Question about InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector
Infocus X2 projector, white vertical strip on right quadrant.
The strip either appears as a quick pulsating/strobing bar or an incredibly solid/smooth white bar. Both times it is in the same spot (right quadrant, about 70-80% of the way from the left side of the screen...)
I've found that either pressing on the top of the projectors lamp assy, or by placing something between the metal lamp assy, and the plastic projector housing (on the right side of the projector, nearest the lamp assy) can make the line go away, or at least go away for a while. I can't insert anything as a wedge between the lamp and the casing, however, with the case put together.. and a halfway-apart projector is an ugly sight....
What can I inspect to determine the problem?
  • 2,237 Answers
On the X2, the dmd chip is attached to the main board on the bottom of the machine. you need to take the top case off, as well as the 2 power supply boards. push the dmd chip (behind the lens assembly) back onto the board.
Posted on Jul 16, 2009
What causes white vertical lines on dlp projector?
Possible fault on the mother board as there are noise on the LCD display. You might need help to sort this out if the fault does not clear even after the lamp works for some times.
Nov 05, 2011 | InFocus ScreenPlay 5700 Multimedia...
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
X2 projector A somewhat irregular vertical line has appeared near the middle. A slight rainbow affect at the line, right of the line gets progresively darker. The blank screen is normal. The projector is...
this projector does not have lcd's. it has a colorwheel and a light tunnel. the light tunnel has probably collapsed and needs to be replaced if you have distortion in the middle of the display. if it were to one side or the other or a the top or bottom it may have been adjustable. But wiith it being in the middle, I'd have to say you needed a new light tunnel.
Mar 12, 2010 | InFocus SP-LAMP-018 Projector Lamp for X2,...
Infocus X2 projector shows picture in black and white only...
that little glass square broke off of the colorwheel, and it needs to be replaced. that yellow/gray line is from the light tunnel collapsing. both parts can be purchased and replaced by you. if you don't feel comfortable doing it, you can send it in to an authorized service center. try av solutions. they're pretty good. you can purchase infocus parts from them, too.
Oct 27, 2009 | InFocus Office Equipment & Supplies
A vertical white strip appears after few minutes.
Hi fabiano did you ever find a solution the vertical line in your RD-JT91 Multimedia OH projector. I now have the same problem. Gary
Oct 02, 2009 | LG RD-JT91 Multimedia Projector
Vertical lines appear on screen
if they are horizontal, there is a ground loop problem. plug the source and the projector into the same power strip. if they are vertical, the clock and phase are off. reset the settings to factory default. then select auto image.
Jul 14, 2009 | InFocus Office Equipment & Supplies
LP70+ image problems
the colorwheel is dirty and needs cleaning (or replacing), or the light tunnel is starting to collapse (and needs replacing).
Nov 06, 2008 | InFocus LP70+ Multimedia Projector
White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Nov 28, 2007 | ASK Proxima Proxima DP2000S Data Video...
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Nov 12, 2007 | InFocus ScreenPlay 7205 Multimedia...
InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector Logo
396 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
