Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
Oven panel increase temp not responding Oven temp won't go higher than 350
Ordered replacement part - control board.
Posted on Jun 04, 2009
My Kitchenaid Oven doesn't allow me to set a temperature higher that 350 degrees. Electric oven. For example, i will punch in 425 and the panel will default back the temperature to 350.
350 will be the design max for your oven unless the handbook says for your model is higher rated and is faulty
repair or replace with a higher rated temp oven
Nov 07, 2016 | KitchenAid Ovens
When I light my oven, it stays on full all the time. Is it the thermostate
I'd recommend buying an oven temp dial to stick in your oven to verify the actual temp. Then you can turn on the oven using a lower setting and write down the temp for the setting. Then as you slowly adjust the setting higher and higher, note each temp. If it doesn't show a consistent increase of temp for each setting, you may need it calibrated or replaced. Good luck!
Sep 18, 2014 | Ovens
Oven set at 350 goes way higher
the oven sensor rod on the rear wall of the oven cavity is defective,remove screws holding it sometimes you can plug a new replacement sensor in from the front,if you can't then remove rear panel on the back of the oven to access the connector to replace it
Nov 26, 2012 | Ovens
My oven won't go past 350 degrees
If you have multiple elements it is possible that one may be burned out and limiting the high end of operation.. Check all to make sure that none is open and replace as necessary.
Check attached site for parts and prices. If you can get the part number it is possible for you to be able to get it on ebay for less money. No harm in checking. Search Over 2 1 Million Appliance Parts
Aug 31, 2017 | Ovens
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
I dont know how to use the oven properly. when i need to bake or roast something i want to put in my own temperature, but there is no option for me to do that. when i turn on the stove all i have is the...
There should be a plus/minus sign OR a up/down arrow to adjust the temp.on the control/touch panel. The default setting is usually 350 and can adjusted up or down accordingly,the display starts at 120 and is supposed to rise as temp. increases.
The bigger issue though is to have it serviced and see why it doesnt rise above 200
Gene
Aug 04, 2011 | KitchenAid KEHU309 Stainless Steel Dual...
Whirlpool Built In Oven - Accubake - RB5275PD06 After self cleaning last week, the control panel is not functioning properly. For example, when we press the temp button, it won't go above 350. When...
Good Evening!
This is a common problem that Ledgestone Technologies and Fixyourboard.com can solve. The touchpad on your oven has failed and will need to be replaced. Read more about the failure and solution below. Message us if you have any questions!
info@fixyourboard.com
Whirlpool Oven Wont Increase Temperature Stuck at 350
May 27, 2017 | Whirlpool Ovens
Oven model RBS245pd86
after cleaning the oven the bake temp would not go any higher than 350. when you press the temp button to go lower or higher it only go down. could you tell me what is wrong or what to do.
Jul 27, 2008 | Whirlpool RBS245PDS Electric Single Oven
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
131 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
