data is converted and your program updated.
  • 1,263 Answers
Well the good news because it dos based, it should be very self contained for example if the program is in a folder called foxapp, copy this folder and sub folders and all contents to the new machine,
if it don't work you missed something , just a case of having a look at other folder names most fox apps I wrote were contained within it own folder.
Regards
GeWiz.
Posted on Jun 16, 2009
  • Robin Hill
    Robin Hill Jun 16, 2009
    I don't there is the need to port it to Access , if you do have issues running the dos application, I suggust you look at the following url
    www.dosbox.com/
    Regards
    GeWiz.
I am using dos based foxpro application in widows xp. when ever i take print from epson Fx 2175. the print job is paused at last line until i close the application. please rectify.clarify,...
Many DOS programs were designed to write directly to the printer's buffer, rather than to a spooler like more modern applications. It sounds like FoxPro is doing exactly that - and isn't designed to release the job until being completely closed.
Mar 06, 2011 | Epson FX 2170 Matrix Printer
I HAVE 20 COMPUTERS CONNECTED THROUGH LAN SYSTEM HAVING XP SERVICE PACK 2 & 3 OS. I HAVE INSTALLED NORTON 2010 ANTIVIRUS SOFTWARE ON EACH SYSTEM 10-11 MONTHS BACK. I HAVE ERP-SYSTEM IN FOXPRO FOR DOS...
Dear Walia,
We need to check weather you are getting any error message while trying to access the Network Computers..
Could you please go through the following steps and check weather you are getting any error message or Dos system getting hanged..
Disable the Norton program from the First 2 systems and try to access the Computers with Ping command...
To use the ping command please open the Command prompt and type ping [ip address of the Second system] ...
If u can access the Computers after disable the Norton program means surely it due to the issue with the Norton firewall...
In that case we need to create the New firewall rule for the Norton program to access the Specific Application
Thanks
Alexander Xavier
Nov 30, 2010 | Norton Internet Security 2010 Antivirus +...
How to print foxpro2.6 dos application to laser jet printer
THE CUSTOMER SHOULD TRY REINSTALLING THE DRIVERS,AND IF PROBLEM PESISTS HE SHOULD TAKE THE PRODUCT TO AN HP SUPPORT END.
Feb 06, 2009 | HP LaserJet 1020 Printer
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Foxpro dos application exe obfuscation
you need the re-fox or fox shell
is works good
an from mexico
Jan 02, 2009 | Microsoft Visual FoxPro Professional...
Foxpro dos programme not printingin usb printer laserjet cp1515
You can access your printer connected to USB port with loop back configuration and print from DOS.
Not only that, you can also print to a printer on the network
Try
Net use lpt1: \\Comp name\ printer name /persisten:yes
Dec 31, 2008 | HP PSC 1610 All-In-One InkJet Printer
What is the command for networking printer for foxpro in dos ?
you can do this thru printer maping
try this DOS command
net use LPT1 \\computer name\printer
Dec 15, 2008 | Computers & Internet
Printronix
i have problem in winxp for printer proline sereis 5 printronix line printer driver not match
in custom size
so need for printer driver winxp supported
Sep 18, 2008 | Printronix Line Matrix P5005B Printer
Dos compatibility
yes intel 945 chipset is not proper work on Dos based programs.u can use foxpro for window
Jan 08, 2008 | Gigabyte GA-8IDXH Motherboard
Microsoft Visual FoxPro 5.0 for PC Logo
110 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
