Question about Sanyo DS27820 27" TV
How to play PS2 on Sanyo tv set
I cannot play my PS2 on my Sanyo because there is no TV/Aus in button on the remote or television.
  • 158 Answers
You can play your PS2 via the RF in (ANT IN ) at the back of your TV .
For this you will first have to connect a AUX to RF converter jack device to ANT IN jack of TV.
Then determine the OUTPUT CHANNEL of the PS2.
(Channels-1 to 12 is in VHF band
channels-21 to 69 -UHF band)
Put the PS2 "ON"
TUNE the TV set to the frequency of PS2.
Posted on Jun 14, 2008
  • wisam musa al kuzaie Jul 12, 2013
    Do you have a picture of this converter ??
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Jan 27, 2016 | Sanyo Televison & Video
Sanyo AVM-3259S TV is stuck on video2 remote is lost. How do change video input? Right now I can only play video games on it.
As the TV has no menu button on its front panel, you must have its remote control to select inputs.
Jul 22, 2013 | Sanyo AVM-3259S TV
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
I don't see anything on television when i'm playing ps2
What type of TV are you hooking the cables too? Most likely the TV settings will need to changed to one of the following.  TV1 or TV2 using the input button on the remote, or channel 3 or 4.  It depends the set up of the TV
Dec 02, 2008 | Sony PlayStation 2 (PS2) Console
RCA universal remote
I programmed an rca universal remote by:
TURN ONTHE TV
HOLDING DOWN THE TV ANDTHEON/OFF BUTTON ATTHE SAME TIME.UNTILTHEON/OFF BUTTON STAYED ILLUMINATED.
PRESS THE PLAYBUTTON IT WILL BLINK,IF TV DOES NOT GO OFF PRESS PLAY EVERY 5 SECONDS UNTIL TV GOES OFF.
ONCE TV TURNS OFF HIT THE REVERSE BUTTON THE TV WILL COME BACK ON.
HIT THE STOP BUTTON TO SAVE THE CODE.
REPEAT THIS BUT HOLD THE OTHER DESIRED DEVICE INSTEAD OF THE TV.
HOPE IT WORKS
Igotthisinfo from google....then typed in rca universal remote...there was a sight for programming remote.
Jul 26, 2008 | Sanyo DS24425 24" TV
Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
May 13, 2008 | Televison & Video
Help
hit the input button again . it should switch it back to reg t.v and to set it back to video so you can play ps2 just hit the input button again.
Apr 04, 2008 | Sanyo DS24425 24" TV
Sanyo DS32424
Could be a bad remote, bad contact on that button. You could try taking it apart and cleaning it with alcohol. You could also try hooking the unit up to your VCR (if you have one). The other option would be to buy a channel 3 modulator.
Hope that helps...
Geno
Feb 27, 2008 | Sanyo DS31590 31" TV
Sanyo DS32424 can't hook up PS2
Some of the inputs will be below channel 2. Just channel down below channel 2 and see if it finds them..
Feb 24, 2008 | Sanyo DS31590 31" TV
Hooking up ps2 game
No this is not why, Time Warner Cable won't mess with that because I have it. What you need to do is make sure your T.V. is on the right video channel, look for source or video button on your remote and switch it to another while your PS2 is on and running.
Feb 23, 2008 | Sanyo DS32224 TV
Sanyo DS27820 27" TV Logo
1,563 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
