Question about Philips 42PF7320A 42 in. Plasma HDTV
Phillips 42FD9954 plasma will not turn ON
We purchased our TV in 2003, it's a Phillips 42" plasma (model # 42FD9954) and the unit will not turn "ON".  We see a standby red light indicating the monitor's "ON" but the when the power button is pressed on the remote control, the red light only blinks "on" and "of" for each time the power button is pressed on the remote.  We have tried unplugging the unit but only for a few minutes.  Anyone have a fix?  We called around for TV repair prices and these places want $125 just to give us a diagnostic analysis and then another $360 flat service fee (no parts included) to come back for the repair.  We really appreicate any help from anyone!
Thanks!
  • 6 more comments
  • Anonymous Dec 03, 2007
    it's a Phillips 42" plasma (model # 42FD9954) and the unit will not turn "ON". We see a standby red light indicating the monitor's "ON" but the when the power button is pressed on the remote control, the red light only blinks "on" and "of" for each time the power button is pressed on the remote. We have tried unplugging the unit but only for a few minutes. Anyone have a fix? **WONT TURN ON FROM STANBY**
    IM KENTUCKY,U.S.A.
  • Anonymous Dec 12, 2007
    I also have a Philips 42FD9954 and the TV will not turn on.  I get the same red flashing light.  I purchased the TV in December 2003.  Looks like a pattern here.
  • DeaThomas Dec 18, 2007
    I have the same problem. What can be done. Is it time to dump it?
    deathomasjr@comcast.net
  • Finley101 Jan 03, 2008
    red light flashes when you go to turn it on.
  • Anonymous Feb 16, 2008
    Have tried the same things as previous people (turned power off for a period of time) its just now when i try to turn the tv on, you can hear it click behind the screen a few times more than before, before it goes to the red blinking light.
    Again, our tv is only approx 4 years old.
  • blueyedhunny Apr 03, 2009
    i have a 42 in philips flat screen, and when i go to turn it on, it only shows the green light but my screen stays black. what is wrong with it? why wont it show any picture? when i push the menu button, nothing happens and when i try to change the channel or try t turn it up, nothing happens.. what is wrong with my tv? its a plasma hdtv.
  • monkmaddness Apr 06, 2009
    We have a Philips 42PF7320A/37 that is about 4 years old. Last night, we got the blinking light. The red LED flashes 7 times in a pattern. I was wondering if anyone knows what the code means? We unplugged the TV overnight, but we still get the red blinking light pattern. We are in the process of taking apart the TV to check the boards.
  • Anonymous Apr 24, 2009
    the same thing the red light comes on when i want to turn the tv on.
I have a Phillips 42FD9954/17S and every time I try to turn it on I also get the power red light blinking and sometimes it will try to turn on with a bunch of clicking noises and it will be green for a while then turn red. What I do and its very weird but works, put a blow dryer on hot and blow it under the tv on the side of the power button for about 10 minutes and it will turn on. I took it apart and there is a heat sink that if i put the blow dryer directly onto it on heat it turns on in less than a minute. Can someone tell me how I can fix this heat sink? I cant take it off. I want to put some thermal compound to see if that works. Give it a try I promise it will work. The Red Light has to be on put the heat on it and then press the power button, if you hear it clicking and green then back to red you are almost there. Keep putting heat on it and it will turn on.
Posted on Mar 31, 2009
Your problems may have been just caused by loose solder on the high power/voltage handling components of your tv. Components such as power transistors, voltage regulator ICs, rectifiers, etc., generate heat during normal operation that is why some of these components sometimes have heatsinks on them.
If heat sink is not present or heatsink is not efficient enough to dissipate heat, it melts the solder and makes the component pins lose contact and worse burn out the affected component.
Solutions:
1. Look for loose/blackened or sometimes like rough overheated solder joints on the power supply PCB or power amplifier section of your tv circuit.
2. If there is, take out the burnt solder with a soldapult or a plain old toothbrush by heating it with soldering iron and brushing it while the solder is hot.
3. Look for burnt/overheated components (obvious physical signs) such as power transistors, diodes, capacitors, resistors, etc. I there is, there is nothing much you can do unless you could identify the component part no. or value and able to purchase the replacement.
4. If you found a defective component, it may not be the only one that was defective. It may have been just a part of the circuit that was affected or just was the main cause of the failure. Try looking for more obvious signs on the circuit board.
5. Transistors, diodes, SCRs, TRIACs, DIACs, and other semiconductor tend to become shorted if the become defective. If this is the case, some manufacturers provide circuit protection to prevent further damage to the equipment. Check for possible semiconductor shorting (you should have familiarity with semiconductor charateristics and testing) . Isolate the suspected component and test with a good old VOM. A presence of shorted component also would indicate an opened or burnt resistor/s or sometimes micro fuses on the circuit board. Use your VOM to test for resistance. An open resistor would give infinity or very high resistance reading.
Hint: Resistor values to look at are 0.1 ohm-2.2 Ohms. Philips commonly uses these resistors as safety circuit fuses.
6. If component is un-identifiable or not available, it is wiser to bring the tv to your nearest or trusted electronics technicians in your area. They are more experienced to handle the problem and they may have the parts available in stock or get them for you.
Note however that it is not always guaranteed that the component you found and replaced will immediately solve the problem there may be some other parts that were affected by the defective components and will give different symptom or just burnout the new components again.
Consider it you're lucky if you replaced components or re-soldered loose joints and your TV worked !
if this solution is too much for you to follow or beyond your comprehension, then dont waste time, just bring your tv to an experienced technician to do it for you.
If all else fails, buy a ne TV!
Good Luck !
Posted on May 23, 2008
The blinking red light problem can, in most cases, be fixed by changing three capacitors oin the power supply. Check for physical signs of damage. The capacitors are usually located at the top left hand side of the board.
Posted on May 03, 2008
  • 163 Answers
How far are you from Jersey City? Contact us order@ebcelectronics.com
Posted on Oct 26, 2007
My Plasma 42FD9954 42 TV doesnt work
Familiar problem on Philips Plasma units. PSU or Sustain board failing.
Jan 16, 2013 | Philips 42FD9954 42 in. Plasma HDTV
I have a phillips 42fd9954 17s. when i turn it on the green light tuns on for like 6 seconds then fades . then nothing. no sound no picture. any idea. i am using a comp cord. had no cord when i got it
if you use vga input and there is no signal the tv shuts down in few second. It will wake up again if you provide vga signal or cycle it on off again. Change input to component or s-video and tv should stay on. On the other hand, this model has known problem with bad power supply unit but usually red light flashing when tv shuts down in that case.
Oct 16, 2011 | Philips 42FD9954 42 in. Plasma HDTV
Phillips 42" plasma has sound
U HAVE 2 BAD CAPACITOR ON POWER SUPPLY 3300UF AT 16 OR 10 VOLTS
Dec 02, 2010 | Philips 42FD9954 42 in. Plasma HDTV
Repaired power supply push main power on side of tv red light comes on do you have to have a remote to power on the remote has been lost phillips 42fd9954/17s
A reply to timeasier837
The TV needs to be connected to its tuner box in order for it to fire up properly. In fact, with the TV in standby (red light), by switching on the tuner box a control signal is sent up the cable and the TV switches on fully.
Oct 27, 2010 | Philips 42FD9954 42 in. Plasma HDTV
When I turn on the unit I get a green light, but after about 5 seconds it switches to red blinking and I do not get a screen
What is the model of TV?
The Red blinking light is a Protection Error Code. Your Tv needs repair. Most common is the power or Main Unit / Logic Board.
Post your model and how many times the light blinks. Also try unplugging for about 20 min and see if it will turn on.
Some models you get lucky and its a common problum which makes for an easier diagnosis.
Check
RNS-Systems.com
for general pricing on LCD and Plasma TV parts.
Oct 14, 2009 | Philips 42FD9954 42 in. Plasma HDTV
Philips Plasma NO LIFE
Are all the caps good on the PSB.? Most sets have Samy boards and they used very shotty capacitors. Some show NO visual clues of being blown as in poped at the (X) top. They just vaporize/dry out. Do you have a cap tester?
Best Regards and Semper Fi
Feb 08, 2009 | Philips 42FD9954 42 in. Plasma HDTV
I had the same problem (with 42FD9954/17S) that when turned on the unit, the green LED turned off and came back to red again some time later. I kept turning it on and once it went to a clicking relay sound and blinking green LED with it. It did that for a while and stayed turned on. I noticed that it is temperature sensitive. Colder the room is more often does it. Used a hair dryer and blown hot air into the unit at the left bottom grills. It helped and started to tun on quicker. Later it has deteriorated so bad that I took it a part and after several ice spraying test showed that on the middle big board (power board) there was an electrolyte condenser went bad. It is the one one which is at the middle, bottom center of the board near the fixing screw. There are two of them (cylindrical objects). The left one was the culprit. However when I fixed it, it turns on immediately but goes blinking red after that. Phillips say it is a static discharge problem. I might blown something when soldering the parts. I don't know what. Any ideas?
Dec 21, 2007 | Philips 42HF7444T 42 in. Plasma TV
Philips 42PF7320A 42 in. Plasma HDTV Logo
1,093 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
