Question about Photography
Ksx-p dual 2 program battery compartment not opening
. I can't tell if it is missing a piece or what. ive tried everything i can think of but it seems to almost be missing a piece. the manual instructs you to use a coin to unlock it, but there is nothing where a coin would even fit into it is just a flat circular thing w threads inside as if something once screwed into it.
    Habit-Forming:
  • 120 Answers
This is a Sears make for the Ricoh model of a similar name. The manual at http://www.butkus.org/chinon/ricoh/ksx-p/ksx-p.htm has a battery grip. The battery grip has two contacts that provide power to the body by two contacts. If these contacts are rusted, as the camera is from the late 70's, both sides need to be cleaned or the electronic shutter won't work. So if you do not have the small grip where 3 AAA batteries fit. You are missing the battery grip. Finding one would be impossible, you would have to find an identical camera just to get that grip.
Posted on Feb 21, 2018
  • 185 Answers
SOURCE: Can't open battery compartment.
ashe 1977
there are two ways to fix this.
1- remove the bottom cover, take the rubber seal off from the battery compartment, remove the battery then soak the bottom cover in vinegar overnite. this will remove all corrosion. remove the battery cap and clean the threads. completely dry the cap and bottom cover, apply WD40 to battery cover threads. clean battery contact with pencil eraser ( carefully ). reinstall the rubber seal, replace bottom cover.------ best fix.
2- this may not work but it's worth a try. just apply ( carefully ) WD40 around battery cap and let it set for about an hour, re-apply and wait another half hour. If this doesn't work refer to # 1
Posted on Jan 04, 2009
  • 59 Answers
SOURCE: VW alternator won't fit on brackets on engine
You need to widen the gap between the tabs. This will allow the alternator to slip over the bracket much easier. Get a socket big enough to allow the threaded insert to be driven inside it. (18/19mm) Then thread the bolt in a few threads and give the bolt a few taps with a hammer until the threaded insert moves about 1/8" or so. This will allow the alternator to fit easily in the bracket and the insert will be pulled back in as the bolt is tightened.
Posted on Feb 28, 2009
  • 10 Answers
SOURCE: microsoft wireless optical mouse 3000-can't open battery compartm
push in and up where it sys microsoft.
Posted on Mar 15, 2009
SOURCE: Nokia 2680, cannot open back to insert battery and sim
push the little silver bit on bottom inward and pull back down and it slids of
Posted on Apr 24, 2009
SOURCE: Removing the stand from a flat panel TV
None of these TVs have any problem removing the stand.
Stands for 32'' and larger TVs plug into the TV's body and are attached by 4 to 8 bolts that go through the cover, then through the plugged-in part of the stand and attach to the internal frame.
In most cases the bolts are 4 - one for each ray of the fork that goes into the TV.
Since bolts for the frame are metal bolts and bolts for the plastic back cover are usually wood-type screws (sharp on the top, wider thread) you can visually tell the one for the stand from the rest.
Look right above the stand for four, six or eight symettrically placed heads that are different from the ones you see on the corners.
Once you unscrew those the stand should feel more flexible and you can simply pull it back.
In order to do all that you have to have the TV laying on its face or back.
Watch out if it's heavy - you may need to support it towards the end of the operation. It's unlikely for it to get damaged if it falls down, but you still don't want to try your chances.
Giving it a little lift also helps unscrew the last bolts...otherwise all the force of the TV is pressing against it...and that makes it harder to unscrew.
Posted on Nov 07, 2009
Nexxtech keyboard 800 728 2. Opening battery compartment
try using a small percision flat blade screw driver....find side with dimple use screwdriver and push outter piece in toward the middle and lift ..
Aug 13, 2016 | NexxTech Computers & Internet
I have just purchased a 'chimp' 9" android tablet when ive been using the internet but i cannot seem to close any of the tabs ive opened - ive tried the - back space and of course the'x' in the right hand...
Nothing, the X in the right hand corner should close the tab.
Assuming the battery is fully charged.
Try Settings / Backup & Reset / Factory Reset
Feb 19, 2018 | Tablets & eReaders
Battery pieces
Not a minor repair. You have to remove two circuit boards and their attached wiring to replace, plus the camera covers
Feb 18, 2013 | Nikon N5005 35mm SLR Camera
Genie g3t-r remote seems like it 's programmed but doesn't open door. led's suggest it was programmed.
1) test the batteries 2) rETIGHT THE spring contact batteries 3) Resolder wires for contact batteries, see if there are some wires missing. 4) Try again with the codes.
go www. fitness.manualsonline.com get the code , and reset again.
Otherwise the remote control you must go to the repair shop.
God bless you
May 09, 2012 | Genie Company IntelliCode GICT390-1BL...
Ive been through 4 alternators on my truck it is a 1988 mitsubishi mighty max their not charging and they keep showing low output Ive checked every wire that I can see for a short and Ive found nothing I...
not sure about an external regulator, your local auto parts store could tell you that, but i think your problem is the alternator is not grounded good, find the ground wire and trace it to where it is grounded, take the ground end loose and get a piece of sandpaper and sand the metal where it is grounded , reattach securely
Jan 15, 2011 | 1988 Mitsubishi Mighty Max
Ive just bought a saitek p380 dual analog gamepad. When playing all games if i press left it goes up and right it goes down. Ive tried everything. i have windows 7. Is that the problem do you think?cheers
it usualy the settings in the game. just try to reconfigure the x and y axes to do the right thing inside the game you are playing and that should solve the problem. i did it and it worked fine for me
regards.
Dmitry
May 21, 2010 | Saitek P380 GamePad
Water dripping in the refrigerator and freezes on the top shelf. It seems to be coming from the freezer compartment. There is a square piece of metal missing from the top of the main compartment. One can...
Removed everything from the freezes. Removed a false bottom from the freezer floor, 2 screws. There was an ice build up under this plastic bottom. I let the ice melt with the de-frost cycle (or frost free cycle). No more water dripping into the refrigerator compartment.
Dec 15, 2009 | Whirlpool Refrigerators
Won't Turn On
UMM THIS MIGHT SEEM KINDA LAME BUT DID YOU CHECK THE BATTERY COMPARTMENT?
Oct 02, 2006 | Apex Digital Digitrex DSC-3000 Digital...
Photography Logo
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
