Question about RCA TruFlat 27F520T 27" TV
I have a rca tru flat, i hooked my dvd player to it dont see a picture. tryed to find video channel cant find it.
    Problem Solver:
  • 11 Answers
Do u have 2 dvd players if u dont do u have video 1 or 2
Posted on Jun 04, 2009
I have rca tru flat tv w/built in dvd and i have universal remote I cant get the dvd set on the remote also I cant get dvd to rewind or fast forward
Hello
It will be very difficult to get all functions of the RCA device, synchronise with a universal remote control. Just find a code, whic has maximum finctionality. That is all we can do. Just try an other code for RCA TV to universal remote. I hereby send some codes to check. OK
TV: 1144 DVD: 3423, TV: 1146 DVD: 3424
TV:045 DVD:091
Jan 21, 2012 | RCA 20F610TD TruFlat TV/DVD
Connecting dvd player to a television need a diagram t.u
If you are going to hook up the DVD player to your TV through RCA cords, see the picture below.
Hook up the yellow RCA cord at the Video-in at the back of the TV and the other end at the Video out of the DVD player to get the video.
Hook up the red RCA cord at the Audio-in(right channel) at the back of the TV and the other end at the Audio-out of the DVD player.
Hook up the white/black RCA cord at the Audio-in(left channel) at the back of the TV and the other end at the Audio-out of the DVD player.
Red and white/black RCA cord is for the sound.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 07, 2011 | Televison & Video
I have hooked up a dvd player (with red, yellow, white output wires) to my ge tv model #25GT534 and turned the tv to channel 91, which is the av input channel. I get sound, but no picture. What am I...
check to see if the yellow rca jack is connected to the video out of the dvd player. If that does work try a different cord. You could try one of the audio(red,white) in the yellow section of both tv and dvd, to see if the yellow one is defective
Jul 20, 2011 | Televison & Video
Trying to hook up an emerson dvd player to tv and its not working? older tv it has no cable hook up or control box for channel set up, shouldnt the dvd player still be able to work though?
IM GUESSING THIS MIGHT BE AN RCA TELEVISION? if you dont have an rca in hook up on the tv give up and buy a new tv or you can find an older item what it is is a switch that has an rca input and a coax output it was used to hook up the older video game systems it is still sold in most stores and that will work if you do have rca inputs and lost the remote you need to get a universal remote to switch the input on certain older rca tv's you could go to channel 00 and it would set it to the input with the switch you shoudl be able to use it by putting the tv on channel 3
Feb 28, 2010 | Emerson EWD7001 DVD Player
I've hooked up my dvd player to my rca television
Did the dvd Play? if yes, Maybe you have to select in the VIDEO mode on your t.v. not in the CHANNEL Mode. Because you cannot watch video in channel stations unless otherwise you have RF tuner. or the rca plug is faulty???? Try another rca
Mar 20, 2009 | RCA Televison & Video
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
Trying to hookup and play standard DVD player
Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
Dec 12, 2008 | RCA F25441 25" TV
Lost orig remote/ fpa lock on
I have a 20f511t RCA Tru Flat with FPA lock on, using an universal GE remote press setup, then menu, channel down to preferences, press enter, channel down to FPA LOCK, volume up to change to on or off, press menu to remove, all shoud work now
Nov 23, 2008 | RCA 20F420T 20" TV
RCA works fine when watching dvd but when cable is hooked up...
Similiar problem on this Chassis,( Popping + Sreeen Collapse)
Found Leaky 470 uf cap. near vertical output ic .( B+ Filter)
TechServices @Gmail.com
Sep 05, 2006 | RCA F20TF10 20" TV
No picture
Tvs usualy have a few ways to hook them up. One is a coax cable this is the silver one in the back that you screw in a cable. The second are RCA cables these are the ones that are yellow, red and white. Yellow is always the video and white and red are for audio. If your using the coax cable your tv needs to be on channel 3 or 4 you may have to force the tv to go to that channel by pushing 03 on the remote. If you are using the Rca cables then you need to change the tv to "video 1" or "video 2" this changes the tv from tunner mode to aux input mode. Most DVD players dont have a coax out so you have to use the rca plugs. Some tvs have the rca plugs on the front (video 2) and the back (video 1) or line in. Some tvs have line out also so you need to figure out wich way you have it hooked up. Do a search for the model of your tv and it should show a diagram on how to hook it up.
Apr 07, 2006 | Emerson EWD2003 DVD Player/VCR
RCA TruFlat  27F520T 27" TV Logo
279 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
