Question about Boating
I have an Evinrude 9.9 engine . It has fire but will not turn over when cranked . I went through the carbourater and nothing is clogged.To me it doesnt seem that the cylinders are getting any fuel -need help
  • 5,537 Answers
There should be a choke. It could be that you are not getting air into the engine.
Posted on Jun 11, 2009
2006 sportster with security system wont start after battery went dead ,turns over but won't fire?
Hi Anonymous, and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
3. Fouled spark plugs.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections.
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
14. Security alarm system not disarming.
For a primary suspect please visit the website below: Good luck
Harley Davidson Sportster error codes and how to access them
Nov 22, 2013 | 2004 Harley Davidson XL 1200 C Sportster...
1990 Oldsmobile toronado will not crank
If your check engine light is on get it scanned. If not pull the camshaft sensor and make sure the magnet is still in place on the cam shaft. You might need to crank it once or twice to turn the camshaft.
Jun 15, 2013 | 1990 Oldsmobile Toronado
I have a Kohler 12.5 KW marine generator on my houseboat that has a problem I was hoping you could help me with. Specs: Kohler 12.5 KW 79 CID 23HP Mfg date 9-10-96 Gen Engine Serial # 06919 L-29-R
there are some magnets behind the flywheel to cause the battery charging system to recharge the batt. sometimes they come unbonded/loose from the flywheel and cause the engine to become hard to turn. I would start there first.
Apr 03, 2013 | Cars & Trucks
Volvo 2005 EC210 BLC Engine Crank but no start .display shows code 140SID and 250 9
It can be faulty fuel pump or clogged fuel filter or its issue with starter or battery or may be problem with sensors.There are few possibilities that can cause these problem,there are few help links provided related to these issue. Click the link below and refer the troubleshooting procedure to solve the problem:-----
Engine cranks but will not start? http://technoanswers.blogspot.in/2012/02/engine-cranks-but-will-not-start.html
-------- Landcruiser prado won't start http://technoanswers.blogspot.com/2012/10/landcruiser-prado-wont-start.html ------- 2007 ford expedition engine cranks but wont start http://technoanswers.blogspot.com/2012/10/2007-ford-expedition-engine-cranks-but.html
: Engine Cranking Fast but not Firing up? http://whatisbyme.blogspot.in/2012/05/1999-lexus-gs300-engine-cranking-fast.html
1997 Oldsmobile Cutlass Ciera: The Engine cranks but not start? http://schematicsdiagram.blogspot.in/2012/04/1997-oldsmobile-cutlass-ciera-engine.html
Mazda MPV cranks but will not start? http://technoanswers.blogspot.com/2012/01/mazda-mpv-cranks-but-will-not-start.html
-------- MAZDA MPV WILL CRANK BUT NOT TURN OVER TO START? http://technoanswers.blogspot.com/2012/01/mazda-mpv-will-crank-but-not-turn-over.html
--------- Vehicle Cranks Fast but Won't Start http://whoisbyme.blogspot.in/2012/07/vehicle-cranks-fast-but-wont-start.html
How to test Crankshaft Position Sensor? http://fordrepairhelp.blogspot.in/2012/03/how-to-test-ford-focus-crankshaft.html
These details will help,keep updated for more help.
Oct 16, 2012 | Cars & Trucks
1999 FXDX WONT FIRE WHEN STARTING
1. Fuel tank empty
Good luck
Apr 27, 2012 | Harley Davidson FXDX Dyna Super Glide...
Car wont stsrt
will the engine crank when you turn the key, and will not start or does nothing happen when key is turned on. If nothing happens when you turn the key, you may have an dead battery. if it will crank and not start, may not be getting fuel or the engine isnt fireing. Check fuel first, then check to see if it the spark plugs are getting fire.
Nov 08, 2010 | 1995 Mitsubishi Galant
Will not start
if you have no fire 9 times out of 10 it is the cdi
May 20, 2009 | Boating
Boating Logo
197 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
