Question about Gateway M305CRV Notebook
My Gateway laptop M6848 right speaker just stopped working and now the left one has this horrible crackling sound?!?!?! It is brand new...ONLY a couple months old!! Please help!!!
Samsung AV-R720 - front right speaker crackles
THIS RECEIVER IS JUNK. I had the same problem with my receiver and Samsung gave me a new unit as it was under warranty. 8 months later the replacement which was brand new did the same thing. Samsung tells me it is my problem now. I should have demanded another unit. the best advice I have is not to buy this product. Samsung won't help you when it breaks and it will break. Nobody seems to know how to fix it.......
Sep 17, 2009 | GPX HTD2204 System
Toshiba 42H81 speaker crackle
It could be the board or the speakers itself.
Check see if ur air tv have any crackles?
If not u can rule it out the speakers.
Tries it with diffrent cables,see what happen.
The prob.still there it ur electronic board.
Aug 27, 2009 | Toshiba 42H81 42" Rear Projection...
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
Speakers on new dell Studio Laptop 1737 crackle and pop
Likely, what you are experiencing is the fact that the batteries in your speaker are running low. The sound of this speaker – as with any battery operated device – is reliant on fully-charged batteries. When the charge gets too low, you will experience sound distortion or abnormalities. Just put in fresh batteries, and you should be all set.
Jun 18, 2009 | Dell Studio 1737 Laptop
Gateway- built-in laptop Speakers not working
Seems to me the speaker is just plain broken. You'll need a new one, contact your vendor for repairs, or you will have to live with using external speakers/earpieces...
I hope you will get your replacement,
Yannick.
May 25, 2009 | Gateway Computers & Internet
Channel 2 crackles
Make sure your speaker wiring does not come close to the 12v power cable running for your amplifier. If your amplifier's 12v power cable runs on the drivers side of the vehicle, run your speaker cables on the passengers side and make sure your tweeters have a high pass filter to stop any pickup of engine sound (When you are driving you *WILL* notice it at high RPM. a HPF (High Pass Filter) will also stop those nasty hissing sounds on S's.
Feb 11, 2009 | Alpine PDX-4.100 Car Audio Amplifier
Gateway laptop speaker
the audio port needs to be replaced
if sound card is integrated systemboard needs to be replaced
if you have a sound card installed get it replaced.
Jun 05, 2008 | Gateway M305CRV Notebook
Gateway M305CRV Notebook Logo
382 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
