Question about Goodman CKL24AR24 Air Conditioner
Brunt smell and sweating
My goodman ha burnt smell comig through the vents. It seems to cool, but the blower is not as strong as earlier in the day. I als see that the compressor issweating. What could be the problem, and what's the solution?
  • 106 Answers
Seems like your blower motor is burning up. Its the motor that blows cool air across the refrigeration coil. If it is a whole house ac unit, probably your main blower motor for the furnace. If you are getting sweat, that means the compressor is compressing the refrigerant, and you should not smell anything from the outdoor unit, only from the furnace. Hope this helps.
Posted on Jun 04, 2009
2005 dodge stratus rt has burnt smell coming through the vents
there's not a lot of different burnt smells it could B antifreeze A leeking heater core or yes you're absolutely right if the motors burning up it could smell bad too
Feb 04, 2014 | 2001-2005 Dodge Stratus 2DR RT Custom...
Smell fumes like exhaust when furnace comes on
You really, really need to get your furnace checked by an HVAC (Heating, Ventilation and Air Conditioning) expert. Your furnace has a section where the fire heats tubes that air is blown across then out to your home to heat it. The air in your home and the air from the combustion process should never mix. If you smell exhaust, it's possible there is a breakdown in this part of the furnace and exhaust, which can include carbon monoxide, could be pulled into the air stream and be circulated in your home. Carbon monoxide can and will make you go to sleep and not wake up! Do not use the furnace until you get it checked.
Feb 08, 2013 | Goodman Furnace Draft Inducer Blower ...
Heater vents blow blue smoke and smell of burnt leaves
Check you cabin filter it is under hood on pass side near wiper blades
If the blower motor is running fine and no smell from there.
Dec 14, 2011 | 1992 Ford Explorer
AC not cooling
first off you should have a four ton unit. what is your super heat? is it pulling attic or outside air?
May 27, 2010 | Goodman CLQ36AR49 Air Conditioner
Burnt plastic smell coming from bottom of frig
This is a sign of a short and should be looked at immediately. A smell like that is a sign of something burning. I could be the start relay and start capacitor with overload. But I would not sleep with the possibility of a fire. I will look over your model and see if I can find what this could be, Sea Breeze
Aug 28, 2009 | GE Refrigerators
Goodman Heat/Air unit Model # A49-20 Serial # 9909502720
It sounds like the blower motor has burnt up.(the one inside) The unit running for a few minutes then shutting off, is due to the high pressure/temperature safeties. When you removed the panels, did you notice any fan running?
Feb 17, 2008 | Goodman CKL49AR49 Air Conditioner
Furnace blower needs repair
Hi,may be your Fan motor shorted ,pls check the that lead wire of FM.
Regards,
Edgz
Feb 08, 2008 | Goodman CPLE24-1 Air Conditioner
Mold goodman phkj048-1
3 places where water could be coming from, The Ground, The venting system or the Condensate. Eliminate each one by first checking the condensate piping and check to make sure it is draining to the drain. Blow thru all hoses to make sure they are not blocked. Secondly, spray with a garden hose the venting system to see if the water is entering the system thru the venting. Lastly, if this happens only when it rains, you could have a ground water drainage issue.
Dec 26, 2007 | Goodman PHKJ048-1 Air Conditioner
Goodman CKL24AR24 Air Conditioner Logo
236 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
