Question about Pioneer HTV-2 System
Remote for Pioneer HTV-2 not working
I switched the batteries and now the remote won't work. I have hit the reset button a few times but nothing happens, the light ion the remote doesn't even light up.
I never did fix the remote, but I was able to use my other remote (universal) to control the Pioneer HTV-2. Thanks
Posted on Jun 11, 2009
Why does my pioneer remote DDX3086 display work, but why can't I turn on my receiver or functions?
Check the remote control for its infrared emission.Check it with fresh batteries.If you wish to get more details about how to check a remote control, please visit this site.One among the posts has details about it.Surf the site with patience.
Aug 03, 2014 | Pioneer Televison & Video
Door locks won't lock/unlock
What kind of vehicle is it?
May 02, 2017 | 1999 Chevrolet Blazer
Emerson ceiling fan remote won't work
Check the remote control for its infrared emission. Check its battery contacts for any rust or dust. Check it with fresh batteries.
Nov 05, 2012 | Emerson 44 Curva Sky Ceiling Fan In...
Bought a 2002 jetta that has a prestige remote start on it. it worked fine a few months. Today nothing works..it won't start, or even trigger the start sequence, and the door lock/unlock won't...
There are two possiblities that could prove to be the fault; hood pin switch and remote start shutdown switch. If the vehicle is equipped with a hood shut down switch, you will need to make an adjustment to it for the remote starter to function. Search around the drivers side edges of the engine compartment for a push pin.If the pin is a stand alone it will be mounted near the headlight inserted into an existing hole. It may also be attached to a bracket. The remote start shutdown switch is a toggle switch located under the drivers side of the dash,usually to the left of the brake pedal, depending on the installation.
If nothing above solves the problem, you may need to reprogram the remote to the unit.
May 23, 2011 | Prestige Remote Start
EeeTop all in one PC wireless keyboard and wireless mouse not working - bayyeries fresh and reset button already checked out
you must keep the batteries out for a few minutes and unplugged then re plug to a new usb port. hit the connect/ reset button on reciever alone with batteries still out of remote then put the new batteries in (lights come on remote you know you have good batteries) and then hit connect on that. that should work if not you must hit connect at the exact same time. thats how i fixed mine.
Mar 12, 2011 | ASUS Eee Top ET2002 20-Inch All-in-One...
Twice now my Pioneer VSX-819H has shut down. Can not get any power to it. The first time I'm sure the phono pre-amp caused a surge. I no longer have it hooked up. The servicer said nothing was wrong and...
I found this for the VSX918, 818. Perhaps it's similar.
The power does not turn on. • Disconnect the power plug from the outlet, and insert again.
• Make sure there are no loose strands of speaker wire touching the rear panel. This could cause the receiver to shut off automatically.
The receiver suddenly switches off and the power indicator
blinks.
• After about a minute (you won’t be able to switch the unit on during this time), switch the receiver back on. If the message persists, call a Pioneer authorized independent service company.
Resetting the main unit
Use this procedure to reset all the receiver’s settings to the factory default. Use the front panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the ADVANCED SURROUND button, press and hold the
STANDBY/ON button for about three
seconds.
3 When you see RESET? appear in the display, press ‘
ST –’. OK?
shows in the display.
4 Press SOUND RETRIEVER to confirm.
OK
appears in the display to indicate that the receiver has been reset to the factory settings.
Mar 02, 2010 | Pioneer VSX-819H-K A/V Receiver
Sony RM-ASP001 for 400 disk changer stopped working
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Dec 23, 2008 | Sony RM-ASP001 Remote Control
Reiker ''room conditioner'' heater stopped working
i have of course the same problem......5 times now in 3 years.
i have discovered that for some reason if i disconnect the fan and put it back up it works again for another 8 months or so.
Nov 16, 2008 | Reiker Room Conditioner Ceiling Fan with...
Setting up 2nd wii remote
Greetings mlsaenz7,
You need to resynch the second remote to the Wii console. To accomplish this you need to hit the sync button under the battery cover on the remote, and then when the lights are flashing on the remote, you hit the sync button on the Wii. The synch button is located under the small cover to the left of the cd/dvd slot.
Thank you,
Dort
Go Ahead. Use Us.
Apr 19, 2008 | Nintendo Wii Console
Pioneer HTV-2 System Logo
221 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
