Question about Canon CLC 1140 Copier
Canon IR2022i Can't On
It shows system error E744 and now don't start. On screen message - Waiting... Please give me some solution...
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 153 Answers
You have a language file bootrom error code, you need to reinstall the machines firmware
Posted on Jun 07, 2009
Error code 000007 in canon ir2022i how to remove it
Find out that the error is - then act on it. If nothing in your manual check with Canon for guidance.
Sep 02, 2017 | Canon Office Equipment & Supplies
I need service manual for canon Ir2022i
hello friend, you can find the canon iR2022i service manual in below link:
Canon iR2022 service manual:
http://goo.gl/FDaoZk
thanks
Jun 04, 2012 | Canon iR 2022i Printer
MY PRINTER CANON IMAGE CLASS D611 NO PRINTTING DE
Hello and Welcome to FixYa!
Sir/Ma'am kindly explain your query, Is your printer shows some error message or it just prints blank pages without any error message? Before the problem started have you replaced your Cartridge or something you did? Kindly give some detail about the problem you are facing. I will help you according to that.
I am here for your help. Waiting of your response.
Thanks
Dec 04, 2011 | Canon imageCLASS D661 Digital Printer
Every time I turn on the calculator, it gives me this message: Waiting... Please install operating system now after a while, the screen changes to: ERROR! Press any key to turn unit off. Then turn unit...
Read the following from the TI knowledge Base. Hope it helps
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need to use the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
Oct 28, 2009 | Texas Instruments TI-84 Plus Silver...
Canon IR2022i Error E744 003. Help.
The BootROM on the main controller PCB and the system software are for different models or are of different types. The BootROM is not mounted correctly, or a fault occurred during downloading or when downloading the system software.
Jun 04, 2009 | Canon CLC 1140 Copier
CANON iR2022i reports Error 000007 on start up
To solve this you can change the fixing film, if you do not know how call service
Mar 24, 2009 | Canon iR 2022i Printer
System error E808
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540 0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542 0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744 0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
Mar 22, 2009 | Canon CLC 1140 Copier
Error code:2,114,0
HI
I have Canon PIXMA MP210 printer but problem is that whenever i given comand for print or scan than computer show "Code: 2,114,0" this message therefor printer not print or scan. so please give me solution
Thanking you,
ayyub_thakur@hotmail.com
Dec 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
System Error (-1) in my 6670
well, i have , all i do just erasing all the logs, and its back to normal again
Mar 25, 2008 | Nokia 6670 Handheld
Canon CLC 1140 Copier Logo
221 people viewed this question
old marine
old marine
